Sept FS Thread
ALL MOTOR LSVTEC Forsale
b18 Block AEBS SLeeves,Endyn Pistons, Eagle Rods,LS crank
b16 RLZ CNC PORTED RACE HEAD RLZ Springs,TI Retainers, Ferrea Valves
Skunk Tuner 3 Cams
Edelbrock Intake Manifold And Fuel Rail. RC 440's BBK 70mm T body, AEM cam Gears, Golden Eagle Lsvtec Kit
Comp Clutch stage 5? i think.. Complete Long Block.
Fully Built ! All Work Done By RLZ, Less then 100 Miles, Ready to Go ! Made 255 On E85
Asking Price $4200
GSR Trans For Sale With Libertys Face Plated Gears and Liberty Hand Cuff,Wave Trac LSD. Complete Trans Fully assembled Ready to go. Has 2 Passes
Asking $1800 Firm
Circuit Werx Ring and Pinion Brand New (GSR Final)
$400
SLS B series T4 Top Mount With 4inch Dp and Dump tube with tail 44WG
$1400
[IMG]
[/IMG]
[IMG]
IMG]
[IMG]
[/IMG]
Skunk Tuner 3 Cams
Asking Price $4200
Asking $1800 Firm
$400
$1400
[IMG]
[/IMG][IMG]
IMG]
[IMG]
[/IMG]
Custom dual backdoor intercooler. Supposedly a Garrett core, and is used but in good working condition. Has a few dents and dings, but was told it is in perfect working order. Overall dimensions are 35"x13"x3.5" (core is 24"). 3" inlets/outlets
$350 (+shipping/paypal)
Weld Magnum, essentially brand new. Alot of money in these wheels, centers are BRAND NEW from Weld, and the barrels were professionally polished by CCW. They are assembled with ARP bolts (~$150 worth of hardware on these). Never used since restoring them. They are absolutely FLAWLESS
15x10" 6" backspace
15x3.5" 1.13" backspace
$1600 (+shipping/paypal) OBO not 100% set on selling these, but will for the right price.. NOT SEPARATING THE SET
(wheels are now all assembled correctly according to weld. 25ft/lbs, with red loctite)
Brand new skunk2 70mm throttle body
$250 (+shipping/paypal)
15x10" 6" backspace
1996 midori green hatch cleanest original car you will find, jim justice built h22 turbo ,built h tranny ,dds axels,mw pro14 ,5 lug,aem sereis 2 ems,rywire milspec harnes,,t1 c.o.p setup with harness ,peterson external oil pump ,ferrea roller cams, blah blah blah almost all brand new nothing wrong with anything lost interest and dont want to finish it need to put the t1 c.o.p and harness in and be on your way i took the old aem c.o.p and ems out and bought new XXXXX or will seperate but i have to sell the drivetrain or shell first !!! could also sell everything i have for hondas( trannys,harnesses,rims/tires slicks/bogarts extra h22 roller cams etc) and a 2010 open car trailer with box and 9000 pd super winch for $15,000
CAR IS NOW BEING PARTED OUT PM ME WITH NEEDS I WILL PUT A LIST UP IN A DAY OR SO
CAR IS NOW RUNNING AND WILL BE AT WILL BE AT ENGLISHTOWN FOR THE FALL NATIONALS SO YOU CAN HEAR IT RUNNING
Brand new BMC Intake Manifold, dual injector, 6 liter plen. Asking $1200
Brand new M800 for logging, lambda and advanced tuning options $5000
Brand new M&W Pro drag 4 with harness and denso coils, $1000 (sold)
CELL 646 739 9291
EMAIL FRANCHISE2986@AOL.COM
PAYPAL FRANCHISE2986@AOL.COM
ALL PURCHASES MUST INCLUDE PAYPAL FEE 3% I WILL POST WHAT EVER PICS
I HAVE IF U NEED BETTER PICS ILL TRY N MAKE IT HAPPEN THANKS
RACE CAR SALE:: sollllldddddddddd
CHASIS SHELL RACE READY NHRA CERT INCLUDES 10/2012 EXPIRES
92 CIVIC CX SHELL CLEAN TITLE SOLLLLLDDDDDDD
PARTS::
VICTOR X INTAKE MANIFOLD W/HONDATA GASKET $250
B16 HEAD BUILT:
*NEW SUPERTECH VALVE SPRINGS
*NEW SUPERTECH VALVES REVISE ECONNEL EXHAUST VALVES $1600 EVERYTHING
*NEW SUPERTECH RETAINERS
*NEW VALVE SEALS
*BRIAN CROWER 402A CAMS
*RED GOLDEN EAGLE CAM GEARS
BACK UP HEAD B16 BONE STOCK NEVER MILLED $350
SHORTBLOCK:
*GOLDEN EAGLE HD SLEEVES
*PAUTER RODS
*LS CRANK
*CP 9.7 PISTONS 84.5MM .5-.6 P2W
*ACL RACE BEARING $3200
*ATI RACE DAMPNER
*NEW OIL PUMP ALL SEALS NEW
*NEW T BELT AND WATER PUMP
MOTOR SEEN THE TRACK 2 4HITS ALL TRAPS OVER 150 @28LBS
865HP @571 FTLB MILLER TUNED DYNO JET
A100 FUELPUMP W/AEROM
100MICRON FUEL FILTER
AEROMOTIVE REGULATOR -10 FROM TANK TO FILTER $450
-8 FROM PUMP TO RAIL TO REGULATOR
GOLDEN EAGLE FUEL RAIL INCLUDED
PRECISION 1600INJ CLEANED AND FLOWED EVERY SEASON $300
SIMSPON PARACHUTE NEVER PULLE SOOOLLLD
TIAL 50MM BOV sollld
GARRET CORE 24X12X4.5 3IN DOESNT LEAK IT HAD AN REPAIR sollddd
PRICED TO SELL
K TUNED TRACTION BAR SOLLLLDDD
EBAY RADIATOR WITH FAN AND CHROME OVERFLOW TANK AND HOSES soldddd
AVID PRO BILLET MOUNT $350
W/AVID TORQUE MOUNTS
AUTOMETER VOLT GAUGE BNIB $20
AEM UGO WIDE BAND EVERYTHING INCLUDED SOOLLLDDD
SCATTER SHEILD ALL THERE CUT A PIECE SOLD AS IS SOLDD
ARIAS BNIB 84.5MM PISTON W RINGS ANDWRIST PINS $300
WRIST PIN LOCKS FELL OUT OF BOX PRICED TO SELL
15LB NITROUS BOTTLE SOLDDD
SET OF BOSCH INJ FOR S2000 CC SIZE UNKNOWN $60 BUCKS THERE YOURS
AUTOMETER WATER TEMP GAUGE W/ SENDER $40
AUTOMETER OIL PRESSURE GAUGE W/STEEL BRAIDED LINE -3 $60
AUTOMETER BOOST GAUGE 30LBS soldddd
M FACTORT PRO SERIES GEAR SET 1-4 2 HITS AT THE TRACK
$2500 PAID MORE
M FACTORY PRO FINAL DRIVE 4.05 B16/LS $500
LIBERTY CUFF SOME SCARING FROM STOCK TRANNY BLOW UPS $80 BUCKKS
OBX DIFF B16/B18 USED 1 STRIPPED FINAL DRIVE BOLT MY **** UP $200
NHRA RACE GEAR THE REAL ****
GLOVES
NECK BRACE
SHOES SZ 12
PANTS 2XL
JACKET 2XL SPENT CLOSE TO 600 $350 USED FOR 2 SEASONS
SPARK PLUG COVER ALUMINUM GREAT FOR POWDER COATING $ 40 BUCKS
T1 Web B-series Pro Series Cams w/Extended Rocker Pads and T1 Billet Vtec Block Off Plate. Brand new, never used. $2300.00 shipped firm.
Bogart R/T 4 Spoke 15x11" wheels w/4.5" BS brand new. Double bead lock option with ultra light weight rings on bead locks (saves about 1 lb per wheel). Comes with brand new M/T 26x10" slicks mounted and balanced, ready to race. $2000.00 firm. Only front wheels/tires, no skinnies included. Waited 4 months to have custom made, . These will clear the factory knuckle with no grinding/shaving.
Co2 300 cubic inch fill tank (can be filled at any welding gas distribution center), transfer tube (to refill 5 lb bottles), (2) 5 lb Co2 bottles, billet roll cage mount for 5 lb bottle, Co2 auto shut off valve (wire into ignition so you never have to shut off co2 bottle in car) and 85 psi and 100 psi pre set regulators. Selling everything together and complete for some one looking to run co2 for boost controller. I have over $850.00 invested into everything, looking to get $500.00 firm. The items would need to be pick-up only, the 300+ cubic inch tank cannot be shipped.
FOR SALE:
1)Garrett Gt3076R Ball bearing Turbo....Low Mileage...Minty Fresh...comes with oil fittings and coolant fittings...$950 Shipped.
2)Back door intercooler painted black....24X12X2.5...$100 bucks plus shipping
3)Blitz Turbo Timer...70 shipped
4)Blitz Blow off valve attached to 2.5 metal pipe with flange....$100 shipped
5)Skunk2 Intake manifold for a D16....gasket matched on head side and TB is ported out for BLOX 76mm TB....$150 plus shipping for manifold...$300 shipped for Manifold and
6)Autometer C2 Electronic boost gauge...$80 Shipped
7)Autometer C2 Electronic Fuel Pressure gauge...$50 bucks(needs sensor)
8)GM 3 Bar Map sensor....$65 shipped
9) ARP D16z6 Head studs...$90 shipped BNIB...SOLD
10)95 civic Energy Shifter Bushings...$30 shipped BNIB
11)D16z6 Canton Oil Pan...$120 Shipped
12)ARP D16 Flywheel Bolts...$50 Shipped BNIB
12)ARP D16 Pressure Plate Bolts...$25 shipped BNIB
BNIB: Bullseye Power S372R Turbo. $1,300obo. I will throw in a free downpipe clamp with the purchase.
specs on turbo: 71.8mm inducer and 101.8mm exducer on the compressor side. 83.4mm inducer and 73.4mm exducer on the exhaust side. T4 divided, 1.10 A/R, 3" outlet discharge and 4" on the downpipe/exhaust side. has a polished race cover and high temp. coated exhaust housing. Everything is brand new! let me know,Surge 831 359 0477.
Wiseco 85mm 13-2 to 14-2 compression pistons with rings. Eagle LS rods with arp s2000 rod bolts. Piston and rods are NEW!!!! They where installed and then removed. $450 will part out.
98 type-r head(virgin). With r-cams or crower401 cams. Everything but, No intake manifold, dis, or solenoid. $500 obo.
PRICE DROP!!!!!
few things for sale.. paypal fees and shipping not included.. pm me if interested
Up first is a SLS ramhorn 3"down pipe combo (brand new, never ran just test fitted)..
Its made for a tial or precision vband housing turbo, and a 44mm wastegate..
900.00 obo
Also selling an h22 manifold and 3"downpipe combo, t4 60mm wastegate..
800.00 obo
These are a set of bogart racing wheels with 4.5 inch or 114.3mm lug pattern to fit accords, preludes and any other vehicle that uses this patter. Fronts are 13x8.5 and rears are 15x4. Wheels are in perfect condition. Tires are not included...
$750.00 obo
__________________
900.00 obo
800.00 obo
$750.00 obo
__________________
Got for sale brand NEW IN THE BOX parts. Prices are best offer and buyer pays shipping.
Percy's racing lexan window kit for 96-00 honda civic hatch. this is the deluxe model that has the borders around the window for the stock look. this is a pnp kit no cutting needed, comes with all hardware and gasket for install $1000
Rci Fuel Cell, Drag Race Cell; Size 6 x 6 x 12; 1 Gallon $70
Waterman racing in-line fuel filters got 9 of them 5 -8 filters and 4 -6 filters $65 each
gm 3bar map $40
Skat 92mm crank New New New $450
Eagle Ls rods $250
Cp 81.5 mm 12.5:1 $275
Skat Ls Rods $200
Supertech spring/reainers Bseries $190
Autometer Ultra Lite Pro Comp II, 0-11,000 rpm,with Shift Light/Memory $250
bosh 1600cc white top injectors (6) needs to get machined or fuel rail drilled out. $350
USED PARTS
STR 70mm TB with tps and map $200
Skunk2 pro gsr intake $150
Eagle LS Rod with CP 9.0:1 81.5 used but in good condi $300
obd2a-obd1 step down harness
Vibrant 4" muffler $80
Skunk2 Front camber 94-00 integ and 92-95 civic $100 Sold
thermal 3" catback exhaust for 94-00 integ $300
Beak Rear Tie Bar for Integ $125
kyb Agx with H&R sport drop $160
type r front and rear lower sway bar (rear 23mm and front 25mm) $200
open to trades.
pm me for pics
gm 3bar map $40
Eagle Ls rods $250
Skat Ls Rods $200
USED PARTS
open to trades.
pm me for pics
for sale or trade. liberty final drive and pinion 4.7 20 passes on them LSD NOT INCLUDED . Will trade for 4.4 set. 750 obo plus shipping and paypal. BNIB gsr arp main stud kit 70.00.
FS Precision 6265 billet ceramic ball bearing. turbo was just at precision and had a new center section and exhaust wheel replaced under warranty. since then it has about 10 passes on it. i have 2 exhaust housings for it to choose from. T3 .82 w/ 3in vband flange welded on it, and a T4.96 housing. i also have a brand new compressor housing for it, with some small blemishes in the casting. asking $1200 plus shipping.
FS Tial 44mm wastegate(silver one) no fire ring or clamps. has brand new diaphragm and valve. $275
NRG Innovations FiberGlass Bucket Seats with brackets for 96+ Civic Brand New -$500
GSR Shift Linkage With Urethane Bushings- $150
3.5" Aluminum Exhaust With Vibrant Race Muffler With V Bands-$650 Prefer Local Pickup
Quaife LSD For B16\LS -$650
Hasport 94A Extreme Race Urethane Inserts For EK Mounts (pretty sure they will fit others)- $50
All prices do not include shipping or paypal
PM or Email for pics or with questions Juice2435@aol.com
1) 85mm Type R(B18C) shortblock. Has Golden Eagle 85mm sleeves, CP 9.5:1 pistons, Manley Turbo Tuff rods, brand new GE headstuds and an ATI fluidamper. This is an o-ringed block and I have already installed new copper from GE. This block will also include factory tapped oil pan, pick-up and windage tray. EVERYTHING on this block is in excellant condition and was built by James Innes of IPG. ASKING $1600.00 SHIPPED
2) 2000 Integra GSR head. This head is in great shape and ready to go on a block. The head has Supertech Valves, Crower springs and retainers. I also have a GE cam seal and GE thermal intake gasket to go along with it. I have ALL the top end gaskets from acura still in the packaging that I will also include. This does NOT come with a valve cover, cams or cam gears and dist. ASKING $600.00 SHIPPED
3) Golden Eagle 85mm Headgasket....brand new/never used. ASKING $75.00 SHIPPED
4) Brand new JG/Edelbrock Victor X Intake manifold. stillin orgiginal packaging and includes all hardware and gaskets still in the package. ASKING $230.00 SHIPPED
5) Brand new in the box Skunk2 70mm TB. part # 309-05-0050. ASKING $210.00 SHIPPED
6) Used BLD fuel rail with marshall liquid fuel pressure gauge. ASKING $85.00 SHIPPED
FOR SALE: does not include shipping and paypal fees...
*2x- 5inch autometer tachs/ without shift lights-$50 each
*1x- str intake manifold (gsr) -$200
*1x- brand new air/air intercooler-$200
*1x- used nos bottle -$100
*1x- used pr3-3 head without cams -$300
*1x- bnib supertech valves (hevn-200f & hivn-200f) -$200
*1x- used gt4294 turbo with 128 ex. housing -$850
*1x- brand new quaife diff (gsr) its been installed into gsr tranny, never used. -$700
I'm selling a set of classic 14" Bogart Fly-Star Racing Wheels 5x114.3
5" backspacing, 9" wide
Price is $250 shipped
Also selling a Wilwood 3/4" bore Master Cylinder Kit w/ Remote Reservoir
Can be used as Clutch Master Cylinder or for a Brake Booster Delete
Kit is brand new, package was opened only to test fit
Asking price $60 shipped
Also have an Autometer Pro-Comp Liquid-Filled Mechanical Oil Pressure Gauge
Gauge is band new, it is 2 5/8in and 0-200psi
Email me @ LivinDreams.DC5@gmail.com for a quick response
Looking to get out of game for a little bit to persue other interests so the All Motor beast must go..would like to go to good home
Brief info
best e.t 10.58@129mph
Allen Built (Inline Pro) stroked k20
Custom piston & rod with k24 crank
Allen Built (Inline Pro) race ported k20 head with Drag Cartel cams
Excessive ported intake manifold with v-stack's using 90mm mustang throttle body and much more
like i said thats just a little brief summary all work and install done by Inline Pro and tuned by Brian Fisher, car is crazy fast and has run up against the best all motor cars in the states and has bee very competitve with the right driver... would like to sell complete or willing to sell just complete motor...
Car currently has a blown 2nd gear and selling as is with out hondata k-pro but will supply the tune used, or can work a deal for everything
$11,500
can not build this car for this price
Not looking for trade's but for the right price will sell complete swap
Serious inquires only
Brief info
$11,500
