need help with my setup
Old Dec 18, 2007 | 02:23 PM
adam1027's Avatar
Default need help with my setup
i have b18c1 with 84mm cp pistons, crower rods, stock crank, darton sleeves,head been done with ferrea valves, crower springs and retainers, stock cams, jg victor x intake with 70mm bdl throttle body, percision injecters and areomotive feul pump and bdl regulator and a pro wastegate and hondadata s300. Last yaer I ran a cheap gt 42 turbo, this year I got a percicion gt4294rl and need to know what else I need to use this turbo .Do I need another wastegate? i'm using an e boost for boost control, the car ran10.72@148.12mph at Milan last year.
Old Dec 18, 2007 | 02:27 PM
kermit97's Avatar
sound pretty good set up, wow good run and how much boost u runnng with the old turbo.
Old Dec 18, 2007 | 03:08 PM
civic eg's Avatar
Default Re: need help with my setup (adam1027)
It also ran 10.2XX over a year ago!!!
Old Dec 18, 2007 | 03:34 PM
adam1027's Avatar
Default Re: need help with my setup (civic eg)
30-32 psi
Old Dec 18, 2007 | 05:34 PM
huertascoupe's Avatar
its not just the motor that will help you with times theres other things that need to be looked at , weght suspension , slicks , to name a few sounds like a strong set up , might just need dial in . good luck with improving your times
Old Dec 18, 2007 | 05:53 PM
adam1027's Avatar
Default Re: need help with my setup (huertascoupe)
I'm using 24.5 mt with omnipower drag suspension and traction bars,my car weighs 2405lbs.also using clucth master fx700 clutch and stage 5 axles
Old Dec 19, 2007 | 05:03 AM
Clayton's Avatar
H-T Administrator
25 Year Member
up for a friend
Old Dec 19, 2007 | 05:25 AM
AllMotorMark's Avatar
not that this is a big thing but a bigger throttlebody is gonna help also , go with a 75 to 80mm but thats probly not as big a sugestion your looking for, really you have to show a slip with a breakdown of your runs, maybe its how your boost is comming on in 1st and second? your running a staged boost controller? maybe its your gearing , maybe its the tuning ...the car is fast so maybe its the liitle things that can help , you need tog ive us more info, a breakdown of the slip would be a big help.
Old Dec 19, 2007 | 09:14 AM
adam1027's Avatar
Default Re: need help with my setup (AllMotorMark)
I have yet to run the new turbo...it isn't even on the car yet.What I really want to know is if the set up I have now will handle the new turbo
would I need another waste gate or should one be enough?
Old Dec 19, 2007 | 09:16 AM
Turbo-charged's Avatar
ditch that E-boost controller and either use the S300 boost control or an NLR.
boost control is EVERYTHING at these power levels.
a second wastegate def. wouldnt hurt. you want to be able to keep the boost low in the lower gears.
Old Dec 19, 2007 | 09:36 AM
BLK JDM's Avatar
Default Re: need help with my setup (Turbo-charged)
What turbo manifold are you running?
Old Dec 19, 2007 | 09:40 AM
adam1027's Avatar
Default Re: need help with my setup (BLK JDM)
It is a custom made front mount manifold off of Paul Bwahans 8 sec Hot Rod style civic
Old Dec 19, 2007 | 10:44 AM
if your looking to just slap it on ya with a new tune it will work...but there is room for improvement elsewhere
Old Dec 21, 2007 | 08:36 AM
Clayton's Avatar
H-T Administrator
25 Year Member
So are you making any progress Adam? There's a few people in here that'll help you, all you have to do is ask man. Turbo Charged is a great resource, as is All Motor Mark. Mark's pretty close too man
newbiecakes
Feb 8, 2008 05:11 PM
Del Sol on Steroids
Mar 19, 2006 08:55 AM
a1320addict
Dec 26, 2005 10:39 AM
kaj
May 27, 2003 10:10 PM
gcajnr21
Jan 29, 2002 08:22 PM
