rywire help
Old Apr 2, 2013 | 08:03 AM
sanman000719's Avatar
Default rywire help
i have searched, and found alot of posts about this but not my question
obd0 to obd1 harness with the jumper harness that they send out.
the power distribution plug that used to sit near the fuse box on the fire wall doesnt connect to the rywire distro plug that came with the harness. the rywire plug has metal jumpers it it since both plugs are female and they are to big to go into and connect to the obd0 plug.
does anyone have a solution for this or can lead me in the right direction
thanx for the help, and or suggestions in advance
Old Apr 2, 2013 | 08:45 AM
Rtype16's Avatar
Default Re: rywire help
Did you try calling Rywire? They are very helpful over there.
Old Apr 2, 2013 | 09:15 AM
sure did now answer left a message no call back
im not trying to stir this like they did something wrong i am just trying to figure out what my options are here
Old Apr 2, 2013 | 09:32 AM
Blown90hatcH's Avatar
What are you trying to do exactly?
You have a MPFI Pre-OBD engine harness converted to OBD1 and your chassis is also using a Pre-OBD to OBD1 ecu conversion harness as well? Post some pictures of the connectors in question. And I would probably move this to tech.
Old Apr 2, 2013 | 09:41 AM
its was in tech with no hits at all
i will post the pics up later
its a 89si harness the engine bay harness has been replaced with the rywire harness, and they send out a connector harness to be wired in also for power and ground.
the rywire harness has the plug for the obd1 power distro cap and it has these jumpers inside it to connect both harnesses the metal jumpers are to big for the obd0 pins
Old Apr 2, 2013 | 10:00 AM
Old Apr 2, 2013 | 10:01 AM
Old Apr 2, 2013 | 10:02 AM
Old Apr 2, 2013 | 01:46 PM
ok got my answer and the answer is leave that alone they dont plug together and thats what i thought to begin with
Old Apr 2, 2013 | 01:47 PM
jdm inc's Avatar
bad *** drop light! lol!
Old Apr 2, 2013 | 01:56 PM
PhilStubbs's Avatar
So, these 2 plugs are the ones in question? You can de-pin the obd0 plug and put the pins into an obd1 plug. Looks like a trip to the junkyard is in your future
Originally Posted by sanman000719
Old Apr 2, 2013 | 02:15 PM
the factory plug isnt used at all rywire said the one on there harness is setup when you get it and to leave it alone.
this is a very common issue he said, and he stated that they should label the plug with something to the affect of leave this alone lol
Old Apr 2, 2013 | 02:17 PM
that drop light os the bomb boiii lol
Old Apr 2, 2013 | 02:24 PM
jdm inc's Avatar
Rywire ftw!
Old Apr 2, 2013 | 02:28 PM
Fliptard's Avatar
Ever order I or a friend have ordered is always wrong or backwards from what we wanted, We even specified exactly what we needed, so far we are up to about 10 wrong orders. I won't buy directly from them again.
Old Apr 2, 2013 | 03:13 PM
90blackcrx's Avatar
I've been dealing with Ryan and Peter for over 10 years now, I've never ever had a problem with them, there products are the best, there customer service is next to none. You might not get someone on the phone the first time but try calling back or emailing them and you'll get a response. As of late they've been super busy with a lot of interesting projects.
Old Apr 2, 2013 | 03:59 PM
yah im loving the harness, and after a quick education i am better with it. he was like oh yah that plug lol so he already knew my question before i asked it and was super user friendly
91efbluehatch
Jul 28, 2012 12:23 AM
psychadelicfreedom
Jul 2, 2005 11:22 PM
teg4life
Oct 14, 2004 11:22 AM
milruner
Sep 19, 2004 12:07 AM
