Help With Tire mounting
Old Jan 7, 2006 | 06:09 AM
94B18Civic's Avatar
Default Help With Tire mounting
Does anyone have any links for tire mounting procedures? I am having some problems sealing the bead on a set of 19's.
Old Jan 7, 2006 | 06:54 AM
SpoolnEG6's Avatar
Default Re: Help With Tire mounting (94B18Civic)
so you have the tire physically on the rim correct? but when you put air in it it won't "pop" up on to bead? how much air are you putting into it?
Old Jan 7, 2006 | 07:17 AM
94B18Civic's Avatar
Default Re: Help With Tire mounting (SpoolnEG6)
Yes the tire is on the wheel but no matter what I try air gets by the bead. I am using a shop compressor at work. It puts out 150psi max.
Old Jan 7, 2006 | 08:41 AM
SpoolnEG6's Avatar
is it very close to the bead of the wheel where it is just about to seat then won't go anymore? Also what size tire is it?
Old Jan 8, 2006 | 06:05 AM
94B18Civic's Avatar
No, it won't seat at all. I tried various methods but in one spot air always gets by. Even after spinning the tire on the rim air gets by in various places. Its a Renn Tech Wheel tire size 245/35-19.
Old Jan 8, 2006 | 07:54 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94B18Civic &raquo;</TD></TR><TR><TD CLASS="quote">tire size 245/35-19.</TD></TR></TABLE>
On a Civic???
Old Jan 9, 2006 | 04:49 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: Help With Tire mounting (nsxtasy)
lube the bead up good. make sure the bottom part of the valve stem isn't on the way of the bead. what I usually do is that I break the beads down again and have a buddy raise the bottom part of the tire at all sides then put air in.
Old Jan 9, 2006 | 06:35 PM
pingaturbo's Avatar
Make sure you didn't rip the bead while mounting the tire on the wheel.
Old Jan 9, 2006 | 09:27 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (pingaturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pingaturbo &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you didn't rip the bead while mounting the tire on the wheel.</TD></TR></TABLE>
I was thinking the same thing...
Old Jan 10, 2006 | 02:10 PM
SpoolnEG6's Avatar
im stuck on this, we need more info...... try mounting a 325/25/20, that's not fun
Agree there might be a small tear somewhere
Old Jan 19, 2006 | 02:53 PM
94B18Civic's Avatar
Default Re: (SpoolnEG6)
Yup. The tire was ripped by the valve stem. After removing the tire I also noticed a label on the inside of the wheel (tire side) that was scrapped off somewhat. The tire should have originally been mounted with the wheel upside down. The wheel was on a Benz SL 65.
tonezilla
Jan 26, 2006 08:52 AM
hondaguyef
Sep 29, 2004 02:52 AM
sTraNdeD
Jun 10, 2004 11:51 PM
justininhifi
Jun 28, 2003 08:50 AM
ck279
17
Feb 6, 2002 07:13 AM
