Nitrous and high compression motor
ok from what i heard from a friend of mine who builds nitrous cars, i can use my 12.5:1 compression motor with a set of nitrous cams and shot a 150 shot safely, is he crazy or is this possible my setup: minus cams
b18b golden eagle sleeved and block guard
eagle rods 12.5:1 Wiseco pistons
bored over to a 2.0L
GSR head JUN port and polish, custom valve springs
Z10 Girdle,
Oversized .5mm over Ferrera valves.
Toda cam gears, aem intake,
unorthodox crank racing pulley
MSD ignition
VAFC, msd wires, custom 1 3/4" primaries header with 3" collector
Victor X Intake manifold
RC 310CC injectors (i know ill need bigger but how big)
AEM fuel rail
SARD FPR
Chromoly ACT flywheel
ACT xtreme PP and 6 puck clutch
can i run nitrous safely, or do i need low compression
please answer only if you are sure, from trying it before, or if you know the answer, not if you think it would be ok, im seriously considering this option, and runnning 150 shot to a 240 hp allmotor car....
Z10 Girdle,
MSD ignition
AEM fuel rail
SARD FPR
smart and possible are 2 entirely different things. i wouldn't go higher than 10:1 or 10.5. but that is because the people i am familiar with using nitrous successfully go by those numbers.
Lower compression is better for nitrous setup motors.
Suprdave
lsbrasil
32
May 21, 2007 12:52 PM
scUba-stEve
14
Oct 14, 2004 10:17 AM
just keep it rich and timing well retard
