p2w clearance for high comp k24
Old 05-15-2015, 08:00 AM
been there done that
doood's Avatar
Default p2w clearance for high comp k24
Gonna be attempting my first build soon. the block will consist of wiseco 87.5mm 14.3:1 pistons. Will be run on e85 for the street and q16 for track. It will see street time but won't be a daily. Was thinking of going with wisecos recommended of .0035 but want to hear from more experienced builders.
Old 05-17-2015, 10:46 AM
90blackcrx's Avatar
Default Re: p2w clearance for high comp k24
What are the power goals ?
Old 05-17-2015, 03:17 PM
PyroProblem's Avatar
Doesn't piston alloy also play a role? High vs low silicon?
Old 05-17-2015, 09:03 PM
doood's Avatar
350Hp more or less. I'm not too concerned with the hp numbers as I am of my et goal of 10s.
I'm pretty sure it's 2618 alloy. Just a regular Wiseco shelf piston.
Old 05-18-2015, 01:27 PM
b20vcrxsir's Avatar
If they are shelf Wiseco pistons they recommend .0025" Piston to wall according to the spec sheet.
I had a 88x99 K24 with the Wiseco K650M88 14.2:1 compression pistons and I ran my Piston to wall at .0035" and had no issues. Pistons looked new when I took engine apart for inspection.
Old 05-18-2015, 03:14 PM
doood's Avatar
You're correct. After Looking at the sheet again it is .0025.
So far from everything I've been reading .0030-.0035 is optimal.
E Town DSM
01-31-2014 01:02 PM
Ryan#1
10-02-2008 06:27 PM
melovesboost
02-05-2007 12:10 PM
Hy-wind
12-02-2004 04:18 AM
b20ek
04-18-2003 02:37 PM
Quick Reply: p2w clearance for high comp k24
