June FS Thread
Figured I would post this here for the forced induction crowd. I don't really have a need for all of this adjustability for my current setup. After getting it professionally installed, I drove around for about 2 days until I realized it's just too much for my daily driver lol. Comes with everything that the unit would come with if bought brand new. Works with Hondata S300, K-PRO, Flash PRO. ASKING $650 SHIPPED! Thank you for looking.
Attachment 531053
Attachment 531054
Boxed up ready to go.
Attachment 531055[/QUOTE]
Attachment 531053
Attachment 531054
Will not ship fuel setup or radiator
MSD Digital 6 -- $200
Dual Bosch 044 setup -- $500
-Aeromotive fuel pressure
-Kinsler Stainless steel Fuel filters
-Aeromotive Y
-Custom Fuel rail
-Lines (some wear)
--8an feed to pumps
--10an feed rail and FPR
--8an return
Twin Fire with CBR coils -- $350
Fluidyne radiator $150
B-Series Scatter Shield $100
Kill Switch Setup (what you see is what you get)
-Aeromotive Y
-Custom Fuel rail
-Lines (some wear)
--8an feed to pumps
--8an return
Skunk2 Racing Tuner Series Camshafts Honda/Acura H22A / F20B 2.0/2.2L DOHC VTEC - Turbo
Cams.Bnib, One box was opened. Cams never installed. Customer backed out on build.
500 obo
Skunk2 304-05-0225 Tuner-Series Adjustable Cam Gears Bnib never opened
180 obo
Lovefab h22 sidewinder manifold. Has flange for t3 or t4. Has one bolt that will have to be extracted. Never installed, bought used.
550 obo
Twm Itbs for gsr head. They are square ported. Comes with fuel rail,fuel pressure regulator,and vacuum block, no injectors. Customer was using id100os on it.
900 obo
Parts are obo paypal and shipping extra
500 obo
180 obo
550 obo
900 obo
Price - 900 + shipping and paypal fees
Location - Hamilton , NJ
Head has the following and was ported at M2 race systems and assembled at head games
Port and polish
Toda dual springs
Toda retainers
ferrera valves
bronze valve guides
5 angle valve job
cam caps
rails
rockers
vtec solenoid
valve cover
all the bolts
i would just get the head resurfaced has some little knicks on the surface
Port and polish
Toda dual springs
Toda retainers
ferrera valves
bronze valve guides
5 angle valve job
cam caps
rails
rockers
vtec solenoid
valve cover
all the bolts
Sadly the time has come to sell my turbo kit that I put alot of work into making. Whats for sale:
Custom Honda/Acura B series Top Mount Garrett 42R Tial flange exhaust manifold with Tial 44mm wastegate flange.
4inch up tube with 2 o2 bungs. (this kit also allows for down pipe and I still have my pipping from when it used to be if asked)
Tial Garrett 42R Tial Stainless housing
PWR 20" x 10.5" x 3" core with custom backdoor end tank with 42R compressor flange.
3inch steel charge pipe with 50mm Tial BOV flange.
(Turbo, Wastegate and BOV are NOT included)
All T clamps, and couplers included. Would rather sell as a complete kit as they all work together. All this kit needs is your 42R turbo, wastegate, BOV and your good for over 800hp (made 860 with 32psi, and held strong)
Asking $1500 or best offer. PM for best response. Thanks.
Fs 96 integra fully caged cf hood and hatch 3500 or obo
Fs Strada Itr 3 piece 800
Fs GRP aluminum rods 500 obo
Fs full-race twin scroll top mounts 700 obo
Fs benson sleeved GSR block 850 obo
Fs DSS 5.9's 1250 with hubs 1100 w/o hubs obo
More parts to come pics avail on request.
For Sale:
Precision T4 67p-trim journal bearing turbo. .84ar exhaust, race cover compressor housing. Mostly dyno pulls on this setup and 4 hits down the track. Good for over 700+ whp. $600.00 o.b.o contact info 832.277.1065 or PM
I have for sale our backup 2.7L all motor shortblock. We wont be using this so we decided to sell it. The shortblock is already assembled and contains:
Golden Eagle sleeved
Sony Bryant 106mm Billet crank
Arias 90mm pistons, 15:1
GRP Aluminum rods
ACL race bearings
Looking to get $5000 for the shortblock. Parts alone are worth more. This shortblock has never been run and all the parts except the Sonny Bryant crank are brand new. The crank was run all last season and this setup is basically the same setup we had last year that went 10.08.
GRP Aluminum rods
ACL race bearings
Exospeed star 5 drag wheels. 13x9 5" backspace. step-drilled for rim screws. Brand new, never used with brand new Mickey Thompson 24.5x8x13 E.T. drag slicks - $1000 obo
Exospeed star 8 skinnies. 15x4 brand new, never used with brand new M&H 22x3.5x15 tires - $1000 obo
FULL-RACE k series vertical flow intercooler. Brand new, never used $900 obo
Tial Q 50mm BOV. Brand new, never used $250 obo complete in box
PIC performance drag coil overs. Less then 15 passes. Mint condition. Car was always garage kept. $700 obo
Complete drag car fuel system $900 obo (all motor k, may work for others)
-RameyBuilt 5 gallon fuel cell, powdercoated satin black, mounts in factory location and connects to factory fuel neck. Comes with straps
-Bosch 044 fuel pump with mount, -8an feed line, -6an return, 100 micron filter before pump and 10 micron filter after pump, all black fittings
-The fuel system was used for 1 dyno session on q16
Complete B20 Vtec swap out of a 94 Civic - $2200 obo
-B20z bottom end
-ported B16 head with Omni Power valvetrain and flat face valves
-Type R cams
-Civic Type R transmission LSD 4.4 FD mint no grinds or pop outs
-6 puck clutch
-stock axles
-stock mounts
-obd 1 engine harness
-chipped tuned p28 ecu
-aem intake
-stock header
Cable LS B series trans - $250 OBO
- Condition unknown, I was told it was good, price reflects that
K Series 5 speed base rsx transmission - $500 obo
- mint no grinds or pop outs
Auto Meter Sport Comp tach w/ shift light. Comes with bezel to mount in factory location on eg - $175
-B20z bottom end
-Type R cams
-6 puck clutch
-stock axles
-stock mounts
-aem intake
-stock header
Brand New
Comp Clutch Stage 5
4 puck sprung
Slightly Used
ACT Flywheel 12lbs
$400 Shipped
Email - The_Gse@yahoo.com
Text - 775-527-9523
Comp Clutch Stage 5
4 puck sprung
Slightly Used
ACT Flywheel 12lbs
$400 Shipped
Text - 775-527-9523
Contact: 240-778-7866
Parting out my 1990 Ef Si, trying to get more funds for my drag car. All prices include shipping. Just pay paypal fees. And all prices are negotiable. Most parts are basicly new. Will trade for skinnies and matching 13inch wheels
Hasport mounts $375
Hasport subharness $225 ******sold to ***"cheetah"***
Full race traction bars $275 ****sold
Skunk 2 one piece suspension $380 ********sold
Vibrant 2.5 full exhaust w/ reso $300
Hytech Headers $350
1990 Honda Civic Hatchback SI rolling shell w/ 74k miles on chassis $600 obo
Includes Blox LCAS, Full gsr interior, ARP extended Studs, Hydro converted, Sunroof works, Battery recolated in trunk
Located in MD hit me up 2407787866
Hasport mounts $375
Hytech Headers $350
Set of 13x10 fronts w/ 4" backspace and set of rears 15x3.5. Both are 5x114.3 lug pattern and fit lovely on my RSX. Need to either shave your calipers down a lil for clearance or get the wilwood drag brake kit for newer 5 lug hondas. Looking for $1100 OBO. Rims only and they were only mounted never ran. Sorry for shitty cell pics, can provide better pics at request. Any questions feel free to message me on here.[IMG]
[/IMG]
[/IMG]
h22 golden eagle intake manifold with 90mm accuffab tb $650
turbo xs daul stage boost controller$150
1600cc bosch injectors $200
h22 port and polished head done by head way performance with ferra valves crower springs retainers $800
h22 moroso aluminum oil pan with pick up $200
full part out hmu with needs
brand 50 mm engine bearings $40
alot of h22/h23 parts just call me 5164037564
BNIB Racepak IQ3 Display Dash with the Racepak Vnet cable. THIS IS THE DISPLAY ONLY VERSION, NOT THE LOGGING VERSION!!! It will then display everything the AEM See's. $1000+shipped
BNIB Aem V2 6040 $1000+shipping
Cannon 79pin(22awg) Comes wit pins & tools $125 shipped
NGK NTK Wide Band Powerdex AFX Air/Fuel Gauge Wideband $150+shipping No sensor
paypal only!
Any ?'s Text me 617-719-1781 anytime
paypal only!
AFI Turbo B series intake manifold fit the follow b16/itr flanged for 75 mm mustang throttlebody which is up for sale also im askin $650 obobuyer must add 3% paypal
(full blown xxl fuel rail $100+shipping
Looking to sell my sheepy forward facing kit .. Manifold t4 twinscroll , 44mm wastegate flanged , uppipes , intercooler . 2000 .will ship if buyer pays.. Brand new .. Kit pretty much replicates the eg on the lower right corner . I can include tial 44mm wastegates for extra. Text me 302 450 6966
I have a precision 6766 ball bearing non billit wheel turbo for sale. It is water and oil cooled. t3 .63 ar 5 bolt exhaust housing. Comes with 5 bolt downpipe exhaust flange. $800 shipped obo. For fastest response text (208) 954-2565
Hello,
Up for sale is my AEM Version 2 30-6050 box. This unit was used for about 5 mins. I used it on a car to make sure it was working properly and tested out a map that I had. There is no issues with it what so ever. Like I said it's practically brand new. I am looking to get $1100 for it. Email me for more info SDSparts@gmail.com
[/URL]
[/URL]
