Sept FS Thread
Old Sep 14, 2011 | 10:36 PM
  #76
94 ls teg's Avatar
Default Re: Sept FS Thread
Turbo b16 part out.. Going k series
EVERY THING IS WITH OUT SHIPING
Located 18954
Motor was put in the car never started got a great deal on a k swap
Will do whole long block for 1350 comes with a cosmetic headgasket and arp head studs
~Block 800obo
Jdm B16 block bored .20 over
Cp piston 11.0.1 part number sc7111
Eagle rods
Acl bearings
Oem water pump , oil pump and timing belt
Moroso oil pan with oil drain fitting
Head 700obo with cams 550obo no cams
~Jdm B16
Supertech valves
Supertech springs
Supertech retainers
Brand new oem valve seals
Type r cams
Skunk2 camgears
~B16 valve cover powered coated granny smith pearl green 140
~Arp headstuds tourkked once 90
~New edelbrock victor x intake manifold with golden eagle gasket 250
~Blox 68mm throttle body comes with tps and p2r gasket 150
~Golden eagle fuel rail 75
~Precision 680 injectors 150
~Trans
Gsr has vin plate with a mfactory lsd has a weird problem with 2nd gear it gives a little trouble if u down shift in to 2nd but not when ur going through the gears. Never bothered me. No other problems. 800obo
Turbo stuff
~~Will do turbo, wastegate,manifold and down pipe 1400obo
~Full race ram horn manifold t3 with 38 mvs v band wastegate and full race 4 bolt down pipe 700
~Precision 6262 with 83 ext housing (4 bolt) 600
~Tial 38 mvs wastegate (blue) 175
~~Will do bov, piping and intercooler for 500obo
~Tial 50mm q bov (silver) 200 no flange
~Intercooler piping with all clamps and couplers tial 50mm flange 150obo
~Percision 650 intercooler 250obo
~Hondata S300 p28 with boost by gear sol. 550
EVERY THING IS WITH OUT SHIPPING
Would like the big stuff picked up
thanks chris
I have more pics
Old Sep 15, 2011 | 08:10 AM
  #77
justnprsh07's Avatar
Looking to go back allmotor so really looking to trade...
chassi
93 dx hatchback,custom front bumper,carbon lip ,carbon hood,carbon roof,10 point cage, momo steering wheel, kirkey drag seat, itr door panels, custom cantilever rear suspension, skunk2 pro s front struts, skunk2 upper and lower control arms, skunk2 upper and lower front and real strut bars, energy suspension bushing kit, weld magnum 15x10 with mt 26s, lenso skinnies w/ mt tires, drilled and slotted rotors all the way around, heavily reduced on weight, car is setup for sfwd as it still has all front interior and glass windows.
power plant
h22a1, darton sleeved, kaizen balance shaft eliminator, crower pro rods, wiseco 88mm 10:1, ported head, stock valves, crower valve springs and retainers, skunk2 pro1 cams, aem gears, golden eagle intake make ported, 3in ic piping, 74mm str tb, 3in ic piping, turbonetics bov, 1000hp custom precision l2a intercooler setup, precision 6765 t4 .96ar turbo, custom forward facing turbo mani, precision 46mm wg, arp head studs, arp main studs, arp oilpan studs, new oem timing belt, new starter and alternator, zex nitrious kit
fuel and ignition
dual bosh 044, custom tank, 10an feed, 8an return bosh 1600s injectors, fjo injector driver,str fuel rail, mallory fpr, aeromotive filters, msd sci box and coil, msd wires, hondata s300, aem 5bar map, aem wideband, autometer oil boost and temp guages,
drivetrain
h22 trans, saenz straight cutt gear set, carbon syncros, quafe lsd, comp twin disc, dss 5.9s axles hubs and half shaft, omni power clutch master cyl, arp wheel studs
prob missed somethings being there is so much done... ill look it over tonight and repost some missed things. Car runs and drives better now that it ever has and i will prove it when needed!!!
note that this picture is before precison 1000hp l2a
will provide more pics as needed
Old Sep 15, 2011 | 09:16 AM
  #78
TDautowerkes's Avatar
Up for sale are 2 turbos for the price of 1!! We have a GT4572(PTE7280) and GT4576 with 2 T4 divided back housings. The compressor wheels are independently balanced so changing from one to the other is easy.
Whats Included:
-Precision 72mm wheel, back plate, and compressor cover with fresh black powder coating.
-Precision 76mm compressor wheel, back plate, compressor cover and lock nut.
-GT45 cartridge
-1.28 back housing (new)
-1.12 back housing
Everything pictured for only $3000 shipped anywhere in the continental US!!
Old Sep 15, 2011 | 07:00 PM
  #79
tenthelementracing.com's Avatar
For Sale:
New, Never Installed, AFI Fuel Rail for a K Series. $100 plus shipping.
pm me if interested.
Old Sep 16, 2011 | 07:43 AM
  #80
acrite1999's Avatar
The time has come to move on to another project and I have decided to let go of my integra...its a 95 acura integra rs shell clean title..super sonic blue.comes with 10pt roll cage,bride seats,simpson chute,exospeed wide body,carbon fiber trunk...car weighed in on boost 2410 with me in it...car cutts 1.60-1.65 consistent and has a personal best of 9.6@158mph making 780hp...car is proven already and needs a good home..if intrested u can reach me at 305 281 6495...car is located in miami fl..$5500
Old Sep 16, 2011 | 09:21 AM
  #81
GT40eg's Avatar
k-pro for sale $875 shipped
pnf ecu/ call or text for faster response and or pics. 443-962-0628
Old Sep 16, 2011 | 10:50 AM
  #82
92redhatch's Avatar
Selling an act 4puck sprung clutch with pressure plate and factory flywheel I want $300 (305)409-5776
I made 522whp and 327trq on Td Autowerkes dyno. Clutch has less then 2000miles and less then 10 passes at the 1/8
Old Sep 16, 2011 | 06:12 PM
  #83
adam1027's Avatar
TCI spool for gsr transmission for liberty final drive $225 obo areomotive a1000 fuel pump,good for 800hp $175 ,4 precision low impedance injectors 740cc $150. MSD pro billet distributor part#8488 with sc coil driver part# 8235 and wires, and connector for installation used on dyno only $350 obo.all parts for gsr, prices don't include shipping pm me for more info
Old Sep 17, 2011 | 11:57 AM
  #84
01DC4's Avatar
BNIB Edelbrock 75mm Mustang ThrottleBody with TPS, and Honda Adapter, New ARP Hardware, $280 Shipped
BNIB Omni Power, GM Style 4 BAR MAP Sensor, With Pigtail, $60 Shipped
Old Sep 18, 2011 | 11:49 AM
  #85
Do-Work's Avatar
I have a set of Je pistons 9.5.1comp 84.5mm & Eagle H-beam rods w/ ARP rod bolts up forsale, used but in working order came out of a GSR $400
Fidanza 7.5lb B series flywheel -$60
Cable Ls tranny coverted to work as hydro -$200
XTD stage-3 B series sprung 6puck clutch w/ heavy duty pressure plate 600miles on it -$100
Half size radiator w/slim fan -$70
Endyne TypeR modified oil pump -$120
B16 4.4 stock final drive shaft and ring -$100
Old Sep 18, 2011 | 04:29 PM
  #86
cotorresgee's Avatar
selling b-series competition clutch stage 2 kit with ACT streetlite chromoly lightened flywheel plenty of life on clutch, disk and flywheel left...asking $450 obo for kit or $250 obo for flywheel or $200 obo for clutch...thanks
Some pics:
Old Sep 18, 2011 | 09:14 PM
  #87
sc34dx's Avatar
Well time has come to part out my car...I built it last year hoping for 11s ran 10s then i refreshed the motor this year to try and run 9s but money got tight and i no longer have time to race...so got to sell it..Parting out entire car...at this time not parting out package deals...
Rolling Shell...$2500
1993 Honda Civic Hatch
Full 10pt Cage done by Fast Forward Race Cars
Never Used Stroud Parachute with cable and bracket
Momo Hub and Steering Wheel
5pt Hci Harness
10k PIC front coilovers
18k Blox Drag rear coilovers
Blox front upper camber arms
Blox rear lower control arms
Steel braided brake lines all around
Gsr rear disk
Front comes with just cx spindles no front brakes, had Gsr's with Dss 5.9 axles but sold
Trunk Mounted battery box with cables for battery
full front interior, dash has only Autometer tach with custom shift light and gauge bezle
-Clean title no rust some dings and dents but nothing major could use paint, currently flat black, no seats and no hood will come with wheels to roll on..Cage is ready to be certified for 8.50s
ENGINE...$3800
Benson Sleeved 81mm Gsr
Manley Turbo Tuff rods
Acl Race Bearings
CP 9:1 comp pistons with upgraded wrist pins
Cometic 81mm head gasket
New Oem Water pump
New Oem Oil pump
New Oem Belt
Fluidamper Crank Pully
ITR stock port head
New Oem Valve guides
Supertech Springs
Supertech Valves
Supertech Retainers
Skunk2 Pro 1 cams with BDL cam gears
Blox oil sandwich adapter
Arp Head studs
-ran motor for one year and blew the head gasket, then in the winter i refreshed it with all new bearings and rings and $1200 in machine work Motor was built by Armando at ILL Garage, always ran Brad Pen Oil changed every event...WILL NOT PART MOTOR OUT
Turbo Kit...$3000
Custom Bottom mount T4 manifold made by James at BMC
Bullseye S366xl turbo
Precision 46mm wastegate
Precision 800hp intercooler
Tial Bov
Stainless Steel Powder coated black 3inch piping
Vibrant couplers and vbands
OIL feed line
OIL return line
4inch down pipe with turn down
Aem 3.5 bar map sensor
Aem boost solenoid
-Everything has about 200 miles on it and all the manifold and turbo parts have been JetHOT coated and all Pneumatic lines and push quick fittings will be included
Fuel System..$800
Golden Eagle black fuel rail
Injector Dynamic 1000cc injectors with clips
-8 Black nylon braided feed line
-6 Black nylon braided return line
Aeromotive fuel filter with fittings
Aeromotive fuel pressure regulator
Bosh 044 fuel pump
-Everything again has about 200 miles on it and was used on my Sumped stock location gas tank
AEM EMS V2...$800
K-tuned Traction bar...$150
CR racing Radiator with -16 braided hoses with welded fittings on engine side and custom fan shroud and fan....$300
Innovative motor mounts...$150
Blox 68mm throttle body...$100
Custom Ill Garage Catch can with lines and Powder coated Gold Valve cover...$300
Competition Twin disk used for 2 seasons....$700
White 13ich V2 drag wheels with 24.5x9x13 M/T slicks used half a season...$600
Halman manual boost controler...$100
Shipping NOT included and would rather sell Local BUT will ship and i take Paypal
Im located in CHICAGO SUBURBS....
PICS and a Quick Vid..
http://www.youtube.com/watch?v=aLhbJsls_WU
Old Sep 19, 2011 | 04:56 AM
  #88
lugnuts's Avatar
FS: Turbine housing - Precision 67/65 .81 T4 - From a brand new turbo that was started and running for 10 minutes. Hardware included. $200 neg.
Kevin
Lugnuts9@msn.com
Old Sep 19, 2011 | 10:07 AM
  #89
speedtec11s's Avatar
I am selling the following:
1 used greddy type s blow off valve with gasket. $150
1 used drag generation 2 intercooler: $125
1 used (for 1 race event) autometer pro comp 5" monster tach with shift light. It has a large shift lite, not pictured and features 11k rpm range, and memory recall. I paid $330 on summit, and am selling for $230
Old Sep 19, 2011 | 12:53 PM
  #90
rota92
Guest
Posts: n/a
PM's shutdown by GDD warlords, please email me! AFAPracing AT yahoodotcom
PPG B-series Gearset - 4.6 or 4.4, you choose! PM me for details
40' Wells Cargo Fifth wheel with 16k Hitch. - 8000
92 Hot-Rod roller - 12000
Trying to test waters on moving some other items off the chassis that are more universal lol
Franks Fiberglass front end with tree - 650
Modified 3 gallon fuel cell - 100 (I have fittings galore for this, we can get it setup best for you)
TAG Handheld weather station - 250
Electronics:
• AEM Serial - Custom fuel pressure gauge to read higher pressure (above 200 psi) – 250 (Also reads 5 other channels all in one unit)
• 2- AEM Water/Oil temp gauge – 175
• AEM UEGO sensor (external) (Reads low enough for methanol) – 160
• ARC electronics Switch panel w/firewall mounted panel - 300
• 128 pin cannon plug w/1 backshell and pins - 250
Universal Parts:
• Weld Magnum fronts 15 x 10. 4” backspace, 5 x 4 ¾ bolt pattern. (Chevy) Used 28 x 10.5” tires on them
• Safecraft Fire suppression system
• 2 550lb springs and 2 450lb springs. 2.5x8” – 100 a set shipped
• Kinsler K-140 Fuel Pressure Regulator - 350
• Kinsler monster mesh fuel filter -12 in/out - 125
HANS Device - 750 shipped. BRAND NEW. Medium 20 degree layback unit. Has QR tethers already.
HOSE/FITTING Inventory:
-8:
Straight - 1
45* - 1
90* - 2
120* - 2
-10:
Straight - 2
45* - 1
Reducers 10 --> 8 (Qty. 2)
I think there is a misc -6 90*, straight, and maybe 3 feet of new line as well.
Old Sep 19, 2011 | 04:31 PM
  #91
JDM JEFFREY's Avatar
B hydro dss 2.9 axles
Used for 4 passes 450.00 + shipping
Old Sep 19, 2011 | 08:18 PM
  #92
FaceTuned's Avatar
Means of contact:
Phone: 253-224-1792
E-Mail: Tony@facetuned
Payments:
local pickup, over the phone visa, Master card etc..
Paypal add 3% for all paypal fees verified buyers only etc..
First up all items are best offer except turbo
Precision sc61, T3 Ar.63 E cover, Minor chip on compressor wheel, has a little shaft play but nothing to major, still makes boost just fine. 350$ Plus shipping
Aem 30-1000 Engine management system,for any Obd-1 honda, SOLD
Walbro gss 342, 92-00 Civic or Integra,BNIB 95$ Shipped
D16Y8/7 ARP HEADSTUDS BNIB $110 SHIPPED
AEM TRU BOOST, has harness it just needs solenoid, 150$ obo.
CHIPPED P28 WITH CN2 PORT READY TO DATALOG
COMES WITH CUSTOM BASE MAP FOR YOU APP.
I HAVE 5 IN STOCK! $150 SHIPPED EACH
OBD1 GSR distributor $120 shipped
OBD0 LS / B16 distributor $100 shipped
give me a call or send an e-mail
were open 9:30am to 5:30 pm Monday - Friday
Old Sep 20, 2011 | 06:33 AM
  #93
Ovrbst_T66's Avatar
EDIT: you can fix this when you have pics available.
Old Sep 20, 2011 | 07:32 AM
  #94
ricky tan's Avatar
EDIT: PLEASE READ THE RULES OF THIS THREAD
Old Sep 21, 2011 | 10:15 AM
  #95
kte324's Avatar
I have for sale a Laskey Racing Built & Assembled block. More info and pictures of the build can be found here: http://www.hondamarketplace.com/show....php?t=2950014
Price: $2500 or best offer + shipping. Pm for more pictures or info about the block. I will also take the oil pan off for more pics if needed. Includes everything pictured.
B16A2 84mm Benson Sleeved
- 9.1:1 CP Pistons
- Pauter Rods
- Acl Race Bearings
- Arp Head Studs
- GE Oil Squirter Plugs
- Moroso Oil Pan
- Gates Blue Racing Timing Belt
- Oem Water & Oil Pump
- Oem Crank Pulley
**Click on pictures to expand**
Old Sep 21, 2011 | 01:44 PM
  #96
acrite1999's Avatar
The time has come again and im moving on to another project and everything must go..if anyone is interested u can reach me at 305 281 6495..all parts are in excellent working condition..
solid hasport dc/eg mounts-400
hybrid racing shifter-320 sold
dss 5.9 axles with hubs etc-1300
type s cables(Perfect)- 160
afi intake manifold with q45 TB- 1100
competition twin (C) bnib-1100
eagle long rod combo with 10:1 je pistons(needs one piston)-530
blox drag suspension-600
built complete a2 head all ferrea and z1 cams with gears-1200
id2000- 720
hybrid rail gold-120
weldon 2035-650
(900hp)turbo kit-4200
fabworx manifold
pt 6765 ported h cover
2 tial wastegates
custom downpipe
custom dump tubes
1000hp intercooler
tial bov
custom polish piping
oilpan
oil feed
oil return
all t bolt clamps
all couplins
i have more things to list just cant remember at the moment,if theres anything that u need and i might have dont hesitate to ask..
all pics are uploading threw photobucket and then pics will be up
Old Sep 21, 2011 | 05:29 PM
  #97
b18c1Monster's Avatar
Edelbrock victor x intake manifold for b16/itr head. $240
Supertech valve springs and titanium retainers(h100dr) mint only used on dyno. $200
Omnipower 70mm throttlebody. $80
Skunk 2 tuner 3 cams mint condition. Comes with jg cam gears $425
BDL fuel rail $80
1000cc FIC injectors. Mint only used on dyno $260
Sleeved 83mm b18c5 block with crank and main caps. $750
Hondata 4 bar map sensor. $75
Fluidampr crank pulley. $200
Old Sep 22, 2011 | 04:40 AM
  #98
vavoom's Avatar
Aem ems 1000 for sale asking 700.00 or best offer.
Old Sep 22, 2011 | 03:10 PM
  #99
denske's Avatar
FS: i have a Precision 6262s billet turbo for sale, t3, journal bearing, .82 AR, with 3" vband flange welded to turbine housing. never used, only mounted during fabrication. need cash, my loss is your gain. looking for 800 shipped obo. pm me, thanks.
Old Sep 23, 2011 | 04:46 AM
  #100
Ovrbst_T66's Avatar
Turbonetics t4 t66 bb $400,has upgraded compressor wheel, backing plate and bearing 2 years ago.
