Liquid to Air intercooler??
Hey Guys
I need some help, Im thinking of using a LtoA IC on my new drag car that im currently in the process of building. Im new to them as ive only used FMIC's before. I would like to see how people have set these up, and how people have routed everything. I do not plan on using a heat exchanger as this will be a track only car.
I would also like to know what you use for lines, tank, and a pump??
Thanx alot
Modified by grand champ at 8:12 PM 10/8/2007
Thanx alot
Im just building it for fun, dont plan to be competitive and dont plant to race in any class. I just wanna shut up some muscle car guys around here as the fastest honda in our area is like high 11's so far. so i wanna be first in tens next year at the local track!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">Only illegal in some sportsman, he can use them all day in any other catagory, including Turbo 4 I believe</TD></TR></TABLE>
you mean sfwd ryan. should be ok in q16.
as for t/s everything must be under the hood. (if i remember)
I know you can run it in Hot-Rod, and Quick16 is essentially as long as its safe and meets general requirements, theres no 'class' requirements since its for cars that dont' fit into any other class, like my car. Its certainly not street legal, but its nowhere near quick enough to be competitive in HotRod and too light at < 1900lb with driver. I'm only looking for low 10s with 450ish whp, but the car isn't legal for SFWD since its not street legal.
But sportsman is also SRWD and PW/S
right but not all he hee.......
on a side note g/j on the single digits this year.
</TD></TR></TABLE>right but not all he hee.......
Precision turbo and engine is prolly where I would go to first, they can offer some pretty good tech info and lead you in the right direction.
Check them out im sure you’ll be happy with them.
http://www.precisionturbo.net
Where does one get a fancy plastic resivoir such as the one that comes with the vortech kit??
And do you actually fill the resevoir with methal alcohol and then just dump raw ice in, or do you contain the ice to itself, say in a bag, or use an ice pack or something, wont the ice clog up the pump??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grand champ »</TD></TR><TR><TD CLASS="quote">Where does one get a fancy plastic resivoir such as the one that comes with the vortech kit??
And do you actually fill the resevoir with methal alcohol and then just dump raw ice in, or do you contain the ice to itself, say in a bag, or use an ice pack or something, wont the ice clog up the pump??</TD></TR></TABLE>
I think i got my tank from plastic-mart.com. However i really want to make a fabricated aluminum one with -10 fittings and line. With a internal seperator for the coolant and ice. As well a little something else i'm working on.
My current set-up has coiled line in the tank the the inlet draws in between the line. And also a screen over the inlet. So it's nearly impossible for the line to become clogged. My pump flows really well as i have alot of flow in the tank itself. Constantly cycling around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grand champ »</TD></TR><TR><TD CLASS="quote">What is the prime fluid to use, Methal Alcohol? or just water?
Methal will absorb more heat will it not?</TD></TR></TABLE>
Windsheild washer fluid and ice has worked well and is fairly cheap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grand champ »</TD></TR><TR><TD CLASS="quote">Would love to see some pics of your set up!!</TD></TR></TABLE>
I pm'd you one.
I pm'd you one.
whole9
May 3, 2007 07:08 AM
