----June FS Thread----
Old Jun 1, 2012 | 11:08 AM
crazes's Avatar
Moderator
Default ----June FS Thread----
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Jun 1, 2012 | 12:20 PM
Twenty47's Avatar
Default Re: ----June FS Thread----
Kinsler k series 60 mm itb's
2000 + shipping/pp fee's
Got these in a trade and dont need any of it. basically giving them away.
K series flat faced black nitride supertech valves and bronze guides
215 shipped for valves. STD size 35,30mm
55 shipped for guides
Old Jun 1, 2012 | 12:48 PM
CHEETAH's Avatar
Default 88 CRX Full Drag Race Chassis
My old race car with:
1 pc detachable: MB fiberglass front end, doors and hatch
aluminum dash
Painless wiring 4 switch panel
Still prepp'd for a B-series setup, but I do have a K-series mount kit
Solid rear axle
Wheelie bars
rollbars (good to 10.0 e/t)
needs shocks/suspension
does not come with slicks/skinnies just steelies
has 2 fuel cells not installed, 1gal and 4gal
with me (220lbs) and b-series all motor setup, weight was 1475 lbs
definitely 9 sec potential with a 400hp K-series all motor setup or a 300hp B-series all motor setup
more stuff...
$2000neg
Old Jun 1, 2012 | 01:07 PM
sonicteg's Avatar
NEW Clutchmaster FX400 6 Puck Sprung Clutch $355.00
Exedy Chromoly Flywheel SOLD
Innovate LC-1 $125.00
Aluminum Radiator $110.00
Pm for details..Make me an offer..Prices negotiable
Old Jun 1, 2012 | 01:19 PM
97VRT's Avatar
Exospeed VPD Wheels
Bright Gold
4x100, 13x7.5
+25 offset, Centerbore: 56
BRAND NEW in the box.
$320 for the pair
Can ship anywhere
Old Jun 1, 2012 | 02:17 PM
Will_H's Avatar
M&W PRO 10 Kit purchased from T1 race development, complete like new used maybe 10 passes. Comes with new GSR MSD cap not pictured. $SOLD!!
Stock integra gas tank with sump welded in. Works great comes with everything pictured. $150
Edelbrock GSR intake manifold, port matched for a 74mm TB.
$200
GSR head, tons of work done to it. Bronze valve guides, Intake and exhaust valve openings are +1mm. Both intake and exhaust ports have a ton of port work done to them. Only thing it needs is a good cleaning. Comes with cam caps! Bare head $300
Shift i, works perfect $SOLD
Hasport mounts b-series. pass side is a auto to manual $150 for all three
Old Jun 1, 2012 | 03:37 PM
dyno76's Avatar
Spinwerk 13x8 Brand new still in box.. $440.00 plus shipping
Old Jun 1, 2012 | 05:48 PM
JDM346's Avatar
F/S
93 cx hatch
-beautiful body....no dents/rust...fresh si blue paint
-beautiful full interior
-custom fiberglass dash with gauges
-cert. 8pt cage
-rear external kill switch
-parachute mount with cable and lever
-exospeed 3 piece front end
-full drag omni power suspension
-custom lower control arms
-corner balanced
-weld magnum gold face chrome lip rims with 26" slicks....skinnies with new tires
-brand new sumped oem gas tank with 2 feed fittings
--8an return line installed
$4500 OBO located in Clarksville TN
for more info and pics (336) 575 -0563
Old Jun 1, 2012 | 06:00 PM
hatrickstu's Avatar
All parts located in Little Rock, Arkansas. Just PM here for info and what not.
TURBO STUFF SOLD
Next is some Precision 1600's with an FJO box. I would prefer not to split these up, asking $450. Sorry for not taking the injectors out of the car before pictures, but here is them in the car:
Old Jun 2, 2012 | 04:20 AM
justnprsh07's Avatar
Cleaning up around the shop to make room for the new build... everything is OBO!!!! Text for fastest response 7065877278
precision 1000 hp liquid to air intercooler setup $500 comes with tank,precision 1000hp l2a core exchanger,pump and fittings
[IMG][/IMG]
obx 70mm tb $125
[IMG][/IMG]
B series clutch $50
[IMG][/IMG]
Brand new in the box half radiator and fan $100
[IMG][/IMG]
H22 eagle rods $sold
[IMG][/IMG]
H22 STR fuel rail $40
[IMG][/IMG]
H22 pullys $40
[IMG][/IMG]
H22 tubo Kit $1200 Custom manifold, 6262, 46mm wg
[IMG][/IMG]
H22 88mm wiseco piston 8.5:1 $150
[IMG][/IMG]
2 H22 crower pro rods $50
[IMG][/IMG]
4x100 drilled and sloted rotors $sold
[IMG][/IMG]
H22 eg mounts $50
[IMG][/IMG]
4g63 bottom end eagle rods wiseco pistons, balanced, cal bearings, $1600
[IMG][/IMG]
Shep Stg4 trans for awd talon/eclispe $1400
[IMG][/IMG]
SRT4 Ragetek twin disc with -1000 miles $500
[IMG][/IMG]
Turbo smart boost controller $50
[IMG][/IMG]
Cooling mist water methanol kit $200 come with tank, pump, straps, lines, filter, and nozzle
[IMG][/IMG]
SRT4 DSS axles $sold
[IMG][/IMG]
SRT4 Turbo Kit $1200 comes with new precision 6262 t3 4bolt .82ar, agp cast manifold, precision 46mm wg, 38mm 2bolt-44mm vband adapter, o2 housing, dump tube, oil feed, oil return, 4in aluminum intake with filter, charge pipe, all couplers, and tbolt clamps
[IMG][/IMG]
24.5 slicks on stock 15in neon wheels $200
[IMG][/IMG]
custom 4in intake with velocity stack and filter $150
[IMG][/IMG]
mopar 3bar map sensor $20
[IMG][/IMG]
rc 750cc injectors $sold rc 1000cc injectors with resistor box $sold clips $25
[IMG][/IMG]
I also have tons of stock part so if anything is needed lmk
Old Jun 2, 2012 | 05:14 AM
IMPORTMyth01's Avatar
96 Acura Integra GSR Weekend/Track Shell
Clean and Clear Title in Hand in my Name
Up for sale is the Integra I have been working on for the last two years. Car was completely stock with a bad motor and I stripped it down to nothing and removed all the PS, AC, ABS, etc and rewired the entire car with a OBD1 harness and RS brake lines, etc. then put it all back together with the below mods. Car was meant to be my weekend warrior for Autocross and Drag but 8 months after it was in its prime the motor let go due to a bad vacuum line.
My wife just gave birth and I thought I would be able to juggle getting the car up and running again but no bueno. Would rather sell it now so that it doesn't deteriorate. Car has been kept under a car cover for the last year or so and still in the shape it was the day at the track the motor blew.
Willing to take $1600 cash as is!!!!!!
THERE IS NO MOTOR OR TRANS IN THE CAR, Rolling Chassis, I do not have them they were sold or trashed.
Only trade would be a 92+ Civic Sedan or 94+ Integra sedan with AC and 5 speed and in good shape
Contact me 706-577-3364 Call/Text with any offers
Below is the link to the entire picture gallery (didn't want to crowd the whole page with photos)
http://s128.photobucket.com/albums/p...0Sale/Integra/
In Her Hay Day
As she sits now.
Exterior:
Flat Black to mimic Black Anodized
VIS Carbon Hood w/ Sparco Hood Pins
Mugen Front Lip (Front Bumper could use replacing)
35% Tint
Interior:
Autopower 8 Point Bolt in Cage
Mint Del Sol Seats
RCI 5 Point Harness (4 mounted I have 5th belt)
JDM GSR gauge Cluster
Air Bag Delete
JVC Head Unit
Engine Bay:
Mild Wire Tuck
Battery Located in rear
ABS Removed
PS and AC removed
Suspension:
Drilled and Slotted Rotors
Neuspeed Lowering Springs on Stock Struts
Skunk2 Rear lower Tie Bar
Energy Suspension Rear Trailing arm bushings
Upper Rear Strut Tower Bar
Skunk2 Front Upper Control Arms
Electronics:
Advanced Alarm and Theft Deterrent System
Ebay Steering Wheel
Old Jun 2, 2012 | 06:39 AM
alopez84's Avatar
AEM EMS 1050 box currently set up for T1 cam trigger but can be easily switch for stock distributor. $600.00
American racing 15X9 4X100 wheels with holes for rim screws. $400.00
A2W setup Bell inter cooler core, water box that fits in EK engine bay with internal water pump and lines. $600.00
Old Jun 2, 2012 | 07:32 AM
SPOOLINmatt's Avatar
NGK Wideband sensor for NGK Wideband and any others that accept it. used for a race.
$50 shipped
B18B Golden Eagle Block with Orings - needs to be bored to 85mm....the damaged cylinder cleared out just under 85mm so it will clearance out to your likings.
$800
DH Racing 69mm Billet Throttle Body - has been cut, had a Vanjen Quick connector on it...still great for that or Vband
$150 with TPS - $100 without TPS
$85 for magnaflow 4" race muffler
Set of 3 used Eagle rods - 5.430" length for B18C1 GSR Crank. $125
Set of 3 used manley rods - 5.430" length for B18C1 GSR Crank. $125
706-346-6024
matt.stover@comcast.net
Old Jun 2, 2012 | 08:30 AM
uscivicmc's Avatar
everything is located in York, PA. local pickup preferred but i will ship some of the things at your expense. add 3% for paypal fees if paying me that way
best way to contact me is call/text, number is 443 eight4six 2511
81.5mm b18a1 block $1600
Manley H beams
Wiseco 9.8:1 pistons
ACL race bearings
ARP headstuds (for lsv)
new water pump
the block has 0 miles on it since i got it from the machine shop, it was bored/honed, rings gapped, crank was polished and measured.
when i assembled this motor, i plastigauged everything. Its all within spec, if you're serious i can pull a cap and do it in front of you to show you.
i also have everything to make it a running motor, starter, alternator, new distributor, shift linkage, axles, hoses, etc. if you need any of that just ask and i'll give you a price on that stuff
B16 head $600
supertech dual valvesprings (turbo)
supertech valve seals
brand new LMA's (beehive springs, not hydraulic)
fresh valve job, one valve was replaced
just resurfaced
comes complete with all cam caps in order
has 0 miles since i got it back from the machine shop
valve cover can be included
13" Lenso's with 24.5x9 MT ET Drags lots of passes left $450
i can include wheel spacers with them as well so they don't rub
fronts only
Forged Performance ramhorn manifold $450
mostly idle time and maybe 15 miles max
Holset HY35 turbo $200
no shaft play, in great shape
will include downpipe and feed line adaptor for 4an line
F1 Spec type 2 seats $450
have 96-00 brackets
Crow Enterprises 5pt harness (brand new, expires in a few years) $60
bolt in style but can wrap around a cage
GSR cams $125
Golden Eagle fuel rail (brand new with all fittings) $100
Go Autoworks fuel lines, from stock filter to rail to regulator then to stock return (brand new) SOLD
Aeromotive Fuel Pressure Regulator (brand new) SOLD
Aeromotive Fuel Pressure Gauge (bnib) SOLD
Edelbrock Victor X intake manifold $225
Edelbrock Performer X throttle body 68mm i believe $275
aluminum radiator and slim fan $75
Allstar performance catchcan and oem block fittings, and some hose $70
Skunk2 dual bend short shifter and weighted **** $100
innovative motor mounts 70a bushings (stiffest poly bushing) $175
Progress Technology drag series coilovers 350/500 spring rates $500
Old Jun 2, 2012 | 08:56 AM
209lsr_ly's Avatar
eagle 95mm crank - 400 obo
lenso with slicks - white - front 25x8.7x13
front has screws inside and outside balanced no leaks
450
Old Jun 2, 2012 | 09:42 AM
turbos362's Avatar
-DART 84x89 short block. CP, pauter rods, LS crank, ACL bearings, Golden Eagle head studs, ATI crank pully, and more (under 100 miles ) $3900.00 OBO picked up
-B16 head stock port, ferrea valve springs and retainer, and valve cover with 2 -10 fittings $700.00 plus shipping and paypal
-Golden eagle cam gears gray $150 for both shipped in the lower 48 states
-B series starter for manual trans $50 obo plus shipping and paypal
-B series half shaft from GSR $50.00 obo plus paypal and shipping
-B series radiator hoses for B16/Type R head. $15 shipping in the lower 48 states plus paypal
Email- turboc1@sbcglobal.net for more pictures or info
Old Jun 2, 2012 | 02:34 PM
Trojan Man's Avatar
No Sales Forums
From: Reading the Chronicles and Blowin Trees in Virginia
PRICES ARE FIRM & SHIPPING IS EXTRA!
RLZ Engineering Race Head $1700 FIRM
Before I say anything about it, yes, this is Ramey's old SFWD head.
99 Civic Si head - ALL machine work done by RLZ in North Carolina
Race port job
5 angle valve job
1mm Oversized Ferrera Valves.
Ferrera Valve Guides
Ferrera Valve Springs & Retainers, Locks
Stainless Intake Valves
Inconel Exhaust Valves
Shaved Exhaust Guides
Made 901whp @ 26psi
Used for 5 dyno pulls since rebuilt
Precision 6266 Turbo $1150
Brand new, never used.
T4
.70 intake/.96 exhaust
Ball bearing/anti surge housing/ported shroud
M&W Pro 10 Ignition $450
Brand new, just mounted on the car.
Bad *** ignition system
*pictures coming soon*
OEM Honda B-Series Alternator $70
From my 2000 Civic Si (OBD2)
Works perfect
B-Series VTEC Solonoid $50
Came from my 2000 B16
Worked perfect making 400whp.
Hondata 4 Bar Map Sensor $70
Used for ~2000 miles
B-Series
Needed for anyone making over 11psi
W
Old Jun 2, 2012 | 03:14 PM
Kevin's Avatar
Brian Crower billet 102mm stroker crank for K series
Manley turbo tuff rods for 102mm crank in a K24 (they have wider B16 journals)
ACL b16 std bearings
I want to sell this as a complete kit. Only thing i'm willing to trade for are K series turbo manifolds or turbos (60mm or larger). PM what you have, i'm willing to listen to all offers.
$1650 shipped in the continental US.
Please contact via PM or glokology @ gmail.com
Old Jun 2, 2012 | 06:51 PM
b-built's Avatar
26x10 15 spin werks with 80% tread on the tires $500
turbo xs daul stage boost controller $120
k24 crower rods and 89 mm pistons $400 for both
5164037564
Old Jun 3, 2012 | 10:39 AM
crxmanror's Avatar
Brand new, never used complete set of Skunk2 Pro Series Valvetrain. Comes with complete set of pro series springs, titanium retainers and springs seats. Kit costs $545 retail, I'm selling for $ 450 shipped.
Technical Specs per Skunk2:
Seat Pressure: 70 lbs at 1.600”
Open Pressure: 230 lbs at 1.100”
Coil Bind: 0.870”
Designed to handle the demands of extreme-lift camshafts operating at prolonged, high-rpm use at championship-level racing, Skunk2’s Pro Series Valve Springs for Honda’s K-series engines are simply the best. Pro Series Valve Springs have been tested at speeds as high as 11,000 rpm on both the engine dyno and the street and our superior, Japanese-milled, super-clean chrome silicone wire is 100-percent eddy-current inspected prior to coiling and then heat-treated, shot-peened, and chemically polished for strength and durability. A special nitriding process concludes Skunk2’s rigorous manufacturing process. The end result is a lightweight valve spring that safely accommodates high-lift camshafts and features superior resistance to load loss, even under extreme operating conditions.
Old Jun 4, 2012 | 04:06 AM
legomytego's Avatar
up for sale or trade is my gf k20 motor i have got her to put a b series back in her teg. so she is no longer using this all the work was handled by joe simpson of tempest racing i just picked it up last weekend took pics then wrapped everything back up. we are also willing to drive some to help make a sale.
PLEASE EMAIL ME !!!!!!!!! vdodd45@yahoo.com
tsx k24a2 head $1200obo spent $730 on just machine work
new supertech valve train
new valve guides
new seals
head was decked
performance valve job
stock cams included
valve cover included
k20z1 block $2200 obo spent $1000 on just machine work.
cp pistons 9.0.1
86.5 mm bore
eagle h beam rods
crank micropolished/inspected
bearing clearances already done for you
bore/hone
oil pan included
front cover included
can have it assembled if you like.
trades we are looking for
id injectors 1000cc or 2000cc
tial bov black or purple
tial wastgate 44mm black or purple
s300 with boost option
gsr victor x intake manifold
98-01 integra front end
engine bay harness if you custom make them email me.
Old Jun 4, 2012 | 08:13 AM
Swipe'd's Avatar
Precision 1775hp Intercooler Core
Dimensions: 27.8L x 12.75H x 5.00D
$500 plus shipping and PayPal fees
located in New York
Old Jun 4, 2012 | 10:58 AM
DC2_117's Avatar
Hello,
I have the following items for sale. Some prices are negotiable. Please PM or Email (sig) me.
Exedy Twin Disc used, fairly new. Plenty of life left! $800
Skunk2 Pro 3 camshafts used but in perfect condition. $450
Magnus Intake manifold B16/ITR Head flange $675 shipped
Skunk2 Pro series Springs and retainers $475
AEM Twin Fire Ignition setup Complete new, only mocked up $255 shipped
T1 Intercooler GT1 $899 shipped
B18A1 Sleeved block Darton MID Sleeves 86mm w/ Custom CP gas ported pistons, side walls coated 13-1 cr, eagle H-beam rods, 92mm brian crower crank, acl race bearings. Motor was completely assembled by Jim Justice @ Justice Race Engines. $2200 FIRM will come with GE LS Vtec kit w/ brand new dowels. Used with only a hand full of passes. $2200
Old Jun 4, 2012 | 03:01 PM
slvrslepr's Avatar
Parting out a build that I don't have time to complete. All items are without shipping This is the best way to reach me 301-992-2223.
ERL Bottom end with Justice Race Engine Head
84mm bore, Crower billet rods, ERL 5 stud girdle, Coated bearings, ARP Mains, Ported Head, Ferrea Valvetrain, Skunk 2 Pro 1 cams. Motor has not been ran since assembly.
Asking $5300
Hasport Billet Mounts w/ billet inserts $300
NRG Fuel Cell $350
Full-Race Turbo Manifold $850
Chase Bays Milspec Harness w/ T1 cam trigger kit and M&W ignition integrated. The harness will come with the M & W pro 10 ignition and distributor and the t1 cam trigger kit $1700
Golden eagle scatter shield $175
H22 Skunk 2 stage III cams 250
Old Jun 5, 2012 | 06:50 AM
JO TECH's Avatar
Hey guys. I got a used 12V AGM Power Cell with charger and 160 amp alternator in good working condition. Came off my personal race car but i upgraded.
For both items $550 Shipped.
AEM WideBand 4 Channel UEGO Controller with back pressure kit NEW- $800
