Sept FS Thread
Old Sep 1, 2011 | 12:28 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Sept FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for
RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 1-1-2010, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Sep 1, 2011 | 12:56 PM
kingofbattle909's Avatar
Default Re: Sept FS Thread
Suup Honda Tech... Im done. I will EMAIL pics upon Req. Heres whats for sale:
***F23 Block w/ maincaps..bored to 87mm.and honed. could use a fresh hone due to light rust spots. line bored +.25, !Balence Shafts removed!, hot tanked. $300
F23 block includes:
Acl Race Rod and Crank Bearings +.25 & Clevite Thrust Wahers..*BNiB*
--F23 Crankshaft:..balenced and hot tanked
--F23 Rods:..Hot tanked, checked for straightness.
--G23 custom water neck (tried n true):
--F23 oil pan
***G23 ready H22 head.. includes rocker arm shaft and rocker arms, cam caps and rails. w/ sealing bolts and washers bnib. lightly ported (nothing crazy) by yours truly. no valve train-hot tanked and resurfaced. plug is not permanent> $200
Included with h22a head:
--H22 STOCK Cams and gears:
--H22 Red Valve cover:..Great Condition
--Bottom part of intake manifold
_____________________________________
Sold separado:
--HOnda H22 Timing Belt: ..$70..*BNIB*
--SuperTech valve guides: ...$70...Bnib
____________$400 will land you everything listed fs.
I will Email pics upon req.
Old Sep 1, 2011 | 01:07 PM
CHEETAH's Avatar
trying to buy a few things for my racecar and so need cash funding for the Oct 1st allmotor shootout lol...bunch of stuff for sale:
Custom Endyn rollerwave B18A/B/B20B/Z 0.250" crower long rods 5.644" with accompanying 86mm bore pistons abotu 14.5+:1 compression....8 rods and 6 pistons...$600
OBX K20A/K24A 52mm ITBs new...$500
LS 86.5mmx95mm stroker longblock with ported head, ported victor X intake manifold with 74mm thr body, JDM ITR copy header, single disc clutch, lightened flywheel and hydro B16A tranny, obd1 engine harness, started/alternator, etc...$3500
Arias 13:1 86mm pistons .....$250
Custom huge plenum K-series intake manifold with 75mm opening t/b flange for GM/Ford/Infiniti, 80mm Q45 t/b...$350
84.5mm used 13:1 compression pistons for use with 92mm crank and LS .137 longrod for b-series...$250
82mm JE turbo pistons....$200
89mm K24 used Wiseco pistons 13.7:1 compression scratched up at the top but worked fine (used them like that with no problems)...the chips etc were from broken sparkplug tip...$250
stock sleeved 87.5mm bore K24 longblock with custom IPS/JE pistons, custom rods, new ACL race bearings, ported PRB head, IPS K10 cams, no manifold, no oilpump, bare longblock, made 320+whp with IPS intake manifold....$4500
bare F20C head from S2000, has all but 1 intake valve...$400
complete PRB K20A2 head with cams, rockers, valvecover, etc...$700neg
ported 1st gen B16A head bare (no valves, seals, springs, retainers) but has all rockers and cam caps, etc....$450
email me at gbrtuning@aol.com or pm me here...will gather pics etc and post up asap.
looking for EXOSpeed EG 3 piece frontend, CF hood for EG coupe/hatch...must be local...if you're a good auto painter, hit me up too.
thanks
Old Sep 1, 2011 | 01:11 PM
buck02's Avatar
I have 4 Brand new 2200cc injectors Brand NEW ONLY 4 LEFT
I have extenders if needed just need to be specific which you need.
$132.00 each injector clips included extenders are extra. They sell for 180 each.
Grant 1075 - Grant Racing Performance Series Aluminum GT Steering Wheel
100.00 Brand New
Grant 633 - Grant Racing Performance Series Aluminum GT Steering Wheel
90.00 Brand New
15631 - Aeromotive Fuel Sample Check Valve 55.00
GM boost solenoid Brand new 50.00
EARLS -10 to -10 mini filter 35.00
blemoine02@aol.com
Old Sep 1, 2011 | 01:17 PM
JDM346's Avatar
AEM V1 1040 standalone...modified to runs coils/cam trigger....like new....$700 OBO
Old Sep 1, 2011 | 01:49 PM
sweetfwdthunder's Avatar
ID1000's with tophats and clips for b series - SOLD
Aeromotive fuel pump controller $175
Old Sep 1, 2011 | 01:52 PM
Themouse's Avatar
FS:
-EdelBrock Victor X Intake Manifold B16/Type R Powder coated gloss black and shaved-$250obo
Throttle body-$175
Golden Eagle Fuel Rail-$85
Wiseco piston rings 84mm BNIB-$120obo
Old Sep 1, 2011 | 03:06 PM
hello1320's Avatar
94 CX
10pt chromoly cage...stroud window net and parachute...Moroso switch anel with chassis wiring harness...Odessy PC1200 battery...T1 cut off switch...Kirkley pro race seat w/black cover...Impact 5 way harness...Kens kustoms stage brake and brakebooster delete with willwood master cyl... Custom SS brake lines... GSR brakes Frt/bk...Custom 3 piece front
3000$
Bone stock GSR bare block MINT
Hasport b series EG/DC mounts (62a)
AVID solid mounts B series EG/DC
DSS 5.9 PRO LEVEL upgrades with halfshaft and DSS 36 spline spool (GSR)
GSR head supertech valvetrain Skunk 2 tuner 2 cams
TEXT ME FOR PRICES AND INFO....ONLY 5 RUNS ON EVERYTHING!! I WILL PART EVERYTHING SEPERATE OR DO PACKAGE DEALS
239-438-5267
Old Sep 1, 2011 | 03:16 PM
Kings Performance's Avatar
Here is what I have for sale :
K20A2 Long Block
Golden Eagle Sleeves
CP Pistons 10:1 comp w/ upgraded wrist
Manley Turbo Tuff Rods
ACL Race bearing set
ERL S2000 Oil pump
ARP Head studs
K20A2 head
SuperTech HP Std. size valve
SuperTech Dual springs, Ti-retainers, seals & seats
Skunk2 Tuner 3 cams
$5,500 OBO (About 2 passes on the track off use. The motor made 730whp)
K20A2 tranny
Magnus 1st-4th Dog Box gear set
Quaife LSD (Brand New Never Use)
$4,800 OBO
Driveshaft Shop 5.9 Axles Civic K-series $1,250 OBO
Competition Clutch K-series Twin Disc kit $800 OBO
Kings Performance Honda S2000 tranny – 1st-4th Dog Box gears w/ 5th & 6th stock gears $5,500 OBO
Honda S2000 AP1 Complete stock tranmission $700 OBO (Came from a bone stock car, NO Abuse)
Honda S2000 AP1 Stock wheels with tires $350 OBO
Honda S2000 completetly stock engine harness $300 OBO
For more info & pics please email bebo@kingsperformance.com or call us @ (321) 235-2699
Fernando @ Kings Performance
Old Sep 1, 2011 | 03:43 PM
EDLOVA23's Avatar
IF INTERESTED CALL 973)390-2982
brand new still in the box 2 piece weld skinnies 15"x3" 4x100 bolt pattern $900
i have 2 B-series shift linkages 1 with a B16 shifter and another with a GSR shifter $100 each
Precision injectors 1200cc - $320 shipped in the U.S
aluminum 4" exhaust and muffler $700 or best offer
prefer local pick up from north jersey
custom catch can sits next to the battery $275
the bracket is welded onto the battery tray*
comes with
battery tray w/ bracket welded to it
all 4 lines and fittings minus the 2 fittins on the actual block
aem ecu obd1 1040 box - $700 or best offer
wrinkle blue valve cover $100
Old Sep 1, 2011 | 04:04 PM
rapidoo15's Avatar
SOLD SOLD SOLD
Old Sep 1, 2011 | 04:09 PM
SIXTY's Avatar
FS: 13x7.5 Matte black lenso's new in the box-$350 shipped
JG sheetmatal intake manifold for gsr head - $250 shipped
Old Sep 1, 2011 | 05:03 PM
CNC HMA's Avatar
Selling some parts from past race cars and things just laying around.
http://www.flickr.com/photos/cncenginedynamics/6104833524/http://www.flickr.com/photos/cncenginedynamics/6104833524/ by http://www.flickr.com/people/cncenginedynamics/, on Flickr
The above LS block is not decked or finish honed but has a set of Darton MID Sleeves. (84mm min) sell for $900 SOLD
http://www.flickr.com/photos/cncenginedynamics/6104831814/http://www.flickr.com/photos/cncenginedynamics/6104831814/ by http://www.flickr.com/people/cncenginedynamics/, on Flickr
The above LS block is decked with the sleeves proud using a set of LA Sleeve Open Deck sleeves but is not finish honed. (84mm min) sell for $850
http://www.flickr.com/photos/cncenginedynamics/6104283173/http://www.flickr.com/photos/cncenginedynamics/6104283173/ by http://www.flickr.com/people/cncenginedynamics/, on Flickr
Above is a set of rear Omni Power Drag struts I used in my EK SFWD/T4 car in 2006 for a few races. I'm not sure if the lower is a direct fit for the EK but it was what we used with modifications to the LCA.
http://www.flickr.com/photos/cncenginedynamics/6104826378/http://www.flickr.com/photos/cncenginedynamics/6104826378/ by http://www.flickr.com/people/cncenginedynamics/, on Flickr
Above is a set of front Omni Power Drag Struts currently being removed off of our Outlaw car. The lower section is the replacement steel pieces issued.
Full set of Omni Power Struts for $450 SOLD
http://www.flickr.com/photos/cncenginedynamics/6104279705/http://www.flickr.com/photos/cncenginedynamics/6104279705/ by http://www.flickr.com/people/cncenginedynamics/, on Flickr
MSD Digital 7 and Coil sell for $500
Prices do not include shipping
I don't check my Honda-tech PMs very frequently so you can contact me through my email howard@cncenginedynamics.com
Old Sep 1, 2011 | 05:31 PM
xsi-t's Avatar
Fs AEM 1040 set up to run T1 cam trigger. 800 shipped obo
Fs brand new ID1000's with clips 400 shipped
Old Sep 1, 2011 | 05:53 PM
94turbosi's Avatar
weld wheels 13x8 with m/t tires 24.5 x9x13 4x100 5 inch backspacing 10 passes mate blk barrels powder coated (SOLD)
shipped and paypal
liberty handcuff brand new (sold)
00 civic oem light cut out for turbo scoop $100
precision 880cc injectors $150
Old Sep 1, 2011 | 07:18 PM
sampletegi's Avatar
CALL OR TEXT (909) 964 - 4TWO47
Putting out feelers for my H2B setup. Would like to sell it in one go to someone for a good deal so I don't have to deal with parting it out. The setup was installed in my Integra and driven maybe 5 miles. I ran into money troubles and never got it tuned and it never got to see the track. Fidanza flywheel and Stage 3 clutch will show absolutely no wear.
I bought the longblock from HMO (Hmotorsonline) about a year ago. The waterpump, timingbelt, tensioner, cam seals, thermostat, oil filter, valve cover gaskets, vtec solenoid seal, IM gasket have all been replaced with OEM Honda parts. Still running balance shafts and has single alternator crankpulley. Tranny is an unknown B series but I believe it is an LS. Fidanza flywheel, Clutchnet Stage 3 pressure plate w/ ACT 4 Puck clutch, NEW throwout bearing and slave cyclinder.
 JDM H22a OBD1 $999 ++OEM HONDA PARTS LISTED $200
 QSD H2B KIT $750
 INNOVATIVE MOUNTS STEEL $250
 B18 TRANNY $300
 CLUTCHNET STAGE 3 W/ ACT 4 PUCK CLUTCH $300
 FIDANZA FLYWHEEL $200
 B18 AXLES (PEPBOYS) $200
 LUCAS 440CC INJECTORS $200
 INNOVATIVE H2B ALTERNATOR BRACKET $89
 GSR H2B CONVERTED ENGINE HARNESS $100
 B&M FUEL PRESSURE REGULATOR $40
 ROSKO EGR BLOCKOFF $20
 NGK WIRES $50
 NGK PLUGS $35
 B18 T BRACKET (NEW HONDA) $50
 B18 HALFSHAFT $50
ASKING $2400 PICKED UP FIRM
As I made that list I realize how much I have spent on this swap lol. YOU CAN’T BEAT THAT PRICE FOR A FULL SWAP THAT WILL BE PLUG AND PLAY!!! IF I DON’T HAVE ANYONE INTERESTED I WILL START PARTING OUT BUT WOULD PREFER NOT TOO.
__________________
Old Sep 1, 2011 | 11:44 PM
theidealone's Avatar
Parting out my car. 1989 Civic Si. Sleeved D16Z6, Built Head, Bogart Slicks and Skinnies, 10 point caged shell, etc.
http://hondamarketplace.com/showthread.php?t=2974482
Old Sep 2, 2011 | 03:14 AM
Autoworks's Avatar
F.S: 13.7:1 K24 $2800
-stock sleeves, weisco pistons, blue print rods, skunk2 springs, skunk2 retainers, skunk2 Pro3 cams, Skunk2 Cam gear, single vent -10AN powdercoated gloss black valve cover (assembled, clearanced rockers, car has only idled on setup, no milage, no clearance issues),
-Skunk2 K Intake manifold and 74MM throttle body $700 (installed, car has only idled on the setup), port matched intake manifold inlet to 74mm
-Stock K24Z1 w/ harness, under 30k miles $400
-K24A1 crankshaft, mint $150
-EG K swap Hasport mounts (used ) $300
-K20 TWM ITB's...missing fuel rail and one og the 3 fuel rail mount points $800
photos:
(checking stretch during assembly)
Old Sep 2, 2011 | 04:42 AM
KleenKrew's Avatar
Weld magnum 13" 4x100 centers Freshly powder coated black
250.00 OBO!!!!! MAKE OFFERS
Packaged ready to ship
GSR CAMS/OEM gears 100. obo
AFI Aluminum intake pipe 2.5 was for a 92/95 civic make offer
Old Sep 2, 2011 | 05:38 AM
Kevin's Avatar
JG ported b16 head (needs rocker shafts, oil rails) $300 shipped
T4 b series turbo manifold, cast collector, jet hot coated $450 shipped
Old Sep 2, 2011 | 06:23 AM
mangina's Avatar
15x8 4" backspace Spinwerks wheels. 8 passes, pretty much brand new. $425 shipped
Old Sep 2, 2011 | 08:33 AM
turbotypeR@SPEC's Avatar
25 Year Member
Practically new Crower H23/F22 rods- $400 + shipping
Old Sep 2, 2011 | 08:55 AM
Abraham-ATS's Avatar
email me for pics ratedrtuning@hotmail.com
1- Hondata K-pro on a prb ecu very used for a few dyno pulls $875
1-set of bnin twin disc replacement disc for comp clutch bseries $240
1- brand new never used haltech platinum sport 2000 with long universal harness 1,800OBO
1- tilton twin disc clutch for b series 8 dyno runs 3 track pases. $850
1-DSS 5.9 axels for b series with hubs $1050
1-complete asambled shot block $2100 OBO
ls block
81mm darton sleeves
o ring
je 9.0:1cr
eagle rods
toda racing oil pum gear
moroso oil pan
fluid damper
Head.
B16 $1200
ferrea valve, springs, retainers and valve guides
web turbo cams
edelbrock intake manifold for b16 head with ge fuel rail, aem fpr, precision 1000cc injectors and 68MM tb $650
GSR tranny with itr lsd (2nd gear grinds a lil) make me an offer
prices dont includes shippin and paypal fees...
Old Sep 2, 2011 | 11:41 AM
MrParks's Avatar
free shipping on most items in the us.
intl orders will be additional charges.
paypal fees apply
first come first serve basis.
info@fcsfab.com paypal addy.
if you have immediate questions of would like to purchase the item please email me at info@fcsfab.com thanks
bmcrace manifold 6L plenum, 6" runner, mustang tb type. mint cond. already has a tb cable bracket welded for oem honda cable. does not come with injectors or throtlebody. it is a 8 injector setup with n20 bungs. 1100 hp+ manifold
1000.00
FCS battery box, display item semi polished unit. used for display. mint cond. comes with all the straps and hardware for easy installation. all associations approved, deemed legal in all motorsports.
155.00
FCS 5 gal fuel cell. -10 feed, -6 return. no sender unit for this item. used test fitment in a da.
race proven by many top teams in the country and worldwide.
fits 88-00 civic/crx all models, 89-01 integras all models, <<< here are the fitments for those who keep asking. <<<<<
mint condition very clean. can take new pics. comes with all the hardware, straps ect.
350.00
k series cast turbo manifold w/ turbosmart 38mm ultra gate. manifold has never been used. new. wastegate is used. 300 for both or can part out 160 each.
momo small steering wheel with ef/crx hub. clean. 100.00
carbon monster autometer tach mint cond. 150.00 comes with tach mount and shift light.
2 mechanical oil pressure gages, 20 each
1 water temp gage mechanical 30.00 is great condition.
gage pod for ef crx civic models. 10bux
apex vafc ol sckool but still works! complete harness as well. 40bux.
3 gallon box tank. sumped. has foam baffling. used in good condition. -8 fittings all around. 100.00
msd in line pump 255gph 125 max psi. used in good condition. 60.00
email: info@fcsfab.com for quick response. 24/7
paypal fees apply
Old Sep 2, 2011 | 01:16 PM
061000rr's Avatar
m&w pro10 cdi box with coil. not sure of brand of coil but it says made in the USA!!
500.00$ or will trade for aem twin fire cdi box and pencil coils
1993 vx rolling chassis., needs finished. i found out real quick i hate body work. custom 6 point cromoly cage, partially shaved engine bay(needs finished) has rust above both rear wheels. and a spot in the bottom of drivers door frame. body side. will have stock suspension with drum brakes unless you want to pay a little more and i have integra rear disc for it. 1500.00$ roll cage built around interior. so it would all fit if for some reason you wanted it.
