September FS Thread
Mr. Badwrench
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for Race Car parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and I will delete it.
3) you are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, all your posts in the FS sticky will be deleted
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
We will delete any BS we feel does not belong in here
4) NO WTB ADS!
Mr. Badwrench
testing waters on my welder:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matco tools page »</TD></TR><TR><TD CLASS="quote">Great shop style MIG welder for smaller shops doing general repairs and fabrication.
Also works as a great second or back-up unit for larger shops.
Comes complete with 10 foot ground cable and MIG gun, sample spool of .024-in. steel welding wire, extra contact tips and nozzles, and gas regulator.
Six heat settings.
Cold wire design - no false arcs.
Welding range from thin 24 guage steel up to 5/16 in.
Handles solid MIG (with shielding gas) or flux cored welding wires. Easy polarity change terminals under hood.
Twin spindles to hold two different spools simultaneously (1-4 in. spool, 1-8-in. spool saves time when changing wire types).
Large cabinet to handle full sized (30#) spools.
Built-in cart for mobility - handles small to medium sized gas cylinders.
Quick set drive tensioning system - toggle release to maintain optimum tension when changing wire spools.
8 foot power cord (customer supplied (male) plug) - 220 volt.
130 amps @ 30% duty cycle.
Max output 180 amps.
Recommended max thickness to weld = 5/16" single pass.</TD></TR></TABLE>
600/wo 700w/ 7525 bottle.
prefer pickup, but halfway up to 150 miles round trip, ill take the hit. more than that, we shall see.
located in delaware.
NIB:
crower b series springs and titanium retainers
350 shipped
arizona speesd and maring first gen b series mounts crx civic
100 shipped
vafc (original ) new never installed
100 shipped
straight t4 turbo and sfp t4 log manifold NO WASTEGATE FLANGE. add what everone you want
450 shipped for both
txs rfl bov
looks new but there are scuffs on the plunger
100 shipped
b16 dizzy external coil kit
msd cap and blaster ss coil
100 shipped
Six heat settings.
NIB:
350 shipped
100 shipped
100 shipped
txs rfl bov
100 shipped
100 shipped
updated as of 9-23-08
* thumbs are clickable !
__________________________________________________ ___
Yamaha golf cart (Gas) 2000.00 FIRM !
- fresh paint
- recovered seats with white marine vinal
- new front king pins/bushings
- new choke cable/air filter/sparkplug
- new brake pedal spring
- new rear drums
- new tires/wheels/lugnuts
- comes with cover for outside storage
- setup for tow strap for drag car.
$2000.00 FIRM
1992 honda civic si racecar chassis
* 10pt chromoly cage with parachute mount/wheelie bar hookups_ just certified this year_
* Custom aluminum dash, door panels and interior panels
* chromoly wheelie bar with wheeleze wheels
* stroud window net
* omp race seat
* FAL lexan windows (race kit) * Lexan sunroof *
* MB Products fiberglass doors with chromoly frames and lexan window with stainless allenhead bolts/nylock nuts
* G-Force seatbelts, brand new last year (2007)
* Tube front end with midplate & solid timing belt side mount
* clearanced for 28" tires
* Acura sundance gold pearl paintjob
* entire chassis was sand/bead/media blasted before paint
* Carbon fiber front nose
* spare tire well is cut out, with flat aluminum panel covering
* CNC master cyl / cnc staging brake with line lock
* OMP steering wheel with quick release/line lock button
***asking 12,000*** (this does not include suspension/wheels/any extras besides whats listed above)
buy the whole car complete/running with extras ** 55,000 car and golf cart**
Weld Magnum Drag 2.0
- 15x10
- 4x100 bolt pattern
- 6inch backspace
625.00 shipped/ 575.00 picked up
will sell without centers 525.00 shipped or 475.00 picked up
AEM EMS
-1020 box
- fits obd2a honda/acura (96-98) will fit others with jumper harness
- setup for T1 Racedevelopment cam trigger setup (also works with msd distributor and oem distributor)
- comes with serial cable
750.00 shipped in the 48 states
Hydraflow clamps 225.00 each
* fits 4inch tube
* i have 4 clamps
* OMC coils (coil on plug) with bracket
- fits b series vtec heads
225.00 + shipping
*obd2b to obd2a jumper harness
150.00
______________________________________________ -
* B16 block with crank. block has some messed up holes where driver side mount bolts on, can be fixed. 75.00 + shipping
__________________________________________________ ________
* Billet Aluminum shock tops from Strange Engineering50 shipped
* Str sparkplug cover 75 shipped
__________________________________________________ __________
* Greddy TVVC Boost Controller 200.00 the most bad *** manual boost controller ever !
* eibach front and rear sway bar kit with endlinks etc, i belive its everything for installation. 250.00
* Autometer 3 3/4inch Sport Comp Tach, with mounting bracket 75.00 shipped
Oil Catch can
80 shipped
* fits 1-3/8 filter
* -12 an male bung
* 1/4npt drain/plug
10 inch tall coil springs
* fits 2.5inch shock
* 350lb rate
50 shipped
Modified by DaveF at 2:04 PM 9/23/2008
- fresh paint
- new rear drums
$2000.00 FIRM
* stroud window net
* omp race seat
- 15x10
- 6inch backspace
AEM EMS
-1020 box
* fits 4inch tube
* i have 4 clamps
225.00 + shipping
150.00
Oil Catch can
80 shipped
* fits 1-3/8 filter
* -12 an male bung
* 1/4npt drain/plug
* 350lb rate
50 shipped
own a piece of sc drag racing history. Bare chassis, no wheels, electronics, etc.
comes with everything else. alot of money invested, will make great bracket car. custom midplate with shifter assembley, all lexan. car has gone 9.89 and has pulled a 1.43 60ft. omni's up front have 10 passes on them.
6000 takes it. i will even deliver it to you for free up to 400 miles round trip.
Apexi tach used 100 shipped
t1 cam trigger kit new never used 450 shipped
obd1 p30 ecu. neptune chipped with datalogging cable. vp import race tune by jeff evans. 350.00
Used Exedy twin disc ceramic clutch, was sent to exedy inspected, only 10% worn, still in very good condition, grabs very hard.
new cometic 82mm ls headgaasket.
used richmond spool for b16/ls trans with bearing 150
new mb products passengers eg door 150
used crower stroker kit missing pistons for a b16 800.
must add 3% for paypal
Modified by ciscoscivic at 6:34 PM 9/1/2008
Selling race car with many extra parts. Asking $11,000-obo for the whole thing.
Chassis-1999 Honda Civic Si Chop Top
Class-All Motor
Engine-B18C1 Stroked and Deck Plate to a 2.3
Bore-86mm
Stroke-98mm
Crank-Eagle B20
Rods-Eagle
Pistons-Arias
Port Job-Port Flow
Cams-Ferrea and Roller Rockers
Valves-Rev
Throttle Body-BDL 74mm
Fuel-Methanol
Tranny-GSR
Header-Custom Burns
ECU-AEM
There are no drag rims or tires with this car. They have been sold all ready. The car is on stock wheels.
You can email me at jlopes@twcny.rr.com or on here for info.
a href="http://photobucket.com" target="_blank">
</a>
Class-All Motor
Bore-86mm
Stroke-98mm
Crank-Eagle B20
Rods-Eagle
Pistons-Arias
Port Job-Port Flow
Valves-Rev
Fuel-Methanol
Tranny-GSR
Header-Custom Burns
ECU-AEM
</a>
Email Address : srt4thatazz@yahoo.com
State : NJ
nitrous set up SOLD!
Tial 50mm BOV SOLD!
SOHC VTEC engine, transmission, p28 ecu. Market place link below.
http://www.hondamarketplace.com/zerothread/2373575
Autronics ECU $1000
I'm selling my Spearco liquid to air intercooler setup. SOLD!
New S372 standard cover 90 ar hotside $1000 Will trade + cash for smaller turbo like a 35R
Also for sale is a custom IC using a Spearco core 24x12x4.5 $500
Modified by srt4thatazz at 6:30 PM 9/29/2008
State : NJ
Tial 50mm BOV SOLD!
Autronics ECU $1000
Competition Engineering Fuel Sump
$80
B Series Log Manifold
$275
B18 Block Guard
$60
D16Y8 Mains & Rod Bearings
$75
H22 Turbo Manifold
$300
Brand New Emanage Ultimate $500 obo
91 Civic Aluminum Dash Board with Gauges $300
Modified by Power2r at 4:27 PM 9/19/2008
$80
$275
B18 Block Guard
$60
$75
H22 Turbo Manifold
$300
Fluid Control Solutions
stainless steel braided brake lines meet the strict guidelines of the U.S. Dept. of Transportation MVSS-106 requirements. They improve your braking performance for competition or every-day driving. Replacing the OE rubber hoses with FCS brake lines reduces brake pedal travel for more consistent braking. Featuring stainless steel braided brake hose with zinc-plated fittings, these brake lines are factory assembled utilizing a double crimp method requiring no special adapters for installation.
applications i have for sale: only one left of integra/civic
88-91 civic/integra 92-01 civic/integra
06+ Mitsubishi evo 8,9, and 10
Subaru wrx impreza, and sti models 05+.
95 shipped
fluid control solutions
turbo oil / evacuation line kit
comes with everything you need. take all the guess work out for you and complete this kit so the end user get a super easy install.
115.00 shipped
sale pending first come first serve.
clutch line lit for k series swap, b series, and everything inbetween. complete with all the hardware and locator's clips. all lines are vinyl dipped for abrasion free and protection against any sharp edges the hose may encounter
65 shipped.
for 92-01 civic integra with b series, and k series one left.
vtec line kit for ls hybrids.
65 shipped
2 rolls of this heat insulation
9 feet left of black/ 3 ft left of silver
garrett GT4202r
fully rebuilt with new wheels from precision turbo and engine.
the turbo runs a precision exhaust wheel with a .98/ 1.01 exhaust housing from precision for high flow rates then its garrett housing.
1650.00 obo
wastegate line kit with 12' 1/4 d.o.t air brake line and 14 air lock fittings and 2 tees for your dual wastegate installs and vacumm lines for your manifold, and boost soleniods, plus we'll throw in some heat insulation to cover your high heat areas. track proven and tested. comes with everything you need to do a clean install.
70.00 shipped
k series fuel system for motor swaps!
complete kit for clean install and everything you need to change over your 92-01 civic or integra for k series. comes with aeromotive reg, hose and fittings, compression return lines and all nessary clips and banjo fittings needed
pics with soon follow. the best bang for your buck kit on the market without compromising quality and fitment
450.00 obo
radiator hose kit
complete -16 stainless steel hose top and bottom for honda. comes with 4.5 feet of stainless hose and 4 high quality red hose AN fittings. 4 aluminum -16 weld on fittings for your aluminum radiator
225.00 obo new
Up for Sale Autometer Tach 5'' with shift light used... $50.00
Used Rota Slips Silver 5 lugs for type R suspension 2 wheels only...$140.00(Pending)
Toda C cams for sale...PM me for price... also interested in trade for GSR tranny.
Up for sale also is a brand new set of GRP aluminum rods for LS/B20 motor. PM me for price...
Custom cam trigger with AEM cam gears. You have to use the stock crank trigger to make this work (which is included). Came off my friends car and I have no need for this on my new setup. $250.00 OBO
Was used for data loging oil pressure. Part number off the sensor
35-2114
P158-5198-4
D1204-023
Comes with pig tail $75.00 OBO
Was used for data loging fuel pressure. Part number off the sensor
35-2114
P158-5198-4
D1204-005
Was used for nitrous. Part number off sensor
P195-2000S-E3A
E1004-019
Sparco gloves (ISO 6940 FIA 86 rules NOMEX) and Saprco head sock (one size 54-62 mod. 00148 EN 340) $40.00 OBO
35-2114
P158-5198-4
D1204-023
35-2114
P158-5198-4
D1204-005
P195-2000S-E3A
E1004-019
I have a few good parts for sale.
Brand new 50mm TWM K20 ITB with fuel rail and tps: $900
Golden Eagle B-series Cam Gears 1 red and 1 blue brand new: $75 each
Odyssey PC 625 battery and charger: $100
Please IM if interested
B series.. These pistons are brand new and never used. They come with upgraded wrist pins 800++++ hp capable. Also includes upgraded rings as well.
Endyn Roller wave pistons
a. 85mm
b. 9:7.1 compression
c. Upgraded wrist pins
d. Upgraded rings
Looking to get $600 and will take offers
a. 85mm
d. Upgraded rings
Here is the breakdown of what I am looking to get. MoTeC prices have gone up, but mine have not. Expect them to go up again. Keep that in mind.
M4 w/ advanced tuning option enabled - $2350 (advanced tuning for M4 cost me $475)
M4 Honda Harness (built by Tony1) - $950
Total $3300
I'll take of an extra $200 to help it sell
New Total $3100
Pro 12 w/ harness and integrated into M4 harness - $900
or
Pro 12 w/ harness and integrated into M4 harness plus CBR coils and coil harness (also built by Tony1) - $1100
That about sums it up. Let me know if you have any questions. All was purchased from Tony (I have all receipts still) and is still brand new. I have all paperwork and wiring diagrams too.
Note*
I used velcro on the back of the M4 to mount it to my electronics plate. For the Pro 12 I used vibration mounts (which I can include) to secure it to the plate.
Pics:
MoTeC M4 and Harness (T1 trigger not included)
Pro 12 and harness w/ CBR coil sticks
Any questions feel free to ask.
Total $3300
New Total $3100
or
Note*
Pics:
fs:
tilton twin disk clutch. bseries. 9lb flywheel. $1000 shipped
built gsr tranny, new synchros, obx lsd, mfactory 4.7 final drive. $1500 shipped
precision 750hp intercooler, aluminum piping, heatwrapped, vibrant couplers, tbolt clamps, tial 50mm bov. $750 shipped.
4" steel exhaust off my delsol, vband connector, magnaflow shortie muffler. $300
Modified by building boost at 4:28 PM 9/9/2008
Will pay shipping on small parts and willing to work with seller on half of shipping on larger stuff. email me for more pictures or PM me with questions.
PAYPAL VERIFIED ONLY PLEASE !!!!!!!
Password JDM conversion harness obd2a to obd1 45.00
Digital 7 Programmable with HVAC coil 750.00
Digitial 7 Hand Held Programmer 135.00
Mazworx Scatter shield 150.00
MSD igniter 40.00
ARP Main Studs 2 sets 50.00 each set
01-05 Honda Civic lowering Springs 1.5” Sprint 65.00
Tial 44mm Large Springs 22.00 each
1) Green .8 bar 11.60 psi spring
2) Yellow .6 bar 8.70 psi springs
Fluidampr B series Street damper Brand New 295.00
Neptune Dataloging cable 35.00
IPG V1 Turbo Camshafts with GE cam gears 400.00 obo
Speed sensor GSR 45.00 i have 2
Integra mounts 35 each
OBD2a Engine Harness Injector resistor all wired in with resistor box, 5 bar map wired in. everything is all reloomed.
Borq S372 Turbo Brand New ran few pulls on the dyno.
1.25 a/r exhuast housing
High Output Compressor cover with V-band welded to it
Antiserge delete Installed
Fully polished cover
everything listed 1450.00 shipped obo
Virtual Works Top Mount Manifold
Wastegate Dump Tubes
4" down pipe with Flex and V-band will fit with both GT42 or s372
1350 for everything
Virtual Works Intake Manifold with Accufab 90mm Throttle body
comes with cable, IACV, Push lock Fittens for vaccum sources
For GSR head Fully polished also TPS is included.
1250 shipped
Small smudge will polish it clean before i ship lol i did have little dirty hands removing it lol but no scratches at all.
Oil return with billet flange and -3 oil feed with earls inline filter 75.00 for both
Golden Eagle Cam Gears Black 175.00
Greddy GSR timing belt 75.00 shipped
Virtual Works Intercooler with Gerrett Core Polished end tanks with intercooler piping. All V-banded 3.5" piping from Intake manifold to intercooler then 3" from intercooler to Turbo. everything is fully polished. Intercooler piping was built for EK Hatch //// Deminsions of core is 24x12x4 1150hp rated
1250 will seperate
will make a Package deal on the whole turbo kit together Intake,Exhuast manifolds tial wastegates, DP,DT, Intercooler and piping all together. As long piesces havent been sold or will make what we can together is some stuff has sold.
Autometer SALE
Electric fuel Pressure Gauge
#4363 with sensor 150.00
No sensor 75.00
Nitrous Pressure Gauge
#4328 65.00
Boost Gauge 0-35psi
#4304 40.00
3 3/8s Tach 0-10,000 rpm With mounting cup
#6604 185.00
Oil Pressure Electric
#4353 40.00
Modified by buck02 at 10:10 AM 9/15/2008
MSD igniter 40.00
Borq S372 Turbo Brand New ran few pulls on the dyno.1.25 a/r exhuast housing
Virtual Works Top Mount Manifold Wastegate Dump Tubes
1350 for everything
Virtual Works Intake Manifold with Accufab 90mm Throttle bodycomes with cable, IACV, Push lock Fittens for vaccum sources
1250 shipped
Virtual Works Intercooler with Gerrett Core Polished end tanks with intercooler piping. All V-banded 3.5" piping from Intake manifold to intercooler then 3" from intercooler to Turbo. everything is fully polished. Intercooler piping was built for EK Hatch //// Deminsions of core is 24x12x4 1150hp rated1250 will seperate
Autometer SALE
No sensor 75.00
#4328 65.00
Boost Gauge 0-35psi
#4304 40.00
#6604 185.00
#4353 40.00
1992 civic
b18c1 fully built
829whp @ 35 psi
Modifications
To much to list.
This car is turn key race ready!
Asking $20,000 or make best offer
serious inquires please call 956 346 6136 or email @ jaynjesyka0423@aol.com
Here is the link of some dyno pulls-
Another link of the 9sec. pass-
One more video of this pass weekend in Clash Of The Titans 8-30-2008-
And some pics:
There is nothing wrong with this car thinking about tring some thing different.
b18c1 fully built
829whp @ 35 psi
Modifications
To much to list.
And some pics:
<FONT COLOR="blue">The 2nd one is a 95 Integra RS. Built for SFWD/Turbo Street. Car has been aligned and corner balanced. Weight in at 2380 without driver. Car idles and has a base map in it. Still needs a final tune. CAR HAS ONLY BEEN IDLED. NEVER BEEN DRIVEN OR TESTED SO THE MOTOR IS FRESH! Everything on the car is brand brand new and has never seen track time or daylight for that matter. Title is clean and in hand. Here is the list of mods on this one.</FONT>
Engine:
Darton Sleeved 84mm GSR
Micropolished GSR Crank
CP 84 9.0:1 Pistons with upgraded wrist pins
Manley Turbo Tuff Rods
ACL Race Bearings
Headwork done by T1 & Trevor Johnson Racing Heads in Texas
Skunk2 Pro-Series Valve Springs
Skunk2 Retainers
Skunk2 Stock Size Valves
Skunk2 Pro 2+ Cams
Skunk2 Intake Cam gear
Golden Eagle/T1 Exhaust gear
Edelbrock Intake Manifold
BDL 70mm TB
3" Intercooler Piping
Tial BOV Black 9psi
Peakboost HVS Topmount Manifold
Peakboost downpipe
GT4294R 1.02/ar Turbo
Tial 60mm w/g black
RC 1600cc injectors
BDL Fuel Rail
Aeromotive Fuel Pressure Regulator
Fluidyne Radiator
T1 Cam trigger kit
T1 Catch can
Custom 4" exhaust with Vibrant Race Muffler
Catch pan
Transmission:
Heat treated gears, Liberty Cuff, Quaife LSD, Exedy Twin Plate Clutch, Skunk2 Short Shifter, Golden Eagle Scattershield
Fuel System:
Sumped fuel tank with -12 out
Aeromotive Pro Filter -12
Aeromotive A1000 Fuel Pump
Aeromotive Fuel Filter -10
-10 line all the way up and -6an return
Suspension:
Skunk2 PRO-C Coilovers with Drag spring rates
Skunk2 Pro-Series Front Camber Kit
Skunk2 Pro-Series Rear Camber Kit
Skunk2 Rear lower control arms
Avid Racing Pro-Series Traction Bar
Weld Racing Magnum 13x8 5" backspace w/ Mickey Thompson 24.5x9x13 slicks ( BRAND NEW)
Weld Racing Magnum 15x3.5 skinnies w/Mickey Thompson 22.5x4.5x15 (BRAND NEW)
Stroud Parachute
Interior & Electronics:
Corbeau Racing Seats
Simpson Racing Harness (Jan 08)
Sparco Flash 5 Steering wheel with quick release hub
Mazworx 9sec cage with window net
Autometer Shift Light
Autometer Digital Pro shift system
NLR 500 Boost Controller
AEM EMS
M&W PRO 10 Igntiion w/T1 Harness
AEM Oil Pressure Gauge
Asking $20,000 OBO
Engine:
ACL Race Bearings
Skunk2 Retainers
Skunk2 Pro 2+ Cams
BDL 70mm TB
Tial BOV Black 9psi
Peakboost downpipe
Tial 60mm w/g black
RC 1600cc injectors
BDL Fuel Rail
Fluidyne Radiator
T1 Cam trigger kit
T1 Catch can
Catch pan
Transmission:
Fuel System:
Suspension:
Stroud Parachute
AEM EMS
Asking $20,000 OBO
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
I have a (b series or H23) T1 cam trigger sensor kit for sale. Used (minus bracket) (pigtail included)
350.00 + paypal fees Shipped to your door!
This kit goes for 495.00 (new) without the bracket.
A1000 pump, just came back from Aeromotive with a new motor. Hasn't even been mounted since I've gotten it. Basically like new without the price tag.
$250 + shipping
joe at redjacksolutions.com
paypal verified 120+
$250 + shipping
H22 "Euro R" Dogbox trans. W/4.78 final drive. Euro R ratio with Dog engagement. Liberty. $2800.
H22 Tilton Twin Disc Clutch set $800
Fully Built H22 All Motor Block for all motor setup (Stroker Crank) Alum Rods, Custom Short 16:1 pistons, RS Sleeved Block, Unassembled brand new parts, Also has all brand new Honda Main and Rod Bearings. $2800
H22 Ported Head $650.
B series or H22 Skunk 2 brand new unopened Pro series springs and retainers. $280
ACT Heavy duty pressure plate and 6 puck disc with ACT Prolite flywheel $300
RC 440 injectors $250
GE H22 sheetmetal Intake Mani (all motor) - $400
Modified by h22crxpwr at 8:25 AM 9/8/2008
Garret gt 4202 74mm, 1.28 ar exhaust, used but really good shape $900
M&W Pro Drag 4, Bad *** ignition $950 with connector
2 Tial 44mm wastegates 1.0 ar springs with flanges SOLD
Tial 50mm BOV Blue color $170
***DSM parts if anyones looking***
1600 cc injectors used on my race car so not very old, $300
Magnus motorsports 10an hard anodized fuel rail SOLD
Groden aluminium rods 6 bolt with 22mm (2g) pin upgrade, used for a couple dyno pulls and 2 low power passes. $500
FP5R and FP11 cams, bad mothers SOLD
Kiggly Racing Beehive valve springs/retainers SOLD
Kiggly Racing block girdle SOLD
Shipping not included on anything at this point
Tom@rrevmotorsports or send me a PM here
Modified by evil93evo at 10:23 PM 9/3/2008
Modified by evil93evo at 10:46 PM 9/3/2008
Modified by evil93evo at 5:51 PM 9/4/2008
Modified by evil93evo at 1:02 AM 9/6/2008
Modified by evil93evo at 10:24 PM 9/7/2008
Modified by evil93evo at 3:55 AM 9/9/2008
