May FS Thread
Old May 20, 2014 | 09:08 PM
  #26
Zer0_SpeedWorks's Avatar
Default Re: May FS Thread
BRAND NEW Racepak Haltech interface module cable for IQ3
I bought it for 375$ plus shipping.
I want 325 shipped and pp'd
PAYPAL only!
Old May 22, 2014 | 07:59 AM
  #27
turboek1's Avatar
Gato B16/18c5 4 injector manifold(only). Great shape, no cracks. Comes with rail. $675 shipped. Paypal or USPS MO accepted.
Old May 24, 2014 | 03:25 PM
  #28
h0od's Avatar
Got some h22 turbo parts from my build I never got to finish . I'm located in Brooklyn nyc . Prices don't include shipping . You could reach me thru the PM or thru email which is h0od11306@gmail.com
Prices are somewhat negotiable
H22 benson block from laskey racing $2800
Brand new never used
H22 endyn full race port and polish with bronze guides and skunk2 valves $900
H22 head with full valve train ferrea valves retainers keepers skunk2 pro1 cams with pro cam gears $2000
Sheepey h22 twin scroll top mount.
Brand new never used $700
H22 aem coil pack with emp and twin fire $500
H22 valve cover with an fittings $150
H22 golden eagle intake manifold brand new with golden eagle fuel rail $550
Greddy Timing Belt $100
H22 moroso pan used with brand new oil pick up $300
Saenz transmission h22 gear set brand new $3000
Precision turbo 6765 DBB
$1000
Spec twin disc used $400
golden eagle oil sandwich with stainless steel turbo oil line (earls) $125
alternator relocation bracket to fit the top mount $ 70
Old May 24, 2014 | 10:10 PM
  #29
Kelvin Racing's Avatar
Decided I only need 1 racecar part out
Precision 6768 h cover T4 .96 exhaust housing 1200obo
8 injector gato intake manifold gsr brand new 850obo
Mfactory lsd 600$ brand new in box
Mfactory 3.07 1st gear 260$
Synchrotech 1-5 carbon synchros 250obo
Clutchmasters twin disc used 600$
Fluidampr street pulley 300obo
Tial 46mm wastegate 325$
Skunk2 tuner3cams 450obo extremely low mileage
Moroso oil pan 5.5qt 200$
84.5mm honda oem headgasket 90$
Benson sleeve blueprinted an balanced gsr- 84.5mm boreWiseco 10:5:1-10:8;1 upgraded cp wrist pins Oliver I beam rods 0 miles on build. 3000 obo
Gsr b18c1 ported by Paramore Motorsports - supertech dual valvesprings and titanium retainers, supertech flat faced valves, ferrea valve stem seals, ferrea bronze valve guides, skunk2 cam seals.
1500$
Fastest reply text me at 352-299-4653
Old May 25, 2014 | 09:27 AM
  #30
dcmatt's Avatar
Helping my tuner cleanout the shop and get some money up for a dogbox setup. Prices do not include shipping and paypal fees. Parts are available for local pickup in Indian Trail NC @ Driven Performance. 7042583216
Bullseye S372 w race cover T4 1.25 divided 4" Vband brand new never even mounted $1150
Precision 6266 T4 .96 nondivided vband housing has around a 1000 miles $900
precision 4088 t4 .81 undivided 3"vband 67mm turbo. Engine let go and damaged the turbine wheel. Still buikds boost and works. Good budget unit or for rebuild $450
osgiken twin disc clutch. Used. Will need a set of disc.$600
Type R type r valves buddy club p1 springs and retainers type r red valve cocer with 2 -10 bungs welded. $1000
Skunk 2 tuner 1 cams b series vtec 1500 miles $450
AFI D series topmount T3 44mm vband wastegate NEW $800
AFI H22 bottom mount T4 44mm vband gate NEW $700
AEM V1 obd2b b series 99-00 em1 or 00-01 integra $450
Custom 95mm b series stroker kit. 84mm custom CP pistons with upgraded wrist pins. Brian crower I beam rods. 8.8:1 compression. Dyno time and 17 hits at the track. $1800
Gsr Built Tranny. Syncrotech Master rebuild kit. All new bearings, seals, synchro hubs, synchro sleeves, and carbon syncros. Also has a quaife drag lsd. Only dyno time since rebuild $2000
Old May 25, 2014 | 07:47 PM
  #31
JDM JEFFREY's Avatar
Sold
Old May 26, 2014 | 07:43 PM
  #32
Almtrhb's Avatar
MTX-L Innovate Wideband Used, In box with instructions works flawless like brand new $110 Shipped US " SOLD "
NOS Dry kit with multiple jets, 10lb bottle with bottle stands $260 Shipped US
Speed Factory SCHA w/ Heavy Duty Spring $360 Shipped US "SOLD"
Precision Billet GT4272r Ball bearing turbo 1.28 AR housing, Turbo still works but a valve hit the turbine wheel. $1000
Paypal add the 3% to Total Or Text me 714-388-7303
Old May 27, 2014 | 04:23 AM
  #33
jc@douglas's Avatar
FS BNIB Moran Motorsports 325lb injectors for E85/ethanol
$1200 firm shipped
does not include fuel filter
Old May 27, 2014 | 08:53 AM
  #34
turbociv910's Avatar
mw pro 14- $ 550 -Works great, used in a 600whp K Series
Motec E888- $900 Used for 3 RTA seasons, Will supply serial number to interested persons.
Old May 28, 2014 | 08:10 AM
  #35
DaFredsta's Avatar
Selling a slightly used precision 6766 T3 turbo with a .82ar hotside, 3inch vband asking 1000obo plus PayPal/shipping... Text is best (775) 762-9837
Old May 28, 2014 | 08:50 AM
  #36
turbotypeR@SPEC's Avatar
25 Year Member
All prices are + shipping and paypal fees.
Rolling shell-$10k non neg price! Don't ask! This is a crackhead price! 25.5 cert chassis, Progress custom coil over setup, custom front, shaved bay, custom flat paint by Goolsby customs, fiberglass tailgate, CCC spoiler, carbon hood, weld ...rear skinny's, Exospeed 15x9 fronts with 26x9 toyo's, Kirky seat, stroud window net, custom staging brake, stroud parachute, sumped tank, Mfactory LCA, and I don't know what else I'm forgetting. I also have enough carbon wrap to do the hood, tailgate, and rear diffusers. I will do that before it leaves here.
Chase Bays b series mil spec harness-$1000
New Honda engine bearings-$125
There are 26 bearings in there. Probably $250 worth.
15 used Crower valve spring retainers. 1 missing for some reason.-$75
AEM fuel rail for b series with sample valve and SX regulator-$150
Hks bov-$50
Unknown intercooler-$50
F22 drag turbo manifold-$50
BDL 70mm throttle body-$200
MSD 75314 4cyl ignition box w traction control-$500
Stock B18C1 longblock, new cam seals, rear main seal, oil pan gasket, valve cover gasket, oil pump, water pump, tensioner, and timing belt. Was gonna be my beater engine, do it's got everything you need new to make it run for a long time. $1100 timing belt and cover not in pic. also, will have stock oil pan and pickup installed.
Old May 29, 2014 | 04:02 AM
  #37
SR.4G.EJ-Dave's Avatar
Sold
Old May 30, 2014 | 09:55 PM
  #38
MoiMotorsports's Avatar
I have mh 13inch by 8.5 by 26 for sale 300
custom. Made radiator with overflow tank 12b12 300
(If u need one made contact me )
golden eagle main studs for gsr brand new in box I missing a washer make offer
U r alum b crank pully 60 obo
fiberglass eg front end fresh paint 500 obo
81mm wiseco 10to1 pistons used make offer
856 332 5450 call or text
Old Jun 2, 2014 | 06:47 AM
  #39
CHEETAH's Avatar
For sale in NY/NJ but can also ship:
All Motor - K-series: ASP Hood exit header and Avid Racing solid mounts for DC/EG chassis.
$1400 firm looking for quick sale. Header alone was $2100 and mounts were $600 when I bought new...also I need an EG carbon hood and call include my hood is 4/10 condition.
You can text or email me:
Nine one seven 27 three 443one.
Gbrtuning at aol dot com
crazes
May 28, 2015 09:54 AM
crazes
Mar 31, 2015 06:04 AM
crazes
Jan 3, 2015 03:11 PM
crazes
May 31, 2013 01:00 PM
crazes
Mar 31, 2013 01:56 PM
