Oil Pump question
Old Nov 25, 2008 | 03:28 PM
underpressure02's Avatar
Default Oil Pump question
When building a new motor or tearing a motor down after a season do you replace the oil pump or just open it up and check it? Everytime I put a motor together I am buying a new oil pump for that piece of mind. But as I was going through my attic today looking for parts I have about 11 oil pumps up there. Some were used for less then 500 miles.
Do you recommend a new one or just taking one apart and checking it?
Thoughts?
Old Nov 25, 2008 | 03:30 PM
rota92
Guest
Posts: n/a
As a friend I would say keep doing what you're doing and put a new one in there, and sell the barely used ones on here to recoup some cash
Old Nov 25, 2008 | 03:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
the three engines i have built, (for myself) all 3 got a new oil pump, strictly because i have beat the hell out of them, and dont want anything i cant see during an inspection coming back to bite me in the ***.
Old Nov 25, 2008 | 03:54 PM
1992Si's Avatar
I guess we got lucky. The single cam used the OEM pump with 216,000 miles on it, just shimmed for high pressure.
Why do you think you need to keep buying oil pumps, if it ain't broke, don't fix it. I'll bet you buy new water pumps too.
Old Nov 25, 2008 | 04:16 PM
Because with my great luck with motors the last thing I need to do is have one fail b/c the oil pump took a ****. And yes I buy a new water pump, timing belt, tensioner, gaskets the whole nine. When I put a new motor together.
When I drop valves depending how late it is I might reuse the autozone headgasket.
Old Nov 25, 2008 | 04:30 PM
SovXietday's Avatar
Hahahaha, brand new oil pumps, tensioners, belts and an autozone headgasket. You are something else man.
I'm running the oil pump that came with my engine, god knows how many miles is on it. Water pump is new, but they're super cheap.
Old Nov 25, 2008 | 04:37 PM
Redline130's Avatar
I use a new pump with every new motor. It's probably more psychological than anything, but my last two motors did have some pretty bad damage and I wasn't sure if any fragments got into the pump. I would rather err on the safe side.
Old Nov 25, 2008 | 04:40 PM
Don't knock the autozone headgasket lasted almost 2 years, with numerous dyno pulls, a ton of passes down the track and not a single issue. My motors didn't even last that long, and we reused it once or twice I forget.
Old Nov 25, 2008 | 04:42 PM
civicxpress's Avatar
i usually change the water and oil pump but because of the economy i havent been doing the water pump,lol
Old Nov 25, 2008 | 05:18 PM
h22 civic's Avatar
for the damage the rotor does when it breaks id keeep buying new ones...usually when they go everything is garbage motor, head, turbo etc
Old Nov 26, 2008 | 04:51 AM
Mikey3000's Avatar
uh yeah oil pump is much more critical than water pump. i don't see how a water pump would fail with such low miles on it.
Old Nov 26, 2008 | 05:54 AM
sgnlab's Avatar
what cost less?
full engine rebuild and new turbo or an oil pump.
I dont care if i only get 200 miles out of my engine i will replace oil, water pumps every time.
Old Nov 26, 2008 | 06:38 AM
mec. pedri's Avatar
always replace them using honda oil pumps
water pumps i just get after market
Old Nov 26, 2008 | 08:43 AM
DSRxCandyh2bEG's Avatar
I don't see a water pump failing, oil pumps are a huge issue though. Wouldn't it be the same thing if you changed the gear inside to a pro-drive or equivalent every season.
Old Nov 26, 2008 | 02:47 PM
h22 civic's Avatar
they still break no matter what name ...but people still say their isnt a prob with them lol...idk, but i learned my lesson years ago with them and went peterson external wet sump best thing i ever did,and while i was at it i went with meitzer external water pump also kill 2 birds with 1 stone .lol.
xyk
Jan 6, 2010 08:00 PM
itr1235
Mar 7, 2007 06:18 PM
garagespecial
Apr 26, 2003 01:16 AM
Evs-One
Feb 28, 2003 12:45 AM
Lei Siew Long
Apr 17, 2002 08:54 PM
