Launch Control Device
Old Sep 7, 2011 | 03:26 PM
DraginX's Avatar
Default Launch Control Device
Came across this on Magnus's site and was wondering if anyone runs them, and what are everyones thoughts on them?
http://magnusmotorsports.com/product...control-device
Looks like it could help make launches more consistent by aiding in preloading the clutch to the exact point you want.
P.s. I did a search but came up with very little on this product.
Old Sep 7, 2011 | 04:05 PM
NY GsR's Avatar
Default Re: Launch Control Device
good old pre-loading does it for me, 568 with stock axels havent broken one yet
Old Sep 7, 2011 | 07:44 PM
vectorsolid's Avatar
I've seen them listed before. Always wondered about them. Interesting idea.
Old Sep 8, 2011 | 02:52 AM
DraginX's Avatar
I think it would help, and would be easier on the clutch also. No one has any input on these?
Lets get a discusion started, pros, cons, diy solutions that you personally use, etc.
Pros:
consistent preloading on launch
easier on clutch
with proper setup preloading saves the driveline
Cons:
could be tricky to get setup
pricey for what it actually is
DIY ideas:
Looks like a line lock with some sort of adjustable bleed off valve.
Old Sep 9, 2011 | 02:44 AM
DraginX's Avatar
No one has any input on these at all?
Old Sep 9, 2011 | 04:22 AM
tepid1's Avatar
You could make that yourself for less than $100.
Plus, tilton has a flow restrictor that is only $75 (if I remember right) and that works pretty well.
Old Sep 9, 2011 | 04:54 AM
tony1's Avatar
$185 or so for the tilton flow control valve.
Old Sep 9, 2011 | 05:10 AM
061000rr's Avatar
cons, if you use your clutch to shift you will have slow shifts due to the slow engagement
Old Sep 9, 2011 | 07:26 AM
roadracer4life's Avatar
I made one from basically the same exact valve and line lock valve.. I had my AEM only slow the clutch release for the launch and then it works like a normal clutch after the launch.. It worked pretty well for the first few times I used it then I pulled the trans and bought a glide..
-Sam
85mmek9
Mar 21, 2012 01:03 PM
boostedBLUfg2
Apr 3, 2011 08:01 PM
twkdCD595
Mar 17, 2008 02:15 PM
Hondasaurs
Oct 25, 2002 03:26 PM
