Sept fs thread
AEM injector driver $100
4" bell mouth $50
Toda B cams $600
Pro Drive Spool $300
Gator stage 3 axles with hubs $700
Love Fab manifold brand new $550
water box 16x12x10 with -16 fittings $250
Power FC with commander $600
MSD Pro coil $50
Earls 19 row oil cooler $130
MSD 2 Step $40
RCI seat belts blue $95 for both
Password JDM LS intake Gasket New $25
Sparco 2" seat belt blue $60
4" bell mouth $50
Toda B cams $600
MSD Pro coil $50
MSD 2 Step $40
I have BNIB 83mm CP 9:5:1 pistons never mounted rings still sealed. (BSeries)
Located in NY will ship PayPal.
Price $500 obo
I currently have no pics because I'm at work any questions pm me or text 516-729-4760
Price $500 obo
Parting The race car out to fund another Project. All Prices do NOT include shipping, Buy pays shipping. Everything is AS IS. Please ask questions but dont Message me if you intend to try an low ball. All reasonable offers will be considered.
95 Integra ls shell. SOLD!!
Skunk2 Pro 1s Sold!!
Hassport solid mounts Sold!!
Liberty gear set w/bilet bell housing sold!!
Competition Clutch Triple Disk. SOLD!!
BMC intake Mani- SOLD
Full Race divided top mount, dual 44mm gate flange- Sold!!
(2) 44mm tial gates Sold!!
Garrett 1000hp core custom dual back door intercooler- SOLD!!
Spinwerks skinnies - Sold!!
Fluidyne radiator with -16 fitting and lines Sold!!
Toda cam gears Sold!!
ATI dampner Sold!!
B16 ported head, Ferrerra valves, supertech guides, springs and ti retainers. This head was a virgin when i got it.
Its practically new. only has a couple dyno pulls and 8 passes $1200
Short block- GSR RS Machined open deck block, Arias 83mm pistons with upgraded wrist pin, Manly TT rods, LS crank,
Bottom end will be Freshened up before shipped to buyer. $3500
DSS 5.9 no hubs $800
AEM thermal amplifier with egt sensors $450
Ross machine 90mm TB with tps - $250
Spinwerks 15x10 6" BS, m/t 26x10 slicks - $700
MSD Digital 7 (7531) - $500
MSD HVC coil - $100
Custom Catch Can/Coolant overflow - $100
ATI dampner Sold!!
MSD HVC coil - $100
Selling some of my extra Sh_t before I move shops.
62mm adapters(can actually upgrade your 60mm wit this setup to bigger horn)
$150.00 (over $350 in retail) Horns sold adapters only
Integra Steering wheel (came off our turbo Car)
$50.00
Custon CP Pistons that I ran last year
$500.00
RSX Altenator
$50.00
Hasport 95a inserts(Great upgrade for street cars)
$50.00
Racepak Kpro harness
$250.00
Integra GSR front spindles with 3.9 hubs
$300.00
All Parts are plus shipping and paypal fees
Marc P
$50.00
$500.00
RSX Altenator
$50.00
$50.00
$250.00
$300.00
Marc P
1. RS Machines sleeved LS bare Block w/main caps.
I bought the block at 85mm bore with some damage in cyl number 4 and was told that 86mm should clear. After I already ordered my custom pistons, had it bored/honed, cleaned, decked my machine shop said it was a no go. THE BLOCK NEEDS TO BE BORED OUT TO 86.5mm TO CLEAN UP THE SLIGHT GOUGE THAT'S IN CYLINDER NUMBER 4. All the other cylinders are perfect! It comes with a Z10 Girdle, ARP Main studs all aligned bored and ready to go. Like I said before, I ran out of funds and that's why i am selling this.
Like I said this block includes all this: fresh decking, Z10 Girdle, ARP Main studs (aligned bored/honed already), breather bungs out the back already. I am selling the block cheap and AS-IS so will take 450 shipped!!
2. BNIB 86mm Custom Wiseco 5.5cc Pistons
Brand new in box set of Wiseco 86mm B-series custom pistons complete with wrist pins, clips, and rings. These are the pistons that i was planning to use but because of the block dilema, I am out of funds and can't buy a new set of pistons.
They are 5.5cc dome, skirt coating, and comes with spec sheet etc. Approximate compression with a stock crank will be around a streetable 12-12.5:1. I found out I'm having to go with a bigger bore in order to use my block so that is the only reason for selling. Looking to get 500 shipped
3. Set of USED Carrillo Pro A LS/B20 Connecting Rods
I ran these in my previous setup and was planning to re-use them in this engine. They are light as hell for a steel rod weighing in at 421 grams each. Probably one of the top of the line rods that are decently affordable. The rods are tanged for GSR bearings btw
but either set (LS/GSR) will work. I was about to use them so just had them balanced but things came up so changing plans. Looking to get 590 shipped for the set.
I am asking $160 for this. The filters have been removed and sold, but I can obtain more for additional fee or just give you the part number.
The can is baffled inside to reduce the amount of oil vapor that escapes out of the filters. They collect and catch it allowing it to fall back into the bottom of the can.
The sheer volume of this catch can with the amount of volume it vents out allows your engine to breathe much better compared to the little cheap sealed 'greddy' like units.
Motec SDL backlit with datalogging unlocked.And a Motec SLM packaged together with harness.. $3,000 obo
Also Motec M4 with datalogging $850 obo
[IMG]http://i46.photobucket.com/albums/f103/Puerto_rico_nc/motecm4.
A1000 Barely used ran out of fuel on dyno so replaced with eliminator $250 obo
Borg Warner S374 1.0ar black compressor housing now.. used for 3 passes $1000 obo
Tial Bov $180 obo
Tial 38mm wastegate Brand new mvs $225 obo
Precision 600hp intercooler $300 obo
RC 440 used to start vehicle otherwise brand new $300 obo
OBX b16 ITBS $500 obo
Tial Bov $180 obo
Up for sale is my 2.7L k24 long block built by 4Piston Racing. This motor has only been ran in the garage and on the dyno. Never been raced. Complete valve cover to pan.
The motor has the following :
-4Piston Pro 163 CNC head
-4Piston billet K600 single lobe cams
-Ferrea aluminum rockers
-4Piston valve springs
-4Piston valves
-ERL sleeved block
-Billet 106mm crank
-GRP Aluminum rods (4Piston spec)
-Wiseco pistons (4Piston spec) 16.5:1 CR
-ERL s2k oil pump
More detailed build specs and dyno numbers can be given to buyer.
$10,500 OBO
Also for sale is my Albins 4 speed helical dog box.
Trans has the following:
-Albins helical cut dog engagement 4 speed gear set, final drive, shift forks
1st gear : 2.55
2nd gear : 1.72
3rd gear : 1.32
4th gear : 1.08
Final Drive : 5.23
-MFactory LSD differential
-New OEM bearings thru out
This transmission was assembled by a certified Honda technician. Again this transmission has not seen track time. Only been on the dyno.
$6500 OBO
I am willing to separate the head and block. Also willing to sell just the gear set with out diff and case.
Contact me via pm on here
-4Piston valves
-ERL sleeved block
-Billet 106mm crank
-ERL s2k oil pump
$10,500 OBO
1st gear : 2.55
2nd gear : 1.72
3rd gear : 1.32
4th gear : 1.08
Final Drive : 5.23
$6500 OBO
RACEPAK Set up!
Will Sell Complete or parted out, pm for response!
- Oil Pressure
- Crankcase pres.
- Fuel Pump pres.
- Exhaust Back pres.
- Coolant pres.
- Oil temp
- Motec Interface
- Clutch pres.
- Manifold Boost pres.
- 3 Ft Vneck
- 10 Ft vneck
- 4 EGT
- Air to Fuel
- V300 SD
G Force gear set for sale. 10 passes. Needs a new ring gear and could use a new 2nd gear, dogs are worn. Comes with both a 1.35 and 1.40 third gear set, both in perfect condition, just tried both ratios. Ran 8.38 on this set. 4.30 FD ratio, 1.04 4th I think it is. Perfect ratios for 26's, easy change for 24's since the ring gear needs replaced.
$2900
Email me for questions. Tony at t1racedevelopment.com
$2900
FS: Precision 6265 billet wheel brand new compressor cover (non anti surge)new 81 ar turbine housing with v band discharge. center section is painted black(for no rust) and comes with -10 oil drain flange and fitting welded. Less than 2500 miles on it.
FS: 2 used tial black q valves with o-rings, clamps, banjo, aluminum flange(perfect working order) $150. each
Pm if interested.
will email or text good pics.
Pm if interested.
[car was never ran on the dyno with them, just put on the dyno for pictures, look no straps]
These are legit Ray's Volk TE 37s all the way around. Chrome rays mackin imported stickers inside the wheels.
13" in the front on Micky Thompson 24.5 slicks
16" in the back with kumos
Bronze in color, very light weight forged wheels, felt great at the track, good condition, outside stickers are even still mint, one handed tire changes. Rays threaded valve stems.
I hate to see them go as these were very hard to come by, but I have 6 star 8s for this season and they are just sitting on the shelf.
These would cost over $3k new with tires with a long wait to even get them.
$1250
RARE Carbon fiber dash, great condition, with autometer carbon gauges pictured. Shown in a EG, should fit most other hondas.
$450, gauges cost more than that, I'm pretty much giving it away at this price.
Brand new comp stage 4 clutch for a d series, still in box, best offer
Several b series vtec and non vtec heads in stock.
NRG Magic stix/BC stg 3 b series cams. Best offer.
Thanks for your business and time,
DK
Full Race K-Series divided housing manifold. Brand new, never run or installed - 1250 + shipping
BEP S372 1.25 AR Fully polished comp housing, coated turbine housing. Just received back from BEP for a fresh and complete rebuild. As new and never installed. 900 + shipping.
DSS B series Pro level set of axles for sale, WITH spool, with brakes and spindles
Brakes include OEM calipers and new pads and rotors (5 passes).
$2000 complete
Paypal accepted, shipping is extra. About $180 for everything.
Everything is located in NY!!
$2000 complete
Hey guys, got an almost brand new Competition Clutch Super Single for the K Series up for sale! The clutch has only been installed for 100 miles. Need to get rid of it so the price is in your favor! PM me for any questions! pics below! Looking for $500 plus shipping!
I have decided to part out my civic ls/vtec turbo setup. Everything listed only has about 10 hours dyno time and 10 1/8 mile passes. Everything is in working order and looks almost new. Most come with orginal boxes. Will post more as i think of it all. You may call or text me at (423) 838-5534 with any questions thanks. (Please no international calls or texts! PM ONLY!) Shipping price is different depending on item, prefer not to ship large items. Add 3% for paypal! Text or pm any questions or for more pics.
$275 (2) Tial 44mm mvs wastegates. They are red and come with all springs $275 each
$200 Tial 50mm BOV red
$300 Avid Pro Series motor mounts solid billet no urethane for b-series into 92-95 civic
$800 Competition Clutch twin disc stage C w/flywheel for b-series hydro transmission
$1250 Weld Magnum skinnies 15x3.5 black and chrome with mh 24x3.6x15 tires only 3 passes
$200 Golden eagle main girdle
$50 Arp main studs for girdle torqued 1 time
$75 PTP turbo blanket large
$75 Aluminum radiator with slim fan
$50 Type R water pump
FS: Built ERL Long Block $4400 + shipping
http://hondamarketplace.com/showthread.php?t=3088808
Dual Back door intercooler for EG $650+shipping
http://hondamarketplace.com/showthread.php?t=3074626
