obx lsd
Old Jan 11, 2010 | 05:16 PM
b20vtek's Avatar
Post obx lsd
I just got a b16 trasmission from a friend with a obx lsd, i'm trying to buy a 4.7 type R final drive but they are asking me if the lsd has 10 or 12 bolts.
does anybody knows how many bolts does the b16 obx lsd has?
try seaching and came up empty
thanks
Old Jan 11, 2010 | 05:20 PM
DaveF's Avatar
Default Re: obx lsd
im pretty sure the oem typeR LSD uses a different bolt pattern on the ring gear, than a non lsd transmission
Old Jan 11, 2010 | 06:44 PM
b20vtek's Avatar
Default Re: obx lsd
never knew that but let me do some reseach on that
thanks
Old Jan 11, 2010 | 07:28 PM
b20vtek's Avatar
Default Re: obx lsd
i just finish reading something and according to what i was reading the b16 transmission with a 4.4fd has a 66t ring gear and the type r 4.7fd also has a 66t ring gear and both share the same 15t counter shaft. there is a difference between the b16a and the type r because the earlier (b16 92-95 del sol) has a 64t ring gear set so is smaller a that will make the bolt pattern different. so based on that i believe that the type r final drive will fit on the 99-2000 b16 transmission with a 4.4 final drive.
correct me if I'm wrong....... i'm trying to to lear before i pull everything apart
thanks
Old Jan 11, 2010 | 07:56 PM
Aquafina's Avatar
Default Re: obx lsd
10.
Only way an ITR FD will fit in the trans is if you use a B18C diff. So if you want to run the OEM FD, get a B18C diff. If you want to keep the OBX, get a 4.7 FD for a B16A like the MFactory FD.
Old Jan 11, 2010 | 08:27 PM
JJsMotorsports's Avatar
Default Re: obx lsd
Since honda transmissions where so inconsistant when manufactured, I have found some b16s with big ID ring gear and (most) small ID ring gear, same goes for itr's, and gsr's(most big ID's)? LMK if I'm wrong?
Old Jan 11, 2010 | 09:11 PM
cibao2ner's Avatar
Default Re: obx lsd
i have both lsd next to me an oem itr and an obx 9000 for b16/ls tranys and they both have 10 bolts..
Old Jan 11, 2010 | 09:19 PM
crob621's Avatar
Default Re: obx lsd
i have a b16 with a obx lsd and a ITR 4.7 fd, i had got a b16 lsd but had to return it to get the gsr lsd so the FD would fit in....
Old Jan 12, 2010 | 01:08 AM
Aquafina's Avatar
Default Re: obx lsd
Letting you know lol. All B16's have the small ID ring gear, all ITR's and GSR's have the large. Any you open that are different have been opened up by someone else before and changed. Honda is very consistent when it comes to transmission.
Old Jan 12, 2010 | 04:09 AM
b20vtek's Avatar
Default Re: obx lsd
ok i guess i will be ordering a b16 final drive
thanks for the help everybody
Old Jan 12, 2010 | 05:17 AM
DaveF's Avatar
Default Re: obx lsd
what trans came with the crazy 14? bolt limited slip ? jdm itr ?
Old Jan 12, 2010 | 05:21 AM
MFactory's Avatar
Default Re: obx lsd
Optional oem Viscous LSD. Was an option for both the B16A and B18C. It's not just the bolt pattern that is different, the LSD is physically part of the ring gear functionally (although it can be separated)
Old Jan 16, 2010 | 12:48 PM
dicxonjim's Avatar
Default Re: obx lsd
Cibao2ner, do you know where I can get an OBX LSD for the B16 ??? I tried OBX website and also erzperformance here , and nothing !
Help me out. Guys !
Old Jan 16, 2010 | 01:21 PM
cibao2ner's Avatar
Default Re: obx lsd
obx lsd 9000 is the same for b16 and ls trannies they use the same bolt pattern..i got mines in ebay for 300 bucks..
Old Jan 16, 2010 | 04:26 PM
dicxonjim's Avatar
Default Re: obx lsd
Ohh okay ,, but can you tell me who the seller is , you got it from !! Thks
Old Jan 16, 2010 | 05:38 PM
REEMB18C1's Avatar
Default Re: obx lsd
good info guys lets keep it in the trans/drivetrain forum
Ti3d in
Transmission & Drivetrain
Mar 16, 2009 02:46 PM
GReddy SI
Jun 18, 2008 05:36 PM
unknown0001
Jan 18, 2006 01:43 PM
bracket 4 life
Feb 13, 2005 10:05 AM
