Oil Pump Failure
Old Mar 24, 2010 | 12:51 PM
h22_bb4's Avatar
Default Oil Pump Failure
Hey h-t
As the title says, what can cause oil pump failure???!!
I had this problem twice into the same motor, it was the same way the two oil pumps fail, the gear was broken into pieces....???
Both didn’t last much, the first one broke on the dyno(OEM b18c), and the second oil pump holded around 12 passes on the drag strip(OEM B16).
The engine is turbo b16 with CP pistons Manley Rods, balanced rotating assembly, 9K rev..
If you guys can think of anything that can cause this please share it...
Thanks
Old Mar 24, 2010 | 12:54 PM
ilovuall's Avatar
Default Re: Oil Pump Failure
did you ever have the block alighn bored ? what kind of dampner?
Old Mar 24, 2010 | 01:00 PM
96 GSR-T's Avatar
Something is out of wack in your bottom end, a bad line bore like mentioned above could definately be one cause, my friend has your same issue and it was due to a shop doing a bad line bore.
Old Mar 24, 2010 | 01:05 PM
ilovuall's Avatar
when you have a block line bored if done wrong the crank is moved in the block and the oil pump is no loger centered on the end of the crank causing extra pressure to be put on the gears. hence the broken gears!
Old Mar 24, 2010 | 01:14 PM
h22_bb4's Avatar
the block was alighn bored..
the Crank Pulley is unorthodox which I really doubt it..?!
Old Mar 24, 2010 | 01:24 PM
boostedcivicsir's Avatar
Mr. Badwrench
the pulley is unorthodox but really doubt it?
if it is infact an unorthodox, you may have 2 issues. the balancer, and the line hone.
dont get us wrong. line honing does not cause the issue. doing it wrong does.
Old Mar 24, 2010 | 01:27 PM
narfdanarf's Avatar
shitty crank pulley is probably your number 1 cause, second contributing factor is the potential of your shitty line hone with improper assembly of oil pump.
Old Mar 24, 2010 | 01:28 PM
h22_bb4's Avatar
but I have many engines bored in the same machine shop with no issues ??!!!
how could I assemble the oil pump properlley??
Thanks guys...
Old Mar 24, 2010 | 01:46 PM
ilovuall's Avatar
through that crank pulley in the dumpster !!!
Old Mar 24, 2010 | 01:49 PM
KStuned's Avatar
Yep
Old Mar 24, 2010 | 02:06 PM
h22_bb4's Avatar
diff I will throw that piece of sh*t..
OEM FTW...
Keep it coming......
Old Mar 24, 2010 | 02:30 PM
cibao2ner's Avatar
u have to check the clearances of the oil pump gear to the crank..and if it too tight on one side u need to grind down the dowels so it moves the oil pump up until its within spec...
Old Mar 24, 2010 | 02:33 PM
base-op.1320's Avatar
I also had this issue twice, after the first I installed a fluidmpr and it happened the second time and then I changed from a cheap *** clutch to an act and never had problem again.
Old Mar 24, 2010 | 02:40 PM
Innes's Avatar
look into an ATI damper over the unorthodox and OEM one
Old Mar 24, 2010 | 02:53 PM
still_slow's Avatar
I have seen a H22 do the exact same thing as yours it destroyed 2 oil pumps before they discover the crank pulley was out of balance.
Old Mar 24, 2010 | 03:21 PM
Topdawgg's Avatar
OEM, ATI or Fluidampr..
wouldnt run anything but, on my car
Old Mar 24, 2010 | 05:48 PM
ALL IMPORT's Avatar
ATI is the only way to fly.
deff need to check your oil pump to make sure it is not off on the crank. easy fix.
Old Mar 24, 2010 | 06:03 PM
EGHATCH4YA209's Avatar
Any chance you noticed loose flywheel bolts upon disassembly? This also will cause the same problem.
unorthodox= Trash it
Old Mar 25, 2010 | 06:23 AM
Topdawgg's Avatar
I learned the hard way, shattered a pump on the dyno @ 493whp.
not fun, but got lucky
Old Mar 25, 2010 | 08:20 AM
alpha's Avatar
End of thread. This is your issue. Replace it with an OEM (NON CTR), ATI or Fluidampr. Promise your problem will be solved
Old Mar 25, 2010 | 08:48 AM
Topdawgg's Avatar
exactly
i didnt realise that was a known problem either, until it happened
that was when I looked on here and the first thing someone said was "aftermarket pulley??"
Old Mar 25, 2010 | 10:42 AM
h22_bb4's Avatar
Thanks guys for all the help...
I will go with the b16 OEM damper...
I already disassembled the engine, thankfully everything looks fine....
I will rebuild the block and will check the oil pump clearances...
Old Mar 25, 2010 | 10:44 AM
h22_bb4's Avatar
everything was tight... Thanks
Old Mar 25, 2010 | 02:33 PM
C.R.E.A.M.*562*'s Avatar
X 2....
Old Mar 25, 2010 | 07:10 PM
TurboManny's Avatar
I wouldnt trash that Unorthodox pulley its still good for some scrap..lol, Yeah def. take that thing out.. ATI or OEM R is what to use
nighttrain33
Oct 3, 2006 07:30 PM
slowteg550
May 21, 2006 03:12 PM
ICeDoUt
Jan 10, 2005 09:50 AM
Death_to_Thieves
Apr 20, 2004 02:35 PM
StageIIIhb98
Dec 15, 2002 05:58 PM
