Launch control question.
Old Apr 26, 2005 | 11:29 AM
Root79's Avatar
Default Launch control question.
There are some simple ways how to DIY launch control. Or this function only in advanced management units?
Thanks
Old Apr 26, 2005 | 12:11 PM
Hybrid96EK's Avatar
Default Re: Launch control question. (Root79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">There are some simple ways how to DIY launch control. Or this function only in advanced management units?
Thanks</TD></TR></TABLE>
Yeah. Chip your ECU. Buy a burner. Navigate to http://www.pgmfi.org. Learn. Empower yourself.
Old Apr 26, 2005 | 12:30 PM
Root79's Avatar
Default Re: Launch control question. (Hybrid93Eg)
Have burner, crome(free soft), already did RTP on OBD-1 base.....
Thats all clear!
But! Did some search in pgmfi.org did not find anything. Or maybe search wrong.
Old Apr 26, 2005 | 12:34 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">Have burner, crome(free soft), already did RTP on OBD-1 base.....
Thats all clear!
But! Did some search in pgmfi.org did not find anything. Or maybe search wrong. </TD></TR></TABLE>
If you had seriously spent any time learning the software, you would have figured this out by now. Look for the "Add extra features" plug in on pgmfi.org. Use it on a P28/P30 based rom. Go to the option tab in Crome, tell me what you see at the bottom.
Now go register Crome.
Old Apr 26, 2005 | 12:39 PM
Root79's Avatar
My country not support Pay Pal. So, that's why I still do not have CROME full version. Any help needed. I already write mile to Crome maker, waiting for answer. Some different way to pay for license.
Old Apr 26, 2005 | 12:43 PM
Root79's Avatar
"Add extra features" where it is on pgmfi.org?
Old Apr 26, 2005 | 12:47 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">"Add extra features" where it is on pgmfi.org?
Took me less then 30 seconds to dig this up. Come on, put some effort into it. PLEASE.
http://forum.pgmfi.org/viewtopic.php?t=4228
Root79's Avatar
I can see in option tab:
rew limit
target idle.....speed limit
Old Apr 26, 2005 | 12:53 PM
Root79's Avatar
Could you explain me more closer please!
What is FTL/FTS?
AAAAAAAAAAAAAAAAAAA I see! Full throttle launch......FTL
As I'm not English speaking, I typed my question in search not so correct.
Old Apr 26, 2005 | 01:03 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">Could you explain me more closer please!
What is FTL/FTS?
As I'm not English speaking, I typed my question in search not so correct. </TD></TR></TABLE>
Good. You found it. You're set.
Old Apr 26, 2005 | 01:05 PM
Root79's Avatar
I can't add .js file!
Old Apr 26, 2005 | 01:11 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">I can't add .js file!
Of course not. You don't add the java script file, you add the .CPF file.
Old Apr 26, 2005 | 01:17 PM
Root79's Avatar
What to do?
Old Apr 26, 2005 | 01:28 PM
Root79's Avatar
Can't get it work, can't add js file. it is js file, but when try to instal it it shows without .js name. Just add extrafeatures.
Old Apr 26, 2005 | 01:34 PM
Hybrid96EK's Avatar
You have to download the whole file and then extract it. I know there is a CPF file in there, I am looking at it now.
Old Apr 26, 2005 | 01:37 PM
Root79's Avatar
GOT TO WORK!!!!
BIG THANKS!!!!!!
Old Apr 26, 2005 | 01:41 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">GOT TO WORK!!!!
BIG THANKS!!!!!!</TD></TR></TABLE>
Awesome.
Old Apr 26, 2005 | 01:58 PM
Root79's Avatar
How I understand this extra features will work all the time? I mean, i'm driving with crome bin every day. So, when go to race I need to connect with ECU and resave my bin with this plugin?
Old Apr 26, 2005 | 02:13 PM
Hybrid96EK's Avatar
Dude. No. Install the plug in, set the launch control where you want. Make the chip. Leave it in, drive around. its not going to do jack until the car is at a stop, then it lowers the rev limiter. Simple as that. There is no need to have multiple chips.
Old Apr 26, 2005 | 02:28 PM
Root79's Avatar
So, it it works only when car stop.
The car is stopped, I'm pushing clutch pedal then shift 1 gear. Push on accelerator. Then revs will hit till my LC rev value. OK?
Yep! Simple!
Old Apr 26, 2005 | 02:43 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Root79 &raquo;</TD></TR><TR><TD CLASS="quote">So, it it works only when car stop.
Yep! Simple!
Yeah, thats how it works. Its not going to hurt anything to leave it on the chip.
Root79's Avatar
I'm doing everything on this NA B20VTEC(stock) hatch:
Last Saturday we did 10.383 for 200m (half of 1/4 mile)
Without slicks, LSD, stock clutch disk and no FTL or FTS. Just P30 ecu chiped with B18C1. I'm going to order R-500 PLX, they still not sell them, only preorders sell out.
So, waiting. Next competitiont at 15 of may.
Old Apr 26, 2005 | 02:49 PM
Hybrid96EK's Avatar
10.3 in the 1/8th mile? Is the elevation up there horrible or something? I run 9 flat in the 1/8th on my old setup and thats nothing special.
Old Apr 26, 2005 | 02:55 PM
Root79's Avatar
Jep! There are only 10 degrees (Celsius) outside. And we run with old Fulda tires.
We are going to use Bridgestone slicks. Is 225/50/R50 not be too big? I can get them new by good price. Clutchnet ceramic disk plate. And FTL with FTS.
Old Apr 26, 2005 | 02:57 PM
Root79's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">10.3 in the 1/8th mile? Is the elevation up there horrible or something? I run 9 flat in the 1/8th on my old setup and thats nothing special.</TD></TR></TABLE>
What was your old setup?
