MSD distributor problems??
Old Jun 7, 2007 | 06:15 AM
BLK JDM's Avatar
Default MSD distributor problems??
Ok I'm posting this for a good friend of mine who isn't a member of the board. Well his 99 EK street car(built B18c boosted 500whp) started giving him ignition problems 2 weeks ago at test-n-tune. So he went out and purchased the MSD distributor and ignitor. He installs it and his hatch will rev to 6krpm and then just fall flat on it's face and the tach will jump around.
So he takes the MSD distributor and ignitor off of his race car(99 SI) and the same exact thing. So he thinks maybe the Hondata S200 messed up so he gets a new chip and uploads his old map. Same thing. He calls MSD and they say he needs to ground the MSD straight to the battery. So he grounds it-Same problem.
So now he puts back the stock distributor and the car revs fine and all now. We're kind of lost so any input would be appreciated. Do you need to give your Ignition box direct power from the alternator or battery once you go w/ the MSD distributor?? What are we doing wrong, it should be a straight plug in procedure, right??
Old Jun 7, 2007 | 06:50 AM
SpeedDreamz.com's Avatar
Default Re: MSD distributor problems?? (BLK JDM)
what ignition box are you using?
Old Jun 7, 2007 | 07:15 AM
turbotypeR@SPEC's Avatar
25 Year Member
i had the same problem.i sent it back to msd and they kept it for a long time.they supposedly found something with the communication between the dist and the ignitor and fixed it.i installed an m&w ignition box while it was gone and it worked fine with the stock distributor,so i sold the msd distributor when it came back
Old Jun 7, 2007 | 07:55 AM
BLK JDM's Avatar
Default Re: MSD distributor problems?? (turbotypeR)
I'm using the 6AL!!!
ciscoscivic's Avatar
pull the cap and check the rotor screws. they loosen up all the time. also, check the pin that holds on the gear it likes to push out.
Old Jun 7, 2007 | 07:56 AM
Default Re: MSD distributor problems?? (ciscoscivic)
you should have the msd box wired to the b+ and b-
Old Jun 7, 2007 | 08:34 AM
JDogg's Avatar
basicly those things are pieces of crap
we have 3 dead ignitors
we have 2 distributors that had the pin come out
3 or 4 had the screws that hold the rotor on come out
2 have a failure in the cam/crank sensors so they wouldnt rev
they work really good when they work, but most of em dont work. i think i may have sold 2 in the last 5 months that havent had to be exchanged/warrentied.
Old Jun 7, 2007 | 09:12 AM
BLK JDM's Avatar
Default Re: MSD distributor problems?? (JDogg)
Damn probably just going to return it to Summit. We disconnected the 6AL and still the same thing.
We pulled one apart and the screws were loose but the other one was fine. Still both of them acting the same way?? That's the weird thing.
Old Jun 7, 2007 | 09:33 AM
DaveF's Avatar
i could be totally off...... but...... for some reason, i recall something about some wiring being backward on the msd unit ? pull it apart and follow the wires to see what sensor is which. then make sure they are in the correct location on the plug.
Old Jun 7, 2007 | 11:23 AM
BLK JDM's Avatar
Default Re: MSD distributor problems?? (dturbocivic)
I'll look into that tonight.
Old Jun 7, 2007 | 11:48 AM
25 Year Member
when i had mine,i was using a 7al2.i tried it with and without the ignition box and it did the same thing.it would shut completely off and back on.sometimes for a second and sometimes for several seconds.it had a mind of it's own
Old Jun 7, 2007 | 12:00 PM
tony1's Avatar
My Spark Disappeared...
Old Jun 7, 2007 | 01:02 PM
BLK JDM's Avatar
Default Re: MSD distributor problems?? (tony1)
Thanks for the great technical insight Tony!!!hahahaha
Old Jun 7, 2007 | 01:20 PM
vtekthis's Avatar
Are you using the ing driver?
Old Jun 7, 2007 | 01:54 PM
BLK JDM's Avatar
Default Re: MSD distributor problems?? (vtekthis)
no injector driver if that's what you're asking.
Old Jun 7, 2007 | 02:10 PM
vtekthis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLK JDM &raquo;</TD></TR><TR><TD CLASS="quote">no injector driver if that's what you're asking.</TD></TR></TABLE>
im sorry lol i meant the associated coil driver for the distributer
Old Jun 7, 2007 | 07:38 PM
b16wacko's Avatar
I think you should listen to Tony's advive, just stick with the stock dis. just get some nology wires they work really good
Old Jun 8, 2007 | 02:51 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">
im sorry lol i meant the associated coil driver for the distributer</TD></TR></TABLE>
der der der der
Old Jun 8, 2007 | 02:59 AM
wade's Avatar
Default Re: (b16wacko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16wacko &raquo;</TD></TR><TR><TD CLASS="quote">I think you should listen to Tony's advive, just stick with the stock dis. just get some OEM/NGK wires they work really good</TD></TR></TABLE>
Old Jun 8, 2007 | 05:09 AM
BLK JDM's Avatar
yeah he's using the coil. Last night one of the bolts came apart in one of them so 1 down and 1 to return. Well actually he's gonna try to return both but it's sad how you buy something to alleviate a common problem and it leads you down a worse path. He's more than likely gonna get the M&W from Tony1 x2 one for the street car and one for the race car!!
Thanks for everyone's advice!!
Old Jun 9, 2007 | 03:25 AM
DaveF's Avatar
the problem cant be the distributer, you do realize the fastest FWD cars are running MSD distributers ! (Marty Ladwig, Jason hunt, Gary Gardella, Brian Ballard) the GM cars seem to have no problem using msd equipment.
Old Jun 9, 2007 | 04:00 AM
BLK JDM's Avatar
Well it's just like AC Delco and AutoLite spark plugs-they work great in your domestic but they do the shittiest job in your import. It's soo hard for me to buy those parts when I'm working on my Tahoe b/c I've been driving imports all my life and I've been programmed to think AC Delco/Autolite=****!!!
I just don't think they spent enough time on R&D for the Honda distributor, but that doesn't mean all their parts are junk.
Old Jun 9, 2007 | 05:51 AM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">the problem cant be the distributer, you do realize the fastest FWD cars are running MSD distributers ! (Marty Ladwig, Jason hunt, Gary Gardella, Brian Ballard) the GM cars seem to have no problem using msd equipment.</TD></TR></TABLE>
i cant tell if thats sarcasm or not... but from what i saw they use the msd to distribute spark, but not to get the cam/crank pickups, etc...
and im sure the race car parts are inspected much better than the garbage that gets sold to us.
and have you ever looked at nascar.. they have 2 6al boxes with a selector switch so that when one goes out they hit the switch and the other comes on. so they dont even expect one msd box to last 500 miles
Old Jun 9, 2007 | 06:45 AM
AutoLab's Avatar
be careful sharing your experiences with MSD distributors around here, I did so last week and got my head cut off. I mean there are 700whp cars on here that use it so it must be great right!?
Old Jun 9, 2007 | 06:47 AM
JDogg's Avatar
Default Re: MSD distributor problems?? (AutoLab)
i dont doubt that there are tons of 700hp cars with the msd dizzy.. the first 10 i sold never had any problems and we have made tons and tons of power with em
like i said, they work great when they work
