Problems mounting slicks
Old Jul 15, 2007 | 07:32 PM
MkIIRoc's Avatar
Default Problems mounting slicks
Hello, I posted this in wheel and tire, but hopefully I can get some input from the other racers...
I have some lenso VPD's and M&H 22x8x13's. I got one mounted fine, but the other one's front bead will not pop! It will go 3/4 the way around, and then just start pushing out the sidewall. I only go up to 30 psi tops. I tried spraying on soapy water, but it didn't work. I must have struggled with this one for 3 hours! I tried flipping the tire, as well. Any suggestions? I would like to hit a test and tune before CMI's. Thanks!
Old Jul 15, 2007 | 07:51 PM
I B BANGGIN's Avatar
Default Re: Problems mounting slicks (MkIIRoc)
i had the same problem.....i took mine to 40psi (even though your not supposed to) and bounced the tire, let some air out and used a little water then bounced some more and let all the air out and then aired it back up....had to do a few time but got it........hope that helps some!
Old Jul 15, 2007 | 08:00 PM
MkIIRoc's Avatar
Ok, worth a shot. Just bounce it from waist level or so? 40 won't stretch or pop them will it?
Old Jul 15, 2007 | 08:12 PM
GetawayInMoscow's Avatar
Default Re: (MkIIRoc)
Try this...
Get some Pestone starter fluid, spray a **** on of it in where you want the bead to seat, then take a match and throw it at where you just sprayed the starter fluid and it will "explode" the tire on to the bead.
Old four wheeling trick for if your tires come off the bead from too little PSI
Old Jul 15, 2007 | 08:21 PM
MkIIRoc's Avatar
hmm, I've seen that before, but I don't know since I just threw down a grip on these. Maybe I'd try it on my wife's car!
Old Jul 15, 2007 | 08:44 PM
40 wont stretch them...i bounced them has hard as i could about head level..
Old Jul 15, 2007 | 08:57 PM
paulzy's Avatar
WE had problems as well. A lot of lube on the rim and the bead, valve out of the stem, and the cheetah worked for us.
Old Jul 16, 2007 | 12:04 AM
HamiltonRex's Avatar
Default Re: (paulzy)
used 65psi to seat my slicks same size wheel/slick goodluck
Old Jul 16, 2007 | 04:20 AM
Autoworks's Avatar
Default Re: (HamiltonRex)
Use a cheetah if you have one.
If the bead seems to be getting hung on the wheel then try using alot of lube on the wheel and the tire.
Some just take alot of pressure to seat, it won't hurt the tire. Just seat it and let the air out.
Old Jul 16, 2007 | 05:05 AM
eddie_ek's Avatar
Default Re: (Autoworks)
I had the same problem when mounting my slicks because the center bubbles up then the bead don't pop. Don't laugh beacuse it worked for me and if I had to do it again I will.
Lots of lube on the bead, on the empty slick mounted on the wheel I took a chain and put it arround the center of the tire with a lock filled the tire up to 38psi and it finaly popped looked freekin scarry but it worked a nice thick solid chain.
Old Jul 16, 2007 | 04:18 PM
MkIIRoc's Avatar
POP! got it! Took a lot of grease, a tie down strap, and 45 psi, but it finally went. That bastard better never come off! I'll just toss the wheels when I need new slicks
Thanks for all the help, you guys are the heat!
Modified by MkIIRoc at 6:39 PM 7/16/2007
Old Jul 16, 2007 | 08:21 PM
Tippyman's Avatar
Default Re: (eddie_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie_ek &raquo;</TD></TR><TR><TD CLASS="quote">
Lots of lube on the bead, on the empty slick mounted on the wheel I took a chain and put it arround the center of the tire with a lock filled the tire up to 38psi and it finaly popped looked freekin scarry but it worked a nice thick solid chain.</TD></TR></TABLE>
That sounds scary.
Old Jul 17, 2007 | 05:08 AM
eddie_ek's Avatar
Default Re: (Tippyman)
It looked scary, but it took less air because the chain does not give and it kept the center from bubbling out.
I got the idea from a truck shop, I saw them strap one those big truck tires from the center so it can sit on the wheel but they did not use a chain it was a nylon strap thats all I had in the shop a tow truck chain.
00 Coupe EJ8
Mar 26, 2013 05:21 PM
tepid1
Aug 26, 2011 06:59 AM
MkIIRoc
Jul 15, 2007 09:12 PM
94B18Civic
Jan 19, 2006 02:53 PM
sloz64now
Dec 1, 2004 05:46 PM
