master battery kill switch wiring schematic
Old Feb 26, 2007 | 03:04 AM
  #26
DaveF's Avatar
Default Re: master battery kill switch wiring schematic (93supercoupe)
here is how it is on my car. works great
Old Feb 26, 2007 | 07:36 AM
  #27
rip94delsol's Avatar
Default Re: master battery kill switch wiring schematic (dturbocivic)
geez thats pretty small there/\/\/\ mine blowing it up a lil bit...
also thats for a complete drag car with line lock and all... I was just wondering for a normal street car!
Old Feb 26, 2007 | 11:03 AM
  #28
DaveF's Avatar
Default Re: master battery kill switch wiring schematic (rip94delsol)
right click it, get the link then add .orig.jpg to the end of the link, it will blow up.
Old Feb 26, 2007 | 01:08 PM
  #29
thanks! not to computer litterate.....
Old Feb 26, 2007 | 01:14 PM
  #30
DaveF's Avatar
take this
http://www.imagestation.com/pi...a.jpg
put it in your browser.... open it.... then add .orig.jpg to the end of the link.
Old Feb 26, 2007 | 01:23 PM
  #31
Turbocivic94's Avatar
Dave I'm not trying to fly the car, just want a kill switch..lol
Old Feb 26, 2007 | 03:54 PM
  #32
tepid1's Avatar
Default Re: master battery kill switch wiring schematic (Turbocivic94)
For those who like simplicity.... aka Ruben
Old Feb 26, 2007 | 06:47 PM
  #33
Default Re: master battery kill switch wiring schematic (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">For those who like simplicity.... aka Ruben
Chris you might have to come wire this **** up, I'm little slow
Hit me up so we can meet, I need to put my **** together
Old Feb 27, 2007 | 03:03 AM
  #34
tepid1's Avatar
I'm finishing up my car now.... I'll give you a hand when I can.
Old Feb 27, 2007 | 12:11 PM
  #35
okay once again why is a fuse needed? There are fuses in the main fuse box(under hood) I understand if this a full drag car but on a street car is it neccesary or better to put 1 on.
I would understand that it might be better because maybe you dont want so high of an amperage going to a componet that might not be able to handle that kind of load....
Old Feb 27, 2007 | 07:00 PM
  #36
SC61HB's Avatar
Instead of a fuse you could use a breaker, just not sure what amperage. Maybe 100A? Someone clarify.
Old Feb 27, 2007 | 08:04 PM
  #37
AllmotorEH2's Avatar
holy crap i am suprised to see you post in this forum twotoe
Old Feb 28, 2007 | 03:12 AM
  #38
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rip94delsol &raquo;</TD></TR><TR><TD CLASS="quote">okay once again why is a fuse needed? There are fuses in the main fuse box(under hood) I understand if this a full drag car but on a street car is it neccesary or better to put 1 on.
you dont need it for a car that has the factory relay/fuse box underhood.. it already has, an 80 or 100 amp fuse in it. its the 1st thing the power goes through..
on a drag car, you are going to get rid of that relay/fuse box. so it would probably be smart to put an inline 80 or 100 amp fuse/breaker.
Old Feb 28, 2007 | 06:35 AM
  #39
Great, I knew the stock fuse box already had 1 I was just wondering why you would have to put another...
I understand that in a race car you take it out and therefore would need that fuse/breaker to control amperage!
Old Feb 28, 2007 | 07:20 AM
  #40
tepid1's Avatar
I understand that in a race car you take it out and therefore would need that fuse/breaker to control amperage! </TD></TR></TABLE>
It does not control amperage.... it limits excessive amperage past the rated fuse or breaker.
Old Feb 28, 2007 | 11:49 AM
  #41
RACEPAK's Avatar
and whats the purpose of this?
Old Feb 28, 2007 | 12:36 PM
  #42
Default Re: master battery kill switch wiring schematic (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">and whats the purpose of this?</TD></TR></TABLE>
when a car has a relocated battery or the vehicle runs 9.99 or faster a battery kill switch is mandatory!
Its in the rule book.
Old Mar 20, 2007 | 02:23 PM
  #43
kidkombo's Avatar
Default Re: (AllmotorEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmotorEH2 &raquo;</TD></TR><TR><TD CLASS="quote">holy crap i am suprised to see you post in this forum twotoe </TD></TR></TABLE>
sometimes i need more knowledgable knowhow to help me out with some stuff...
btw with my schematic i originallyposted i switched it so that all teh main feed wires like the remote terminal starter are allon the side where theyre directly onto the battery +.....the only wires that were modified were the alternator wire and the main fusebox wire.....run those on one side of the switch, on the other end, have two wires both going to the fuse box and viola' car is killed with the flick of a switch. if anyone wants me to make a diagram with the mods pm mehehe
btw when i switched this, the started i guess had a stronger signal and cranked over the car alot easier than how i had it before.
Old Apr 25, 2007 | 10:01 PM
  #44
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">
Hit me up so we can meet, I need to put my **** together</TD></TR></TABLE>
Bringing this back up. Where do you run your start wire and the other wire from the fuse block?
I need the easiest way to wire this dam thing up so I pass tech this weekend. I have not slept for a few days now and any help would be great. Thanks
boostedb20z
Mar 20, 2009 03:15 AM
philosofy1
11
Dec 8, 2007 09:33 PM
seen4ever
Jul 19, 2005 06:47 AM
flip1199
Jun 19, 2004 12:13 PM
