S300 Launch control
Old Aug 27, 2012 | 01:48 AM
acura_b18c1's Avatar
Default S300 Launch control
hey guys, im about to go the drags with slicks for the first time. ive been searching and saw the recent thread with launch control settings for turbo cars. My setup right now is a NA. simple 2L B with 23inch slicks.
a few question about the settings.
do u guys usually leave the maximum speed at 6mph?
i have the launch control always on. do u check the invert input box?
I saw the fuel enrichment and timing tips in the other thread for boosted cars. learned alot. do i need to do anything here for NA?
and lastly.. what about the burnout rev limit?
after u guys go through the waterbox and begin the burnout, do u jus WOT and let it hit rev limiter consistently with the Ebrake up or do u pump the gas pedal?
thanks alot for the help for this rookie.
Old Aug 27, 2012 | 03:58 AM
Twenty47's Avatar
Default Re: S300 Launch control
i wouldnt mess with the fuel enrichment and all that. set the limiter at like 7500 rpms and wide open throttle it with some pre load. not much to it for NA at less than 250whp.
Old Aug 27, 2012 | 06:22 AM
ok i see. thanks. just making sure, during the burnout when the Ebrake is up and you wide open throttle it, do u jus let it hit rev limiter or pump the gas?
Old Aug 27, 2012 | 03:48 PM
theidealone's Avatar
Do what works for you. I power through bouncing off of limiter. A lot of people pedal it because they don't like bouncing on limiter. But I also do 3rd gear burnouts so it doesn't take a ton of time to heat the tires. Plus I'm turbo.
Old Aug 29, 2012 | 03:10 AM
oh ic. anything bad results from bouncing off the limiter too much?
Old Aug 29, 2012 | 04:29 AM
tepid1's Avatar
Bouncing off the limiter is not a good idea. I'd recommend avoiding it.
Old Aug 30, 2012 | 11:56 AM
ok yea i wasnt comfortable with bouncing off the limiter. i guess ill try doing what i did with DRs before. roll through the water, put it in 2nd, get the rpm to about 6k with the ebrake up, drop the clutch and WOT. when it hits 9k, drop the gas pedal till it hit 6k and rev it back up. pump like that a few times, and drop the ebrake and WOT through. how does that sound?
Old Aug 30, 2012 | 01:10 PM
DA 4 Lyfe's Avatar
+1
Old Aug 30, 2012 | 01:17 PM
nuttah69's Avatar
i remember my 1st drag burnout in my eg5 (d16z6). i done a mad burnout (dont ask why). then when i went to launch off the line i broke my gearbox
good came from it though because i ripped out the motor and built a forged b18c4 bottom end with a c6 itr head (ported and polished) running a gt30r
Old Aug 31, 2012 | 01:57 PM
haha k thanks for the suggestions guys. ill also go look for some in cam videos to better understand it
Old Sep 6, 2012 | 10:09 AM
Jakessw's Avatar
Hey, I am also going to the track soon and will be using the launch control on k-pro for the first time...
Did you ever get an answer on the mph setting?
I am alittle confused at what it should be set at also...
The car is a k20 swap del sol k-pro and bolt ons.
don't mean to thread jack.
ZebrasoHD
Engine Management and Tuning
Sep 29, 2018 06:37 AM
JHipps
Oct 1, 2014 01:55 AM
reyesb25
Jun 9, 2013 07:01 PM
acuralovar
Nov 29, 2009 08:08 AM
CLE
Sep 11, 2006 10:06 AM
