July FS thread
Contact: pm or 443-532-5177
Well after putting all this money into this setup I realized its just to much for the street lol. I don't plan on racing it so I decided to part it out and just do a mild all motor build. I'm going to post everything up for sale but I need the turbo kit sold first before everything else can go.
First for sale is the turbo kit:
Tempest racing duel gate top mount t3
Tempest racing 3in downpipe
Percision 6262 turbo .82ar
2- dump tubes
2- tial 44mm wastegates
Tial 50mm blow off valve
Custom intake and air filter for turbo(rare for topmounts)
700hp intercooler
All intercooler pipes, clamps,oil lines
Turbo blanket
$3200 picked up
2)
Freshly power coated valve cover w/ go autoworks catch can
$250
3)
Gsr 84mm ge sleeved block
9.2:1 Aries pistons
Eagle rods
Acl bearings
Moroso 5qt oil pan
$2000
4)
Victor x intake manifold
$200
5)
RLZ cnc race ported built head, fresh rebuild with paper work less than 50 miles on it.
All supertech internals
Bronze valve guides
$1500
6)
Skunk 2 pro 1 cams
$450
7)
Mint gsr trans with itr LSD
$700
8)
Fic 1000cc injectors
$200
2- dump tubes
700hp intercooler
Turbo blanket
$3200 picked up
2)
$250
3)
9.2:1 Aries pistons
Eagle rods
Acl bearings
Moroso 5qt oil pan
$2000
4)
$200
5)
Bronze valve guides
$1500
6)
Skunk 2 pro 1 cams
$450
7)
$700
8)
$200
Most items are OBO and included shipping. Please PM me if you're interested in anything... I do not have a use for any of this anymore and need to sell
SLIGHTLY used, (Basically brand new) Aeromotive Eliminator (Red) fuel pump, (12AN inlet 10AN outlet.... Not an A1000) filter and AN fittings. It's seen two dyno runs and two track events. It's in perfect working order. Retails for $580 without filter or fitting..
Comes with everything in picture
$350 shipped (US only) out of country I will not pay for shipping
MSD digital 6 and coil $170 shipped OBO
The coil had been used a bit, but the ignition box is basically brand new... My loss your gain.
Civic PWR radiator with fan, in perfect working shape
$150 OBO....
Precision 1000hp intercooler. Had it set up to exit up top. If this will not work with your set up, it's an easy fix.
$120 OBO
H22 shifter with strain gauge installed by T1 (it was $900 to have this done)
$300 OBO
Racer Steve heat treated H22 gears and FD (BRAND NEW, never used) for sale
Heat treat alone was $250.. Will sell for $400 OBO
The black ones, not the shiny straight cut dog engagement gears
$150 OBO....
$120 OBO
$300 OBO
For SALE!
Racepak IQ3 EFI CAN module for AEM series2/EMS4
BNEW just took out of the plastic to test.
Im just selling the cable. NO IQ3 DASH
300$ shipped FIRM
Paypal only
PM me!
300$ shipped FIRM
Paypal only
PM me!
M/T 24.5x8 13 fronts 22.5x4.5 15 skinnies on Bogarts with about ten runs on them comes with Bogarts lugnuts and washers also. Located in Sacramento CA area. Asking 1000 text at 9165129784
http://www.flickr.com/photos/dsdonejimmy/8378821853/
http://www.flickr.com/photos/dsdonejimmy/7908609016/
http://www.flickr.com/photos/dsdonejimmy/9198866838/
Corey R T4 twin scroll top mount with 2 brand new never ran Precision 46MM wastegates got rid of my car and this is all I have left
$1300 plus shipping for everything
$750 plus shipping for just the Manifold
$300 plus shipping Each for the gates
text 860-335-5090 or email JBLAZE622@netscape.net don't sign on here much
Fastbrake single piston Wilwood rear drag kit brand new never driven on
Finally a rear kit to get rid of the heavy factory rear disc brakes! This kit will drop 15 pounds per side of unwanted weight while still providing the needed stopping power.
Kit uses the proven Wilwood 1 piston slider calipers with 10" rotors.
comes complete with calipers, slotted & drilled rotors, pads, mounting brackets and braided steel brake lines. The kit has been mounted on car for mock up.. Never driven on or even moved. All brand new kit.. Very light with good stopping power. Paid 650 plus shipping from it off fastbrake.com website.
Asking 550 shipped. Please dont low ball me. Great deal by the way.
Please PM any questions or email me elghostface1@gmail.com Paypal preferred..
F/S: Custom H22 T4 Twinscroll Top Mount
Ended up purchasing a forward facing manifold recently so I won't be using this one anymore. Has dual 38mm vband wastegates. Not sure who made it but it's nicely done. Has been sitting for a while and could use a ceramic coating. Only small flaw is runner #1 is slightly flattened. Not bad at all though but it's there. A GT42 fit nicely on this and could probably fit something bigger if you wanted to.
$550 shipped and paypal'd
804 551 8247 if interested
I have custom made AR-FAB Hotrod foward facing turbo manifold with t4 flange with wastegate flange $600.00
Precision 4202R 74mm bb oil and water cooled turbo comes with 2 exhaust housings 1.10 and 1.28 made 1000hp turbo. $1000.00 ( vibrant clamp is not included )
AXLES AND SPOOL ARE NOT FOR SALE.
message me i check daily.
Motec m4 or m48 harness $350
Autometer egt gauge new part number 4344 $100
95 gsr ported head in running condition. All parts are stock in head. $400
used je 83.5mm 10-1 b series pistons with used rings. In runnable condition $200
Z10 dry or wet sump oil pan. Used for running an aftermarket oil pump. You should be able to use with a stock oil pump and pickup too? I am not sure? Also comes with a oil pump delete if you want to run the dry sump. $200
For sale/Trade: 2 x Brand new never mounted M&H 235/60/15.
Located in Central FL.
http://www.mandhtires.com/P235-60-15
321-213-7458
321-213-7458
Hey guys,
I have the following parts for sale. Best means of contact for more pics or questions please text me at 334-797-153(six)
BlueRidge Motorsports Top mount manifold for an h22 with wastegate and precision 6776, turbo is in perfect working condition with no shaft play. -- 600 for the manifold, 600 for the turbo, 100 for the wastegate, or I will take $1100 shipped for the whole setup:
BNIB Skunk2 H22 intake manifold --$200 shipped!
Complete M&W pro10 kit $500
Mark williams axle setup complete with spool $2800
Exedy twin disk b-series $850
DSS 3.9 axles $850
Aem 1000 box $500
1040 box $750
6040 box $1000
b-series ramhorn turbokit NO TURBO $1200
PWR air/water IC setup $300
CP 83mm 9:1 pistons no rings $350
water pump- make offer
modifry- make offer
haltech- make offer
DSS 3.9 axles $850
Aem 1000 box $500
1040 box $750
6040 box $1000
modifry- make offer
haltech- make offer
This car has been in my posession for the passed five years. It was built with full intentions of becoming a SFWD 67mm or 72mm car. No expenses spared on the chassis work. Car has been 6.49@115 with >700whp at 2450lbs. Car drives strait as an arrow and has never felt the slightest bit sketchy at 140+ in the 1/4. Does need paint, and very minor body work on RR 1/4 panel. Throw a drive train in the car and go racing. Price is set at $3000, I am slightly negotionable with the price. I am not interested in parting with any of the items currently on the shell itself at the moment. Please call or text at nine one nine 6975922 for questions as i do not check my PM's often.
1992 civic DX 4 door
phantom grey
Grey interior
Jojo Callos front end-in full primer, not been mounted since leaving body shop having all chips and cracks repaired
VIS carbon fiber Hood
VIS carbon Fiber trunk
Kingpin Machine Outlaw front suspension kit(all spherical bearings in UCA's, LCA's, Compliance bushing)
Ground Control sleeve coilovers- 18k springs in rear, GC standard springs up front
Koni Yellow struts in rear
Blackworks rear LCA's
Skunk2 adjustable front upper Control arms
Full-Race Pro Am traction bars
GSR front brakes with slotted rotors
2 bronze rota slips in rear
2 GSR fat fives in front
Full-race sumped fuel tank
10 pt custom chromoly cage. I built this cage within every NHRA rule to be legal to 8.50. All points welded to floor with 6x6 steel plates, all tubing .082 1 5/8 chromoly. Has rocker bars on each side, along with kidney bar on drivers side, parachute mount tied into cage in trunk area. Strut tower bracing bar in rear. Cage will certify with NHRA or IHRA with no problems.
Comes with 2 new rear doors, RR tail lamp assembly, RR tail lamp filler panel
Also has DSS 5.9 axles up front. Will need stock hub/spindle assembly unless buyer wants to purchase axles with the car.
BRMS top mount twin scroll manifold, T4, twin 44mm wastegate flanged, schedule 40, heavy duty ish, does not include gates, will include dump tubes with full asking price. $750
Borg warner S368 turbo, race cover, 83mm turbine, 1.10 t4 back side, divided housing- $750
Complete M&W ignition- B-series distributor with External coil cap, all modified for M&W, mustang coil, M&W pro 10 box, all wiring included- $600
Custom back door intercooler. For use with BRMS top mount- may work with others. 4" hot side, 3" cold side, vband throttle body flange, tial 50mm bov flange, revhard core. Does not include bov. $400
T-bracket for b-series- 50
Avid solid Motor mounts, these are 100% solid aluminum, no bushings- $250
B-series stock trans mount- 50$
B-series AC compressor mount- $50
b-series starter- $50
B-series harness with all VTEC wiring. Has resistor box wired in for large injectors but can be unplugged. Will need VTEC pressure switch connector- $100
https://fbcdn-sphotos-e-a.akamaihd.n...25618420_n.jpg
phantom grey
Grey interior
Hasport Motor mounts for Kseries for EG/DC2 brand new never open paid $550 asking $500 OBO still in box
Precision Injectors 440cc $120
LS harness $80
Skunk2 shift **** weighted $30
Shoot me a txt 316-609-9427 for pics
LS harness $80
Neptune RTP demon board installed in obd1 Vtec ecu. $475 shipped.
Gsr input shaft bearing BNIB $20 shipped
Skunk2 weighted shaft **** used $25 shipped
NRG short hub adapter for EF/DA used $60 shipped
located in Mobile, AL. text for faster respond 251-6two2-33three4
paypal accepted.
paypal accepted.
Eagle Gsr 900hp Rod, Arp 2000 Rod bolt... No spun bearing $280
JG (B16) Intake manifold $250
BDL 72mm TB with Tps sensor, and 4 Bar Speed Factory Map sensor $250
Skunk 2 Tuner 2 Cams With Blue Skunk Cam gears $560
Hondata CPR Kit $350
Rywire Milspec Harness, including the cabin harness for free (OBD1) With ID2000cc injectors clips $500
Send me a Text 714-388-7303 And im up all times of the day/night.
I very rarely log onto HT so if you PM me don't be surprised if I don't reply... Text me
More Parts to be posted soon...
Might sell if moneys in my face....s2000 is well known car has never been ran or finished been sold a few times I might still keep it but $ talks
s2000 complete drag shell with 10pt cage and parachute
full ford 9inch rear end custom with strange suspension
custom driveshaft ,Rossler built Turbo400 transmission with F20c mount plate ...Turbo manifold down pipes dumptubes
Intercooler ,radiator , waterpump setup, catchcan, Weld wheels all around
Rywire engine firewall disconnect harness, bunch of extra parts etc.
Will sell the whole setup for 12k... This is a serious car for price We are talking about a 7sec s2000 once complete....Everything brandnew never used.....Serious people only please thanks.....(no lowballers don't need to sell it it can sit there lol) pm or text 214-576-6367
For Sale, Brand new, FMIC built by Go-Autoworks, the GT1000 950HP Garrett core, 12x24x4.5, 3"single backdoor, 3" side cold exit, still in original Bubble wrapping, only reason why I'm selling it is cause I'm parting out my stuff...Paid almost a Grand for it, shoot me an offer.......Never been mounted...PM me lets work out something...
H22 Race parts
4piston CNC cylinder head - $1900
http://www.team4piston.com/ProH22.html
-- NEW Skunk2 Pro series valves
-- short-term used Skunk2 Pro series retainers and springs
-- 4piston bronze valve guides
-- fresh resurface, new valve seals
-- 89mm counterbore
-- valve deshrouding
-- valve train setup to 80lbs on the seat
H22 Kinsler 62mm Individual Throttle Bodies -- $1600
-- port matched to 4piston intake port
H22 Skunk2 Pro series stage 3 camshafts - BNIB $550 - $700 with gears
BME H23 aluminum rods - $300
-- 89mm counterbore
Custom B series T4 38mm flange divided bottom mount manifold. Great quality, great weld and awesome all together. Will come with two dumptubes. Only reason I am selling because I chose a top mount instead. Asking $700
Only trade I would accept is AEM V2 6050 or 6040.
Pm me or text (718) 413-6348
