July FS thread
Old Jul 10, 2013 | 10:25 AM
  #26
luck4rmkc's Avatar
Default Re: July FS thread
Description:
Built GSR longblock
81.5mm stock sleeve GSR block
9:1 SRP/JE pistons
Eagle rods
OEM GSR crank
ACL race bearings
GSR head
GSR cams
Supertech springs and ti retainers
ARP head studs
Bare longblock only no covers/oil pan/water pump/tensioner
This engine was built properly by myself (ASE certified master tech and former Honda technician). I can supply specific specs P2W, bearing clearances and ring end gaps if requested. It has made as much as 601whp on a 6262 turbo tuned by Chad at MKC.
This motor has proven itself to be extremely solid and built to last. Plenty of people locally can vouch for this if needed.
I'm asking 1800 for the longblock and I will throw in the clutch in the pictures if you pay 2k. It is an ACT with max extreme PP and sprung six puck disk.
PM me for details
Old Jul 10, 2013 | 06:24 PM
  #27
rota92
Guest
Posts: n/a
Franks EG front end.
With a tree installed.
I'm gutting the shed it's been stored in for demo. Come and snag it if you need it.
Old Jul 10, 2013 | 08:04 PM
  #28
Nutzurchin's Avatar
Eagle rods for BI8C with ARP2000 big bolts, used but in great condition, low miles, like new. Recently has been lightly honed by the machine shop, never had a spun bearing or overheating. Still uses standard size bearings.
$220 shipped usps priority mail with tracking
please text me at 925.586.seven3seven1
Old Jul 11, 2013 | 06:47 PM
  #29
mint's Avatar
Sold!
Old Jul 11, 2013 | 09:22 PM
  #30
duugle's Avatar
SOLD
Old Jul 12, 2013 | 08:38 AM
  #31
tootski14's Avatar
Chris 256-476-4130 tootski14@hotmail.com
3000.00 obo
Built H22 longblock only. Stock sleeve, bore 87.25mm Mahle 9:1 compression. Eagle H beams, Honda bearings, gaskets, seals, belts. Brian Crower valve springs and retainers, REV valves, Fidanza cam gears and 8 lb flywheel. Skunk2 Tuner 1 turbo cams. Cometic head gasket, AEBS head studs.Type S valve cover. Engine only has 4500 miles and made 415whp on 16lbs with GT3582r. Conservative. 3000.00 obo. Buyer pays shipping. Paypal verified.
Old Jul 12, 2013 | 09:32 AM
  #32
GT30EK's Avatar
Brand New!!! K24 CP Piston 11.5:1 - 87.5mm. 450 Shipped!!!
GSR Benson sleeved block 85mm with .0045 piston to wall clearance $1800
CP Pistons W/heavy duty wrist pins 9.7:1 W/B16 Head or 10:1 W/GSR Head
Pauter LS Rods
Comes with type R oil pump and rear main seal.
Motor is two years old, and about 30 1/4 passes.
GSR ARP Studs SOLD
3 Inch SS Exhaust with Magnaflow muffler for Ek Hatch 200 Pick up ONLY located on Long Island NY.
FJO Wideband with NTK Sensor 100 Shipped
Includes Controller, 4ft sensor wire, and NTK sensor. All perfect working shape
Old Jul 12, 2013 | 10:06 AM
  #33
honda_12V's Avatar
SOLD
Old Jul 13, 2013 | 06:32 AM
  #34
Tuner Eddy's Avatar
Selling my current setup to go bigger. Motor made 524hp on a 6262. It runs absolutely perfect. The long block asking price is $2800 OBO and consists of:
D16A6 block
Darton Sleeved
75.5mm 9:1 pistons
Scat rods
OEM Honda bearings and pump
ARP headstuds
OEM D16Y8 head gasket (total compression is 9.7:1)
D16Z6 head
Ported and polished
Crower retainers
Supertech valves
GO-AUTOWORKS Spec Camshaft by Web Cams
AEM Cam gear
GO-AUTOWORKS Rear block plug
STR (GE) Intake manifold (ported to match head)
GO-AUTOWORKS Thermal intake manifold gasket
68mm Throttle body (intake manifold inlet was ported to match the throttle body)
GE Throttle cable bracket
AEM Fuel Rail
Speed Factory D2B kit, includes brackets and CC d2b flywheel. -- $700 OBO.
I'm parting out my turbo kit as well:
Go-Autoworks Top Mount Manifold and Modular 2 piece downpipe (2.5" to 3" B-Band) (d-series) -- $700 OBO
Go-Autoworks GTC dual backdoor FMIC w/ 600hp Garrett core (3" intercooler piping that can be modified to fit a B-series, everything is V-Bands) -- $700 OBO
Precision 1000cc injectors -- $250 OBO
3" Straight Exhaust, turns down just before the gas tank -- $200 OBO
Precision 6262 .63ar (100 miles on it, works perfectly) -- $800 OBO
I'll sell every part of the turbo kit listed for $2500 OBO, or you can buy the longblock, d2b kit and turbo kit together for $5200 OBO.
Best means of Contact is texting, 334-797-153(six)
Pics:
Old Jul 14, 2013 | 05:01 AM
  #35
TopEndUSA's Avatar
-$1725 shipped - Precision 4272R turbo, T4 split scroll exhaust 1.28a/r (turbo has 10 1/4 mile passes on it. looks new still, no shaft play, exhaust housing is heat coated black.)
Old Jul 14, 2013 | 06:01 PM
  #36
porkythegrunt's Avatar
EK B/D solid black innovative "race" mounts
$250 shipped (please add 3% or gift)
EK T4/44mm B-series forward facing manifold built by precisionfab1.com a couple years ago, only seen idle time.
Painted black, comes with studs/nuts and gasket, was made for an EK.
$750 shipped (please add 3% or gift)
How it looked prepaint:
only seen idle time on pumpgas
fiveomotorsport 1600cc high impedance injectors (ID replicas/UScar, for B-series, can work with other makes/models with different top hats, part number 0426HONB1600X - may be discontinued, but give fiveomotorsports a call if you want to use it for something other than a B-series Honda. Can be used with ethanol or gasoline)
- $400 shipped (comes with T1race OBD2 to UScar adapters/pigtails)
Please include 3% or gift
Old Jul 15, 2013 | 03:05 PM
  #37
ShawnR's Avatar
pm/ call or text 757-621-8641
Wilson 80mm throttle body brand new have 2 of them $250 each
Brand new Catch can - $150
Brand new hybrid racing tensioner -$275
Spec clutch flywheel with arp hardware - $100
Old Jul 15, 2013 | 03:54 PM
  #38
98B18C1's Avatar
taking offers at this point to see what I can get for it. If the price is right I will sell the shell. Comes with:
- certified 10 pt roll cage good up to 8.50 or slower
- exospeed 3 piece front end
- CCC drag wing polished
- jdm white face cluster
- climate control
- audio console
- sumped stock fuel tank with aeromotive a1000 fuel pump and aeromotive filter with -10 feed and -8 return.
- Brake line tuck with tucked prop valve inside
- Fresh paint job outside and engine bay (shaved)
- Parachute mount with simpson parachute
- Full wire tuck (headlight harness)
NOT PARTING OUT! Please no lowballers or trades (you should know how much it cost to build a shell of this magnitude)...
Old Jul 16, 2013 | 08:03 AM
  #39
Turbo-LS's Avatar
All prices are OBO unless otherwise noted and do not include shipping costs or paypal fee's PM me or TXT 2034102574
Precision .63 T3 66mm turbine housing 5 bolt $75
Walbro 450 E85 fuel pump SOLD
Golden Eagle LSVTEC kit (no HG) $100
Used Wideband Sensor for Innovate LC-1 $35
New Wideband Sensor for Innovate LC-1 $50
Home Made 5 bolt to vband adapter, 3" vband downpipe for top mount, vband clamp $150
Precision 600hp Intercooler SOLD
B18C bare block missing middle caps and girdle SOLD
B18B Bare block with golden eagle block guard $150
B18B ERL Sleeved block 84mm ARP Mains Needs Alignbore PRICE DROP $550
B Series Inner Transmission Case $100
B Series Flywheels $50 Each
DC Ac system everything under the hood $150
OBD2 LS valve covers $50 each
Carburetor Syncronizer Brand New $75
AEM Twin Fire Unknown Condition Missing Harness SOLD
RCI 2050D 5 gallon Fuel Cell with straps and Misc Fittings $100
Old Jul 16, 2013 | 02:43 PM
  #40
xxjonxx4's Avatar
PRICE DROP !!!
Im selling my internals from my 97 GSR everything is in mint condition no spun bearings i overhauled the motor for forged internals and a stroker crank. Motor had about 65,000 miles. I am also selling a LS Bare block and its internals; i pulled this motor from a scrap yard and disassembled it for cleaning. Everything is ok with the block no signs of spun bearings in the mains etc. Just needs to get rehoned to get the rust on the walls cleaned up. Also have the LS rods and pistons FS. Rods are in mint condition. If you have any questions or concerns please text me anytime before 10 pm eastern time. I will ship at buyers expense, I am also paypal verified. Thanks
GSR CRANK-170
GSR RODS AND PISTONS-100
LS BLOCK WITH MAIN CAPS-SOLD
LS RODS AND PISTONS-50
LS CRANK-120
Old Jul 16, 2013 | 08:21 PM
  #41
paulzy's Avatar
FS: Brand new sumped fuel tank for 199-2000 civics. Should fit other years as well but that's for you to check. Tank is made by Dorman. Has a stainless steel sump with a single -10AN bung. Sold my car so I don't need it anymore.
$280/obo
The tank alone was over $200
Old Jul 17, 2013 | 06:08 AM
  #42
MR.johnson's Avatar
all prices are BEST OFFER.
Brian Crower springs and retainers. 95psi installed seat pressure. 200 obo
stage 4 6puck with extreme pressure plate. BNIB never opened bags. 400obo.
hoosier QTP 11.5x26x15 were on the front of my civic for 2 months alot of life left.
Old Jul 17, 2013 | 10:54 AM
  #43
KStuned's Avatar
*** IF IT’S NOT LISTED HERE THEN IT’S NOT INCLUDED!***
Rolling chassis means no engine, no transmission!
KSTuned 1996 Outlaw EK Civic
BEST ET: 8.47
BEST MPH: 179
Sold as a rolling chassis with fresh paint (2009) and new Chromoly cage, SFI Spec 25.5 (May 2013)
$12,000 with everything listed below!
FEATURED IN HONDA TUNING MAGAZINE (Race Issue 2011)
Car was completely stripped of all of it’s undercoating and paint from the interior and exterior. Professionally repainted inside and out in 2009.
SFI Spec 25.5 NHRA Certified Roll cage (Certified in May 2013, good through May 2016). Fabricated by Andy Divers from KAIZENSPEED from Chromoly tubing.
We took a stock 1996 Civic Hatchback and stripped it completely down to bare metal starting in 2006. We completely stripped the car of all paint inside and out, and even underneath. Then we began with the roll cage, adding gussets to the A-pillar bars and stitch welding the entire front and rear of the car. Every critical unibody panel has been stitch-tig welded together for consistency under pressure (numerous hard launches with 1,000 + wheel horsepower). The car was painted in 2009 and we began racing in 2010. Within a few months we had broken the 8 second barrier. Spring 2011 we transformed the car to compete in Outlaw Street and did very well. We competed in Vegas, Washington and Oregon. 2012 we ended up with a best ET of 8.47 and a best MPH of 179!
This car currently holds the record for quickest and fastest FWD H22 powered street car. The chassis is in excellent shape and the paint looks like new.
The chassis will accept any engine (B-series, K-series, D-Series, or H-Series)
INTERIOR:
NEW SFI Spec 25.5 Chromoly cage, NHRA Certified May 2013
New Simpson 5 point harness
Kirkey aluminum drag seat and Kirkey seat cover
New RJS window net
CNC stage brake with master cylinder and reservoir
OEM EK dash with center blockoff plate
EXTERIOR:
Stroud Parachute with chute mount
Ignition switch panel with four switches (Ignition, Start, and two for whatever you want)
Exospeed 3 piece front end
KAIZENSPEED EK DRAG WING
Carbon fiber hatch
Carbon fiber hood
New headlights purchased May 2013
All OEM glass purchased new in 2009
MECHANICAL:
Custom front ballast bar and traction bar with ballast plates attached
KAIZENSPEED 6 gallon ice water reservoir with Rule 3700 electric water pump,
Precision Turbo PT1000 Air/Water intercooler.
EG front subframe and steering rack
Rear wheel speed sensor with signal converter
Custom B-series shift linkage and Skunk 2 shifter
Kingpin machine spherical bearings for front LCA’s
KAIZENSPEED Front Drag Brakes and stainless brake lines with DSS hubs with extended lugs at all four corners
KAIZENSPEED lightweight rear drag brakes
Brake booster delete plate and Wilwood brake master cylinder
Battery kill switch with wiring and firewall pass-thru’s
Skunk2 Pro-Series Plus front camber kit
Skunk2 Pro-Series rear camber kit
Old Jul 17, 2013 | 01:08 PM
  #44
yzracer323's Avatar
These parts have only seen dyno time. Everything is in perfect working condition.
*Located in North Beach, MD for local pickup. Shipping is available(Buyer pays shipping and Paypal fees.)
*Best to contact me at yzracer323@aol.com
700+whp Turbo kit, B series
-Garett t67, divided .84a/r exhaust housing
-Custom h&h top mount manifold, T4 divided
-Dual tial MVS 38 mm wastegates with dump tubes
-Tial Q 50 mm bov
-Custom dual backdoor intercooler, using Garrett core. Includes mounting brackets
-3” aluminum charge piping using all Vibrant Vanjen clamps
-S90 billet Throttle body with Vanjen connector
-3" vband up pipe
-Brand new, never used boost solenoid with push lock fittings/hose
- 3AN feed & 10AN return lines
Asking $2800/best offer **Sale Pending
Edelbrock pro flow fuel rail, B series $90
Adjustable FPR, Free if you want it & buy something
M&W pro 10 Box, Crane coil, harness, and mounting plate $550/obo
Magnafuel MP7008 Inline fuel filter $60/ea
Genuine Bosch 044, with -10an adapters, like new $150/ea
2x, Mac boost solenoids $40/ea
Catch can/lines $100
FCS 5 gallon fuel cell $390
T1 dual 044 pump hanger $90
Comp twin disc, dyno use only, like new $875
Full-Race EG/DC traction bar SOLD
B16 Trans: Freshly rebuilt, Quaife LSD, Hardened gears, 5th gear cuff. Have an LS 5th if needed. $975 picked up
Old Jul 17, 2013 | 05:34 PM
  #45
Mo_Spec's Avatar
Selling Quaife for LS/b16 trans. The diff has 7 track hits on it and a little dyno time. Selling because we are upgrading to DSS Pro stuff.
NOW ASKING $650 obo
Free Shipping!
Old Jul 17, 2013 | 07:28 PM
  #46
MrParks's Avatar
used fcs race 5 gallon fuel cell off the grey car. -10 feeds and -8 return. comes with new straps and hardware
350.00 mint cond.
msd blue coil mint cond. comes with coil wire.
100.00
aluminum battery box. comes with all the hardware straps and bolts to safely keep your battery in place. made from 5052. used. (picture is when it was new. comes with everything.
80.00
turbosmart hyper 45mm gates. got 2 of them off the grey car. in very good condition. comes with 8lb and 14 lb springs and all the fire rings, and new flanges to weld. i have 2 of them.
300.00 ea.
media blasted cover, baffled -10 fittings. oem baffle has been removed to make sure no media has been caught inside. used.
75.00
afx ntk wide band kit mint condition.
200.00
place racing b series crx civic 88-91 mount kit. used in very good condition
80.00
fcs race battery location fuel cell never used but light surface scratches.
275.00
fuel cap plastic new.
30.00 shipped
borg warner airwerks s400sx 72mm turbo.
specifications: ported housing, 72mm inducer extended tip technology, new inconel 87mm/83mm ti wheel modified 1.25 a/r housing est 1.30 a/r
hyrdo dynamic bearings
1900.00 new.
all items are first come first serve.
paypal is info@fcsfab.com
all items are used unless specified.
for quicker response please email info@fcsfab.com
Old Jul 17, 2013 | 08:43 PM
  #47
kartunezgsr's Avatar
B series Ati fluid damper street pulley does have a chip on da edge due the pully removal tool slipping off I'm askin 220 shipped and pp
Old Jul 18, 2013 | 07:10 AM
  #48
turbo-2nr's Avatar
Lenso before they were exospeed VPD drag wheels
with mickey thompson 24.5 x 7 slicks in great condition $400 shipped
Quaife LSD for sohc transmission the one with the bigger bearings $350 shipped ppd etc
comes with ring gear lol
call/text 817-992-1706
Old Jul 18, 2013 | 10:17 AM
  #49
FRernesto's Avatar
Up for sale is this Edlebrock 65mm throttle body part number EDL- 4790. Asking 175.00 and will ship in a flat rate box for free, Please include paypal fee. The throttle body is in perfect working condition and the TPS does come with it.
Old Jul 20, 2013 | 02:19 PM
  #50
SynTeg's Avatar
New G-FORCE 7000BK 5-Point Harness Black $120 shipped obo
New G Force 4122LRGBK SFI Helmet Support Large Black $35 shipped obo
Used Tial 38mm MV-S black V-band. 6 lb spring $200 shipped obo
New BDL Ind. B-Series Adjustable Cam Gears Black $130 shipped obo
Prices are all or best offer. Email me at SynTeg@gmail.com or Text 702-757-1313
