hp goal for 470ccm injectors (E85)
Hi folks,
I got 470ccm Injectors on my stock B16 Turbo (8psi, T4 57 trim, made round about 250whp on pump gas) and I want get a new tune on E85.
Are the injectors big enough for this small setup?
Need bigger ones?
What size to be safe?
Thanks for the answers.
Need bigger ones?
Re: hp goal for 470ccm injectors (E85)
you will need bigger injectors to run on e85 to make the same power as pump gas. it uses "almost" double the ammount of e85 to run the same power as on pump fuel.
try out some 750cc or larger injectors.
