!!!!Kaizenspeed does it again!!!
Old Mar 14, 2013 | 01:35 AM
zakura R's Avatar
Default !!!!Kaizenspeed does it again!!!
Good **** guys nice parts
Old Mar 14, 2013 | 04:12 AM
MR.johnson's Avatar
Default Re: !!!!Kaizenspeed does it again!!!
that rear setup looks nice.
Old Mar 14, 2013 | 05:21 AM
98vtec's Avatar
moderator emeritus
Gotta love these guys!
Old Mar 14, 2013 | 06:44 AM
tepid1's Avatar
But it still uses the rear LCA....
Looks nice though.
Old Mar 14, 2013 | 06:57 AM
98vtec's Avatar
moderator emeritus
Looks nice though.
So?
Some race rules require the rear suspension to retain all factory mounting points and this does just that.
Old Mar 14, 2013 | 07:00 AM
JJsMotorsports's Avatar
I love this, finally some thing simple and effective!
Old Mar 14, 2013 | 07:36 AM
sohc95vtec-t's Avatar
Very nice looking piece!
Old Mar 14, 2013 | 07:40 AM
Zer0_SpeedWorks's Avatar
That really looks good!
Old Mar 14, 2013 | 07:52 AM
crazes's Avatar
Moderator
looks good.
We need to have some tech involved into this or I have to close it because then its just adverising
Old Mar 14, 2013 | 08:02 AM
98vtec's Avatar
moderator emeritus
I believe ahobbs posted on FB that the whole setup with the calibers dropped 50lbs. Thats a pretty serious drop.
Old Mar 14, 2013 | 08:56 AM
ESP.net's Avatar
About time we start catching up to the v8 world
Old Mar 14, 2013 | 09:09 AM
Divers's Avatar
Tech is here... I'll answer all question you guys may have. Fire away
Old Mar 14, 2013 | 09:13 AM
heavy duty's Avatar
Can it be made to stock wheel base? Can it also push the wheel out to stock. Not tucked in like other kits.
Old Mar 14, 2013 | 09:14 AM
061000rr's Avatar
will you be able to make a provision to meet the ogs rule book? some kind of braket on the front to bolt to the front toe adj bolt hole?
Old Mar 14, 2013 | 09:34 AM
GEN2 LS's Avatar
Loved
misleading title, I was expecting to see a new 1/4 mile record I know I wasn't the only one who felt this way lol.
Old Mar 14, 2013 | 09:43 AM
98vtec's Avatar
moderator emeritus
The product in the picture goes on the rear
Old Mar 14, 2013 | 09:49 AM
tepid1's Avatar
Originally Posted by 98vtec
So?
I understand, but this doesn't look like it uses the OEM toe mount.
If you use the factory LCA mounting point then the only way to lengthen the arm is by offsetting the hub which affects suspension geometry. That's why I ask, wiseass.
I'm not bashing it. In fact, I love the innovation these days.
Old Mar 14, 2013 | 09:59 AM
98vtec's Avatar
moderator emeritus
I would be interested in hearing how the wheel base is adjustable.
Old Mar 14, 2013 | 10:01 AM
tepid1's Avatar
Via that threaded heim joint front mounting point.
Old Mar 14, 2013 | 10:15 AM
98vtec's Avatar
moderator emeritus
Ah, i didnt even notice it lol. How would this effect the lower control arm? I know there will be a window the bushings will allow the lower control arm to move without binding up but what is that window?
Old Mar 14, 2013 | 10:20 AM
tepid1's Avatar
You'd have to have some custom LCA's. You can maybe get +- 1/4" before it's an issue.
Old Mar 14, 2013 | 10:33 AM
redboost10's Avatar
Is that legal? To lengthen wheelbase
Old Mar 14, 2013 | 11:08 AM
h-duced's Avatar
SICK!!
Old Mar 14, 2013 | 12:23 PM
jdm inc's Avatar
What wheel bearing does it use! Oem?
Old Mar 14, 2013 | 12:55 PM
SR20S13's Avatar
Looks like a lot like a myers rear suspension
