Jan FS Thread
Old Jan 5, 2012 | 02:24 PM
  #51
JamaicanDave's Avatar
Default Re: Jan FS Thread
3pc exospeed **CLOSED FRONT** -PM for details
cms racing spindle mount 15x4 make offer
KensKustom wheelie bar un-used 550
franks fiberglass hot rod style 1pc front end-- make offer
P29 pistons and rings 100
**items for sale do not include shipping or pay pal fees**
Old Jan 6, 2012 | 08:31 AM
  #52
sq_creations's Avatar
Aem fuel rail, Aem regulator and 1000cc Low impedance injectors - $400.00 obo
Genuine Hondata intake manifold gasket b16/b18c5 - 20.00
Autometer Phantom 5inch Tach with shiftlight - 180.00 obo
Liberty Cuff:SOLD
b16a head with skunk 2 springs and retainer (HAS 2 BENT VALVES) $SOLD
Vortech Aftercooler (just the cooler) I think it was intended for a mustang but would fit great on a honda - $SOLD
Professional Products b series Throttle body 68mm (measured at 70mm) - SOLD
Shipping not included
Old Jan 6, 2012 | 11:15 AM
  #53
ninesecrx's Avatar
Default Motec M4 or M48 Harness
I have 2 harnesses for sale. They can be used with the Motec M4 or M48. One was made at Motec with all milspec parts. $1000 obo for that one. It even has the B series Dist. set up for timing which is included. The other was made from a shop. It was made to hook into factory honda parts like the dist. and such. $600 obo for that harness. Both came off running cars.
Old Jan 6, 2012 | 11:43 AM
  #54
Dynamic Performance Racing's Avatar
Rolando Blanco
Dynamic Performance
198 Rt. 206 Unit 1B
Hillsborough, NJ 08844
908-829-3707
Selling two sleeved GSR Blocks. The first one is a Benson Sleeved B18C and the second is an ERL Sleeved B18C1. Both are 84mm. The Benson Sleeved block might need to be bored out to 84.5. $1000 Each.
Benson Sleeved B18C - $1000 (Bare Block Only)
ERL Sleeved B18C1 - $1000 (Bare Block Only)
SPEC Mini Twin for B-Series - SOLD
For more photos and description, please visit: http://www.facebook.com/media/set/?s...1807535&type=3
Last edited by Dynamic Performance Racing; Jan 9, 2012 at 07:15 PM. Reason: SOLD Twin Disc
Old Jan 6, 2012 | 07:15 PM
  #55
jdm.fanatic's Avatar
selling a package deal for a built d series.
cp pistons 75mm
eagle rods
acl race bearings std size includes thrust washer.
arp head studs.
cometic head gasket.
skunk 2 adjustable cam gear.
y8 head complete with dizzy clean and checked redy for install.
everything brand new in box $800 text or call justin 208-968-8362 anytime
Old Jan 7, 2012 | 09:14 PM
  #56
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Means of contact: 240-217-0647
i recently acquired jason hunts old ek civic coupe in a deal. i was thinking about keeping the car but i already have one race car to maintain and no way i can afford to keep 2 so this one has to go.. best way to contact me is call or text 240-217-0647
chassis...$3000
96 dx coupe.
12 pt chromoly cage with parachute mount. cage is out of cert but should pass with no problem.
stock gauge cluster has been replaced with all autometer gauges. sparco racing seats with 6 pt harness
will be sold with stock suspension
engine..engine was completely rebuilt by justice racing engines in 2008. car has not been on the track or dyno after rebuild.has been sitting inside a garage. started 2 times $3000 obo may part out head from the block if i get good offers
darton sleeved 85 mm
erl 5 pt main girdle
manley turbo tuff rods
cp 9.1 comp pistons
13mm head studs.
ported b16 head done by justice racing.
ferrea valves, valve springs and retainers.
ctr cams with venom cam gears
golden eagle intake manifold with 70mm tb SOLD
turbo.. would like to sell everything as a kit but if i have to i will part it out.. everything listed below for $2200
full race top mount with 44mm gate.. this is a old old full-race manifold SOLD
borg warner s372 sold
18x12x4 garrett intercooler back door. $500
3" piping with twin tial bov's $350
4" down pipe with burns muffler and 4" aluminum exhaust $400
turbo xs 4 stage manual boost controller.$200
fuel system...
sumped oem tank $200
dual bosch 044 pumps with venom filters $300
venom fpr $100
new in box 1600cc injectors sold
bogart fly star's 15x3.5 rears..sold
MSD 7560 Programmable 5-stage delay timer $200
bogarts.. sold
engine.. sold
turbo manifold.. sold
turbo....sold
catch can ..sold
scatter shield... sold
traction bar....sold
im parting out this complete car so if you see anything you want thats not listed feel free to ask
Old Jan 8, 2012 | 02:20 PM
  #57
RattyTuned's Avatar
full b16a2 longblock includes intake manifold,injectors,clutch assembly,throttle body
70k on the motor
vin:4304158
looking to get 700 firm!
full k20a2 longblock includes intake manifold,header,throttle body,fuel rail,fuel injectors,harness,all pulleys
30k on the motor
vin:2421509
looking to get 1500obo
pm me on here or shoot me a text at 215 290 7412
Old Jan 8, 2012 | 02:53 PM
  #58
haas480's Avatar
Full-Race T4 divided front mount manifold - SOLD
wiseco/cometic DOHC VTEC head gaskets (as seen above^)
- (1) 84mm std 0.030" thickness
- (1) 81mm std 0.030" thickness - SOLD
$60 shipped & paypalled each.
PM me.
Old Jan 8, 2012 | 03:14 PM
  #59
theidealone's Avatar
I would rather sell local, so the buyer can see the block in person, prior to purchasing. But Ill list it here.
B16A2 Block. 85mm Golden Eagle Sleeves.
Problems:
Cylinder 1 has some scratches on the sleeve. Looks like piston skirt slap, but theyre semi deep. Maybe a broken ring? I purchased it like this, so I dont know. Two vertical scratches. Im no machinist, or professional builder. But if I hadnt decided to go single cam, I would either hone it, and run it, or bore it, and have custom pistons made for it (i.e. 85.2mm or something, obviously dependent on machine work needed).
The Oil Pressure Sending Unit port on the back broke (the block casting). Weld a piece of aluminum to plug it, and run a sandwich plate. Problem solved. Not a big deal, but I dont want to leave anything out.
Looks like it had Time Serts installed in a few of the head stud holes. Two of which look funny to me. Excessive epoxy or something built up above the Time Serts themselves. I think if you clean it up, and drill out some of the epoxy, itll be fine. One of the holes threads, the other threads into the epoxy, and gets hard to thread past. May need a Time Sert or two replaced. All other holes thread great.
I have NOT used this block. I dont want to hide anything. Im trying to be very up front, and thorough. If anyone is serious, I can take better high resolution pics, and see if I can show everything to the best of my ability.
The scratch in the sleeve
The "epoxy" in one of the two holes.
Block does come with matching caps. And if the buyer wants it, or the offer is right, I will include the crank.
Make me an offer. I dont know what this might be worth to someone. I really just want my money back, so I can put it into my single cam build. I WILL CONSIDER ALL TRADE OFFERS. Id love to get a 6262.
Old Jan 9, 2012 | 09:38 AM
  #60
TempestRacing's Avatar
Precision 7285 (72mm billet compressor wheel /85mm exhaust wheel in a gt45 housing, ball bearing) for sale. less than 10 passes on it. call or message for details 301 855 3392
Old Jan 9, 2012 | 08:54 PM
  #61
Wayeng's Avatar
Neng Yang
651-442-8357
I have a brand new gt42R twin scroll turbine housing 1.15AR . Call me if you want more details. I bought it for 2K and selling for 1K that is a steal.. Brand new never installed. My loss your gain.
http://www.flickr.com/photos/64601281@N07/6671401115/
http://www.flickr.com/photos/6460128...n/photostream/
Old Jan 10, 2012 | 09:46 AM
  #62
AR Performance's Avatar
I have a 1994 Honda Civic that i am selling, car runs 10.1 @ 139 all day, vehicle is street legal & has a clean title. Car has an LS vtec, list of parts are custom ram horn turbo manifold paired with a turbonetics 6965 ball bearing turbo, edlebrock victor x intake manifold, tuned with hondata s300, CP forged pistons with GRP aluminum rods, custom fuel system that includes 1600cc injectors backed by an Aeromotive A1000 fuel pump & custom aluminum fuel tank, competition twin disc clutch, 5th gear eliminated and added the cuff for more strength, and Bogart wheels 13x9 in front 15x4 in back. Car also has 8 point roll cage.I am looking for $7000 or best offer for the car, DO NOT low ball offer because i will not respond and YOU WILL BE WASTING MY TIME, i will just keep the car if you low ball offer me. For any further questions please call me or text me @ 954 548 6391.
Old Jan 10, 2012 | 02:22 PM
  #63
allmotorhatch's Avatar
FS: Avid Racing SOLID mounts for a B series swap in an EK.
These are BRAND NEW
$300
Old Jan 10, 2012 | 06:28 PM
  #64
GT30EK's Avatar
Will Sell as a Kit for cheaper, but with No WASTEGATE.
Also will sell intercooler, piping , and BOV separate.
Full Race Ram Horn Non A/C T3 44mm wastegate flange. (Includes Manifold, V Band Down pipe, and Dump tube for 44mm wastegate) 900 Shipped
Full Race Back Door Intercooler 20X11X3 with Piping to throttle body with all T bolt clamps and Couplers. and Tail 50mm BOV. Full Race says it's good to 720whp, I made 805Whp with it no problem. 900 Shipped
BEP S366 T3 .70 A/R Vband exhaust . Made 805WHP @ 32Psi on 2.0L B-Series. Have about 30 Pass on the turbo, NO Smoke runs mint. 700 OBO Shipping. PENDING SALE!!!
Dyno - http://dynos.evans-tuning.com/2010/1...540tq-aem-ems/
3 Inch SS Exhaust with Magnaflow for Ek Hatch 300 OBO Pick up, maybe will ship.
Old Jan 10, 2012 | 06:39 PM
  #65
Cimburke23's Avatar
NEED THESE SOLD ASAP!!!
Price: $700 OR BEST OFFER NEED SOLD ASAP!!! shipping not included
Description: I have a forward facing manifold that i had on my integra. I made it personally, fully tig welded, flanges are 3/8" mild steel, piping is schedule 10 stainless. it will never crack or have any problems. I personally made 647whp@25 psi on a stock sleeve, stock port gsr setup with this manifold and a 6262 billet turbo. i will include both downpipes, both 38mm EMUSA vband wastegates with 7psi springs and both dumptubes, and all fittings and hoses in pictures. manifold is black high temp (2000deg) coated, but some has been scratched off. also including stainless braided return line, can also include a tapped GSR oilpan if the price is right
Pictures:
complete setup with side exit downpipe
close up of manifold:
downpipe that goes under the oilpan:
Old Jan 10, 2012 | 07:02 PM
  #66
lvdb-2's Avatar
competition 12lb flywheel ready to be installed bought new used for 6mths slipped a clutch so upgraded to a twin,recently reserfaced at local machine shop asking 160$ shipped and fees lmk 702-287-0150 Robert
Old Jan 11, 2012 | 08:27 AM
  #67
92tealhatch's Avatar
rc 1200cc b series $250
Victor c intake $250
Golden eagle scatter shield $125
Synapse motorsport twin gate top mount with dump tubes/hot side charge piping $750
2 tial 44mm v band wastegates $200 each
T1 cam trigger with Golden eagle gears $350
AEM engine management $500
Dual Bosch 044 pumps with hanger lines fittings filters sumped tank(EG)$750
Edelbrock fuel rail $75
AEM Pressure reg $75
GSR valve cover powdercoated black 2-10an fittings in front with catch can setup $250
2001 GSR trans M factory straight cut PRO series 3rd 4th with M factory 5th gear delete collar 4.05 M factory PRO final drive,Quaif LSD, less than 500 street miles and only 3 passes synapse motorsports built $2750
all prices are without shipping and paypal fees
Old Jan 11, 2012 | 11:53 AM
  #68
200 HP's Avatar
Full Race T4 Ramhorn Turbo Manifold w/ V-band for 44mm wastegate.
$699 obo
Old Jan 11, 2012 | 07:34 PM
  #69
slowboy90's Avatar
Means of Contact (PM? Email? Phone?): 336-345-2666, pm
I have my current race motor forsale
85mm aebs ls block
ls crank
brian crower race rods
wiseco pistons
acl race bearings
oem honda oil pump, new oem water pump
gates kevlar belt
blox cam gears
b16 head ported
supertech valve springs and retainers
gsr cams
cometic gasket
golden eagle head studs
aebs intake manifold
2900 obo all you need is a dizzy and tb to make it run car made 710 on 28psi on a t3 s366
fully adjustable shift light
i may have a bare gsr head forsale disassembled
Turbo kit
SLS twin gated t3 top mount
S366 t3 .70ar
3in vband down pipe with flex and heat wrapped
twin purple fullrace mvr-44mm
treadstone 1000hp intercooler with twin full race purple bov's welded on
vibrant vanjen clamps on intercooler and 3 inch piping for a dc2
fic 1650cc injectors
text for pics ill update as i go through my parts
also have a 4 in downpipe for a top mount into dc2 flex with vbands on both ends tig welded stainless
brian crower 95mm b series crank with rods and 84 or 85mm (cant remember size right off) cp turbo pistons
84 or 85mm aebs sleeved ls block fresh line hone with erl 5 point main girdle
i also have almost complete da interior
dss 5.9s with gsr spindles
18k skunk2 rear drag springs
exospeed 3 piece front for dc2 bnib
http://s1126.photobucket.com/albums/l616/slowboy90/
Old Jan 11, 2012 | 08:53 PM
  #70
PRO1's Avatar
RLZ LSVTEC ALL MOTOR LONG BLOCK
MOTOR Has less then 50 Miles Made 255whp On E85
b18 Block AEBS SLeeves,Endyn Pistons, Eagle Rods,LS crank
b16 RLZ CNC PORTED RACE HEAD RLZ Springs,TI Retainers, Ferrea Valves
Skunk2Tuner3 Cams
Edelbrock Intake Manifold And Fuel Rail. RC 440's BBK 70pmm T body, AEM cam Gears, Golden Eagle Lsvtec Kit
Comp Clutch stage 5. Complete Long Block.
Fully Built ! All Work Done By RLZ, Ready to Go ! Asking Price $4000
Carbon Fiber EG Wing $400
Carbon Fiber EG hatch $4oo
RLZ Fiber Glass Race Wing $300 Shipped
SLS T4 Topmount 4inch Down Pipe,Dump Tube and Tail 44mm Waste gate, Has 2 passes $1300
Brand New MSD Pro Billet Bseries Make Offer
[IMG]
[/IMG]
Old Jan 12, 2012 | 03:30 AM
  #71
Topdawgg's Avatar
FS: FULL RACE Intake manifold for GSR
Looking to get what I paid for it. 650$
Bought this from Jason Hunt a month ago..Thought it was b16/type R.
Also can include a 76mm Accufab throttle body (also in picture) for 700 +shipping
Old Jan 12, 2012 | 04:11 AM
  #72
KleenKrew's Avatar
freshly powder coated black 13" weld magnum centers 4x100
200.00
gsr cams with/gears and new oem seals
100
Old Jan 12, 2012 | 01:43 PM
  #73
DxTrix's Avatar
New 109 H stroker setup 89mm ross pistons Cunningham rods $1100 plus shipping
http://s51.photobucket.com/albums/f3...20h%20stroker/
New Arias H 87.5mm turbo pistons $450 shipped
New Arias H 89mm 16.5:1 pistons $550 shipped
H22 Hytech turbo manifold t4 $800
http://i51.photobucket.com/albums/f3...0960414658.jpg
http://i51.photobucket.com/albums/f3...5-05192524.jpg
http://i51.photobucket.com/albums/f3...5-05185917.jpg
PWR liquid to air with aluminum water tank and water pump $700 plus shipping
http://i51.photobucket.com/albums/f3...101806-1-1.jpg
http://i51.photobucket.com/albums/f3...2-07163304.jpg
http://i51.photobucket.com/albums/f3...2-07163345.jpg
http://i51.photobucket.com/albums/f3...0-11101816.jpg
http://i51.photobucket.com/albums/f3...0-11101806.jpg
Old Jan 12, 2012 | 07:41 PM
  #74
xsi-t's Avatar
Fs AEM 1040
$500+ shipping.
Old Jan 13, 2012 | 01:28 PM
  #75
jdm_ef9's Avatar
Items for sale are from our All Motor B-Series setup. Please message me for any questions.
OBD-1 AEM Series 2 EMS
$925 Shipped
RLZ CNC Ported P72(GSR) Head
Comes complete with caps and Supertech valvetrain. Has oversize IN valves. Has less than 20 miles on it.
$1100 + S/H
Competition Clutch Twin Disc Clutch
$$$ SOLD $$$
SSR Street Sweeper Stainless Header
Comes with megaphone/reverse cone and v-band
$900 Shipped
Golden Eagle Scattershield
$$$ SOLD $$$
Kinsler Custom ITB Setup
P72 head. Uses ID injectors(not included)
$1500 Shipped
Exospeed VPD/XPD Wheels
$$$ SOLD $$$
Vibrant Timing Belt Tensioner
$75 Shipped
