Nitrous help with a built LSV.
Old Feb 10, 2008 | 03:51 PM
ghost ride the whip's Avatar
Default Nitrous help with a built LSV.
Well i want to know if i could or even schould run Nitrous..
i am still building the motor but i will have it in a car with in 3 weeks..
heres my set up!
MY HEAD,
PORT\POLISH IM PORTED TO MATCH HEAD
SUPER TEC VALVES NITRADE COATED FLAT REV
SUPER TEC DUAL VALVE SPRINGS
SUPER TEC TITANIUM RETAINERS
RC440 INJECTORS
VIC X IM.
RMF DRAG HEADER
BUDDY CLUB SPEC 4 Cams
MY BLOCK.
Darton Sleeved LS bored out to 85mm, Eagle Rods,
CP 12.5-1 Compression pistons, 89mm LS Crank ITR Oil
and Water Pump Oil
Tranny.
USDM ITR WITH 4.4 FINAL drive.
ls 5th
ACT clutch and flywheel.
HONDATA S200.
Old Feb 10, 2008 | 03:52 PM
Default Re: Nitrous help with a built LSV. (ghost ride the whip)
http://www.flickr.com/photos/justjoey06/2253200739/ THE HEAD.. the block is getting built and will have it back on the 15th
Old Feb 12, 2008 | 01:39 AM
mxracer145's Avatar
sure, you can spray it if you want to.. as long as you have the right timing, the right heat range spark plugs, and use at least 93 octane fuel. it would be just fine. just dont do a dry nitrous kit. it has to be the wet kit so you have a way to get the extra fuel you will need. dry kits will make the engine run lean and could melt it down...
Old Feb 12, 2008 | 10:21 AM
OMG B16's Avatar
I dont see why not. My friends 12.5:1 H22(stock sleeves) was on a ~200shot for years. ITs now on a 160 shot, because of the single nitrous kit instead of two.
The car made 420whp on the ~200 shot
Old Feb 12, 2008 | 10:27 AM
.CUBISH.'s Avatar
Default Re: (OMG B16)
i wouldnt spray on 93 with that compression...
Old Feb 12, 2008 | 10:34 AM
OMG B16's Avatar
Default Re: (.CUBISH.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt spray on 93 with that compression... </TD></TR></TABLE>
Truth.
Since you didnt mention what gas u were using, i didnt mention anything either. Good gas is a must.
Old Feb 12, 2008 | 01:29 PM
nonvtecallmotor's Avatar
Spray the **** out of it.
Old Feb 12, 2008 | 02:34 PM
PHDZINE's Avatar
Default Re: (nonvtecallmotor)
I think the Victor X manifold is a liitle to much for what your doing but thats only my $0.02
Old Feb 12, 2008 | 03:20 PM
b18avtec(A!!M0TOR)'s Avatar
i have a very similar set up and sprayed 50 wet,and got great results, hella fun
Old Feb 12, 2008 | 03:29 PM
.CUBISH.'s Avatar
Default Re: Nitrous help with a built LSV. (b18avtec(A!!M0TOR))
my 84x89 b20vtec peformed well with the victor x.... had 12 to 1 compression, skunk stage 3's, etc.. made 240hp 158trq...carried power to 9800
Old Feb 12, 2008 | 03:47 PM
Default Re: Nitrous help with a built LSV. (.CUBISH.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">my 84x89 b20vtec peformed well with the victor x.... had 12 to 1 compression, skunk stage 3's, etc.. made 240hp 158trq...carried power to 9800
same here, made really good power with victor x
bertsb18hatch
Sep 15, 2009 08:41 PM
prhatch124
Jan 13, 2008 12:31 PM
Cali4niaEk9
Dec 3, 2006 09:05 PM
HYBRID FREAK
Jul 12, 2006 07:08 AM
