June FS Thread
Old Jun 4, 2013 | 08:23 PM
  #26
bhawan133's Avatar
Default Re: June FS Thread
EK 3 piece front end for sale $ 800.00 fits both 26" and 24.5 " tire
PM IF YOUR INTERESTED
Old Jun 5, 2013 | 06:29 AM
  #27
TDautowerkes's Avatar
NOTE: ALL PRICES INCLUDE SHIPPING!!!
· Golden Eagle B20 Block Guard - $60
· KAW EVO X battery tiedown - $80
· GARRETT turbo speed gauge + sensor - $475
· Vertical flow intercooler Treadstone core + custom endtanks - $500
· AEM water temp sensor kit - $40
· AEM wideband/uego sensor - $80
· Precision 7175 GTS T4 .96 a/r - $1000
· Custom exhaust manifold + 3" downpipe - $550
· Accord transmission w/ QUAIFE LSD (was on an H) - $900
· Ported H22 head w/ full FERREA valvetrain - $1050
· Bosch 1600cc injectors (could probably use a cleaning) - $250
· CROWER connecting rods (reconditioned, used for a few dyno pulls and removed) - $400
__________________________________________________ ___________________
Up for sale is a CLEAN 98 EK hatch rolling chasis. This car is set up for a turbo H swap. It also comes with a bunch of goodies so don't let this deal pass you by. Before I list all the parts on it, I'll let you guys know the ONLY flaw on this car is the front bumper. It was re-sprayed but the painter did a horrible job at matching it to the rest of the car. The lip, grille, and everything else is MINTY and matches.
Asking price is $4,000 obo.
Specs:
Engine/engine bay
· Full 3" custom exhaust to an APEXi N1 can
· FMIC mounted with intercooler piping coming from both endtanks to the fenders.
· Custom MOROSO catch can mounted under driver side headlight
· TEIN hood dampers
· Linelock
· Sumped tank
Suspension
· EMUSA rear LCA
· BLOX Drag suspension
· SKUNK2 rear lower arm bar
Exterior
· Lexus IS300 pearl white paint
· 99-00 front end conversion
· Rota GT-3 wheels with white center and polished lip (perfect condition)
· Mickey Thompson ET street drag radials - 225/50/15 (75%+ life left)
· Carbon fiber duckbill rear wing
· OEM lip kit all around
· SPOON side mirrors
Interior
· Full interior (carpet, panels, and rear seats are MINT)
· CLIFFORD G5 Alarm
· Si gauge cluster
· S2000 steering wheel
· Type R style shift ****
· Red Sparco racing seats
· FULL Defi BF gauge treatment. Boost, Oil pressure, Fuel pressure, Water temp.
· Cluster gauge pods
· Defi control unit and all sensor included
· AEM wideband gauge and sensor
· GReddy Profec B spec II electronic boost controller
· Pioneer radio unit
· RCI 5-point harness
· 9.99 legal roll cage (not NHRA certified yet because this car was built for street use)
Now, on to the good stuff.. PICS!
Old Jun 5, 2013 | 08:07 AM
  #28
cavi2sunfire's Avatar
ok guys I have a few things for sale
Weldon 1100 Pump with adapters
Weldon 2040 Reg with adapters and BWR pressure gauge
Weldon Filter With adapters
parts have around 10 miles on them and a few dyno pulls parting car out so don't need this anymore would like to see 400 for all of it shipped for another 175 ill throw in the AN lines I have and 10 gal fuel cell so everything you need minus injectors
Old Jun 5, 2013 | 03:38 PM
  #29
cteg6's Avatar
2007 OPEN 16ft car trailer...
*eletric brakes
*recentley added delta storage box $2000 firm call/text 203 449 1399
Old Jun 5, 2013 | 05:01 PM
  #30
team1320_k26eg's Avatar
K-series PAR 1-4 Dog Box Transmission
2.85 - 1.92 - 1.33 - 1.05
4.78 FD
Quaife LSD
Includes bell housing and shifter mechanism.
$5,500 Located in North County San Diego. Email: fievel1320@aol.com, text or call: (760)505-2855
(will consider a running vehicle in trade of similar value. If the cars value is lower, cash would have to be put on top)
Thanks for viewing!
Old Jun 5, 2013 | 09:45 PM
  #31
ninesecrx's Avatar
2000 civic si drag car. 25.5 spec cage. strange spindle mount suspension. setup for s2000 engine and 4t65e transmission. Comes with everything almost ready to race. Plenty to list but would rather talk with interested buyers. $30,000 obo
Old Jun 6, 2013 | 02:29 PM
  #32
elevatedj32's Avatar
* Items For Sale. Prices are neogotiable. *
* Email me at turnbuckle1960@aol.com *
* Buyer pays Shipping and Paypal Fee's. *
* All my stuff is good and low time *
* All images are clickable for enlargement *
** 6 Nearly Brand new, Siemens Deka, 220lbs/hr, 2310cc/min fuel injectors. **
** This is not a re-worked or re-milled injector. **
** Coil Resistance: 2.5 Ohms, low-resistance, peak-and-hold type **
** 14.5mm Viton upper and lower o-rings **
** Fuel compatibility: Flex fuels, oxy. gasoline, Ethanol E100, E85 **
** Dimensions: Body Diameter, 20 mm; O-ring to o-ring, 60.5 mm **
These were used on dyno for several runs and removed, they did not suit my setup. I had them cleaned and pickled afterwards. They have never had Methanol run through them, only GAS. They have been sitting on my shelf for a couple years.
Brand new they sell for 160.00 each on popular websites.
* 600.00 for the 6 of them. *
* You should have a spare or two *
** Nearly New Lithium Pros T1600 battery with Charger. 9.8 lbs. **
** Group 24 size **
** Bought last August, Minimum usage on it and is virtually Brand New. **
** Sell for 650.00 ** They cost 1000.00 brand new.
** For you J Motor Heads. **
** This plate adapts a J motor to accept a chevy style transmission. **
** Was setup for RWD **
** You will need a Ford Style starter **
** All R&D done for you **
** 220.00 **
** 2 Custom Identical Flywheels for the "J" motor. **
** 1 new and 1 used **
** SFI Approved **
** 153 tooth Chevy Ring Gear **
** Over 400.00 in material, don't forget the R&D cost that was additional **
** Used one is 225.00 **
** New one is 275.00 **
You "J" motor guys might wet yourself on this one. It won't be cheap.
** Raw Uncut Camshafts for the J3xa2-a5 motors. **
** design your own grind **
** Cam Journals are oversize for you creative souls who thought about opening up the cam journals in the head to accept higher lobe profile. I wouldn't go much, but you
could get .550 lift +- with the right rocker ratio and cam profile. **
** Already hardened **
** How do I know? I just know. **
** Don't ask where I got them **
** 500.00 **
** 6 Nearly New Denso CBR COP Motorcycle Coils **
** All come in at 1.3 ohm, just like new ones **
** Everyone should have an extra couple on supply **
They work great, I changed my ignition to something different, don't need.
** All 6 for 150.00, 25.00 each ** New cost +- 60.00 each.
Old Jun 6, 2013 | 09:29 PM
  #33
therunnerz's Avatar
b16 endyn ported head bare with caps....$500
Gsr crower rods $300
Grp aluminum grp rods few passes on them $300
mezeire idler water pump $75
wiseco 81mm pistons $200 need rings
Arias k20 12;1 pistons brand new in box $250
Rsx type s engine harness $100
aeromotive Fpr $80
arias 84mm pistons $250
All parts are in perfect working order pricing is cheap so it can sell cause they are just sitting here in my shop collecting dust.. time to cash them out lol text me will be best 214-576-6367 I am very fair with shipping
Old Jun 7, 2013 | 08:37 PM
  #34
MoiMotorsports's Avatar
im selling my car 1995 civic ex coupe it use to race in Florida i have a Florida title to it the car as raced its whole life it only has 35k miles on title
i can sell it as turn key i would like to sell the rolling chassis i will sell the turbo setup if it doesn't sell with the car im not in a rush to sell it want to do a rwd car if this dose not sell i will convert it . u can use this car for pro stock like i did in 2011 2012 or a 11.50 index 10 o index u can put a stock gsr in it and it will go 11.50 weigh with a b swap is 1680 it the roll cage mild steel so if u were to change it to chrome molly u can save more weight. i installed the kens kustom straight Axel setup and u can make alot of adj with that where u can change the wheel base so it will 60ft better i has wheeli bars all the windows plexi glass from the company fall (everything in the car there are no short cuts or cheap parts
the price on the car is obo i can take parts off if u dont want certain things
all u will need is your swap and u can go racing $10,000 i can take off alot stuff where i can just sell u the body 7,000 i willing to work out a deal even trade for a 99 00 civic si or a fox body mustang
(856) 332-5450 text or call
some videos
Old Jun 8, 2013 | 12:39 PM
  #35
FRernesto's Avatar
Up for sale is this Edlebrock 65mm throttle body part number EDL- 4790. Asking 175.00 and will ship in a flat rate box for free, Please include paypal fee. The throttle body is in perfect working condition and the TPS does come with it.
Old Jun 9, 2013 | 06:14 PM
  #36
boostontheD's Avatar
Full blown dual pump hanger
230 shipped plus PayPal fees obo
Everything pictured is what's included
Old Jun 9, 2013 | 07:46 PM
  #37
therunnerz's Avatar
repost with pictures
Old Jun 9, 2013 | 10:32 PM
  #38
Zer0_SpeedWorks's Avatar
For Sale!
AEM thermocouple amplifier BNEW mounted only - 250$ shipped
AEM AQ-1 data logger with 18in flying harness and Garmin GPS 18x module for trackmapping and timing BNEW mounted only - 450$ shipped
Racepak AEM series2 EFI module Vnet cable for IQ3 less than a day of use - 300$ shipped
Please PM me if youre interested! Paypal only!
Old Jun 10, 2013 | 08:11 PM
  #39
*EFilliated*'s Avatar
87MM 13.3:1 Kseries K24/K20. Pistons Have about 150 miles on them, still in great conditions, ready to drop in. Asking $300 OBO. Shipping will be additional. PM if interested....
Old Jun 11, 2013 | 08:47 AM
  #40
pettyboy69's Avatar
I've been throwing around the idea of parting out my fwd cars lately so I'm posting everything up for sale to see if there is interest out there. If I can't find a buyer for the engine I won't be parting anything else out.
Engine is brand new and never ran 0 miles
Benson sleeved LS-vtec engine
84mm bore
GRP billet aluminum rods
Custom ross pistons w/gas ports
JE custom wrist pins
O-ring'd block and reciever grooves in the head
SCE Copper head gasket
Moroso 5qt oil pan
JG cylinder head GSR
cnc'd
ferrea bronze guides
JG .5mm oversized flat face valves
JG valve springs and retainers
fresh valve job and surface
Highly polished front of cylinder head looks amazing
Brand new skunk2 pro 1 camshafts
$4000 for complete engine brand new everything never ran
H&H fab B series ff t4 twin scroll twin 44mm turbo manifold brand new ceramic coat, manifold has never been ran
$850
Precision 6766 jb t4 twin scroll with 1.32 and 1.00 housings 300 miles on turbo 0 on all the housings brand new aluminum vband welded to compressor housing
$1000
Vibrant 875hp intercooler with vband and sharp radius 90 Brand new never ran
$500
HKS cam gears Brand new just bolted up $270
Victor x intake manifold powder coated purple $300
AEM rail with gauge $80
BBK 70mm TB $175
Skunk2 alpha radiator, lines, and slim fan w/shround $300
1995 civic hatch shell
Light metalic blue kinda like the s2k light blue
tokiko blue struts with GC coil overs
Integra front brakes
cf duck bill
camber kits all around
rear subframe brace and aluminum lcas
Brand new wheels and tires maybe 50 miles on them
$2500
I'm sure there is other stuff I am forgetting
If you are not 100% serious and have cash do not waste my time
NO TRADES OTHER THAN S2K AFTERMARKET DRIVE TRAIN PARTS
pm or text 208-521-9397
photobucket is acting up, but pictures will be loaded as soon as photobucket is back up
Old Jun 11, 2013 | 12:58 PM
  #41
B18c1turboedEK's Avatar
WEB Cams $550.00
STR intake, STR throttle Body, Golden Eagle Fuel Rail $400.00
Sperco A1000 water air intercooler, Passenger side water tank, Meziere water pump, 16AN water lines $650.00
S372 Turbo $600.00 with oil lines
DSR T4 Twin Scroll Manifold top mount $600.00
Ferrera PRO series Valve Train, springs and retainers & 1mm Valves $400.00
Please include shipping and paypal fee
Will post pictures when I get home tonight
Old Jun 11, 2013 | 07:58 PM
  #42
mint's Avatar
Everything has 10 dyno pulls and one day at the track.
Divided T4 manifold $700 OBO
Borg Warner FMW 67mm T4 1.0a/r with vinjin clamp $1000 OBO
2 Tial Mvs 38mm WG all the springs that come with. $500 OBO
$1900 OBO everything above plus dupe tubes and down pipe.
PM/Call/text Nate 612-7O3-2OO1
Old Jun 12, 2013 | 01:40 PM
  #43
jdm inc's Avatar
b18c arp main kit. BNIB 100 shipped.
obd2b to obd1 jumper 75
intake 20
ef b series mount 100
Old Jun 12, 2013 | 06:20 PM
  #44
GT30EK's Avatar
GSR Benson sleeved block 85mm with .0045 piston to wall clearance $2000 obo
CP Pistons W/heavy duty wrist pins 9.7:1 W/B16 Head or 10:1 W/GSR Head
Pauter LS Rods
Comes with type R oil pump and rear main seal.
Motor is two years old, and about 30 1/4 passes.
ARP Studs torqued once motor never ran. Comes with studs,washers,and nuts $60 obo
Old Jun 13, 2013 | 10:17 AM
  #45
artie89's Avatar
abes sleeved ls block by z10 the block is 81mm and o ringed all it need is a fresh horn im looking to get 900 obo for it
Old Jun 13, 2013 | 07:34 PM
  #46
Mo_Spec's Avatar
Clearing out some parts so we can try and buy some real axles for the race car, all prices are shipped, except the tailgate and axles haha.
EG Tailgate $75
B series VC $50
K series VC SOLD
S2 74mm TB $75 (it sticks)
2.5" stainless vband set $40
MSD Blaster coils $25 each
Quaife ls/b16/itr diff Needs $400 of new parts to repair $175
PTE 67mm comp housing $50
GSR cams w/gears $50
CTR Intake cam SOLD
RSX cat delete $50
Vibrant 3"-4" ss reducer $50
(Not pictured) Quaife ls/b16/itr diff (8 passes) Karcepts 36mm hubs and b series axles with 36mm outer cv's $800 The car went many low 9 second passes on this set up.
Old Jun 14, 2013 | 10:37 AM
  #47
Almtrhb's Avatar
**SOLD** Exedy Twin Disc used, has 2 1/2 full events on it, 200+ dyno passes $750 obo Shipped US... You pay paypal, you pay shipping outside the US..
** SOLD** Msd Digital 6, Damn near new.. $160 Shipped in the US
You pay payal..
Text me 714-388-7303 Ill respond asap... Comming Soon **SOLD Top mount wit **Sold** 66mm precision WG, Skunk tuner 2cams with cam gears, 2200cc injectors, etc
Old Jun 14, 2013 | 11:44 AM
  #48
patroick67's Avatar
Parts from my sfwd car that I never completed. You can text me for quickest response @ 8129297990 I accept paypal only and ship out the day after funds are received.
Chasebays mil spec engine harness for h22 engine comes with integrated hondata coil on plug and milspec plate for firewall.
Will come complete with 4 honda coils. 1000$ shipped
neukin radiator with 1770cfm radiator fan this radiator has never had any fluid ran through it and is 100% plug and play. 250$
Russel steel braided line kit for a 92-95 civic part number 684480 70$
These are also brand new just spill some brake fluid on the package.
F1815p ferrea competition plus exhaust valves for a b series engine brand new still in the package 200$
wilwood brake master cylinder kit 100$
cnc staging brake new never been used 120$
Old Jun 14, 2013 | 01:10 PM
  #49
tepid1's Avatar
FS: (two) Bosch 044 pumps and MB racing pump hanger bracket and J-racing check valves. Paid $700+ asking for $475 shipped. -8AN inlet and outlet pump fittings are included.
FS: Accufab 75mm (at plate) throttle body. Fits the standard Mustang flange. Brand new. $250 shipped
FS: Pair of Weld Racing 15x10 with 6" backspacing. Mounted drag radials for dyno stuff only. No track hits on these. Like new. $600 shipped
FS: Custom A2W Intercooler with 2 Garrett 1000hp cores. Also includes ice/water tank, all -16AN AN hoses and Meziere dual outlet 55gpm pump. Coated in non sweat coating. Stays dry even with ice in the tank and 100+ ambient. Pay the asking price and I'll throw in the Tial 50mm BOV. $1100 shipped
FS: Fal Civic fan. Works perfect. $100 shipped
FS: Homemade catchcan. Works great. Used it for a few years. -12AN fittings. Used in battery location. $75 shipped
FS: Full Race traction bar links. Comes with bolts, washers and nuts. Cross bar NOT included. $50 shipped SOLD
FS: D2 Laser ride height sensor. 0-100mm distance. $250 shipped (sorry about the dirtiness)
FS: Motec hall sensor. New and never used. It was a backup unit. $150 shipped
FS: Motec speed sensor. Another backup I have. $60 shipped
FS: Motec single axis accelerometer. Brand new. Yet another backup. $275 shipped SOLD
FS: Prologger WBo2 and boost controller. Comes with brand new Bosch LSU4.9 sensor and all instructions. $350 shipped
FS: Ford TPS sensor. Never used it, but works. Like new. $30 shipped
FS: Black Golden Eagle manifold. Comes with what you see. Has -6AN fitting too. $40 shipped
FS: Battery cutoff switch. 200amp capacity. $40 shipped
FS: Avid Racing GSR water outlet adapter. Never went into full production on these. -16AN fitting. $60 shipped
FS: RPM Services 70mm throttle body. Comes with 3" Wiggins clamp assembly. Honda flanged. $125 shipped SOLD
FS: Wiggins 3" clamp assemblies. Both are in great condition. 2 for $130 shipped or $70 for just one shipped
FS: SLS custom B-series spark plug cover. Anodized in 3D violet just like the Tial stuff and the Wiggins clamps above. $100 shipped
FS: Skunk 2 Battery tiedown. No damage and like new. $30 shipped
FS: Spal ultra thin 13" push fan. 920CFM. $40 shipped SOLD
FS: Custom 3.5" Aluminum DC2 exhaust. Uses Magnaflow 3.5" muffler and Vibrant V-bands. Sounds awesome! Rather not ship this. $400
FS: 2000 GSR shift linkage. Mint condition. $150 shipped
FS: BFG Drag radials. Like new and still have nubs on the tires. 225/50-15 $225 picked up
Old Jun 15, 2013 | 01:18 PM
  #50
ashtons300zx's Avatar
Couple of things for sale.
Tial Q Version 2 50mm BOV, already mounted on a 3" chargepipe. Flange can be cut off pipe and remounted if necessary. Basically brand new less than a couple months old. Comes with the vac fittings......$200 shipped or best offer
JGS 50mm race wastegate. Comes with all seats, flanges, fittings and all. The race version has the vband tophat for quick spring changes. Comes with the 10lb spring in it and a 1 bar spring and thicker spring seats as well. Gate fits Tial 44mm vband flanges as well. $250 shipped...Gate has very little use on it and is a couple months old.
XS Power 16v battery and charger setup. Less than a year old and only used during dyno time and a couple passes. Holds perfect charge and in great condition. Almost $480 new Selling for $200 picked up. If Im able to ship buyer can pay for shipping.
