nos
Old Mar 11, 2005 | 09:48 PM
plink's Avatar
Default nos
i have a wet kit and im going to put it on a 00 civic si stock what shot should i run and still be safe.
Old Mar 11, 2005 | 10:59 PM
svpAMhatch's Avatar
Default Re: nos (p.o.l.)
200 shot
Old Mar 12, 2005 | 04:09 AM
FormulaGSR's Avatar
stock cluch doesnt like more than about a 50shot. If your not careful you'll fry it with that. As for the motor, depends on how big your ***** are.
Old Mar 12, 2005 | 04:25 AM
quicksol95's Avatar
Default Re: nos (svpAMhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svpAMhatch &raquo;</TD></TR><TR><TD CLASS="quote">200 shot </TD></TR></TABLE>
listen to him
Old Mar 12, 2005 | 04:45 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: nos (slow90hatch)
50 Wet. Anything more and you're going to need an MSD timing retard. Search
Old Mar 12, 2005 | 06:50 AM
captainh22's Avatar
I have a friend that put a 125 shot on a 3/4 wore out gsr motor it handled it like a champ it was in an ek and he turned a 13.03 sec 1320 it was a wet shot and i put a 75 wet shot on my h22 and my motor took it verrrrry well but I wore out my CM stage one clutch after 5 or 6 bottles. and I retarded my timing 4 degrees and had an af ratio in the 12's on a vafc. Is it a stock motor?
Old Mar 12, 2005 | 08:13 PM
plink's Avatar
also have itr cams and ECU,cm stage 3,vafc2
Old Mar 12, 2005 | 08:20 PM
Banned
https://honda-tech.com/zerothread?id=1171730
Read up on this thread.
Old Mar 12, 2005 | 08:51 PM
randbcustoms's Avatar
stock pistons can handle 125 shot however to keep it safe i tend to keep it at 100.. your problem is going to be timing.. with a 100 shot normally u just retard the timing 4 degrees.. but if you have a chipped ecu it probably has the timing advanced.. so make sure you account for this..good luck...if you don't spray it till second you should be good for a little while on a stock clutch.. depending on it's current condition..
Old Mar 13, 2005 | 01:01 AM
sleeping_sedan's Avatar
i have a friend thats using a 100 shoot on a JDM B16 with lil bolt on upgrades but he does have a race clutch tho .. so
player2z
May 2, 2021 11:06 PM
-805ER-
Honda Civic (2006 - 2015)
18
Apr 24, 2007 01:48 PM
superman336
Feb 1, 2007 08:19 AM
eg6rider
Mar 7, 2006 06:45 PM
aandDavidsaid
Dec 21, 2003 10:05 PM
