Jan-2011 FS thread
Old Jan 4, 2011 | 08:47 PM
  #51
cloviskilla's Avatar
Default Re: Jan-2011 FS thread
i have a built b20/gsr its two days old still in my ef. you can come see and drive the motor,comp test . i can tape engine running and comp test. i come on hard times and need cash for lawyer 1400.00 plus shipping obo heres the build.
offers welcome
84mm b20 block
decked and honed bye a sunnen
fully balanced
gsr crank
i beam lightweight rods
acl bearings
13:1 weisco teflon coated forged pistons
portflow ported b16 heAD
arp head studs
new vtec oil pump
endyne lsvtec kit
skunk 2 valves
serdi 5angle valve job
brian crower stage 2 cams
brian crower springs titanium retainers
supertech teflon valve seals
aem cam gears
cometic head gasket
all new gaskets
Old Jan 4, 2011 | 11:17 PM
  #52
Blueberry1320's Avatar
Gsr trans .. Extended first (3.07) mfactory diff.. N carbon coated syncros...no grinds ..1500$ local pick up!!!
Exedy twin disc 700$
Pm for pics if interested
Old Jan 5, 2011 | 02:25 AM
  #53
EP3Moschini's Avatar
First is a brand new Avid racing traction bar set-up I will let it go for $250.00 + shipping since its brand new and thats about $50.00 less than retail
next is a set of used Avid racing 70a DC/EG motor mounts (lifetime warranty) $200.00 shipped
also have an edelbrock d16y8 intake manifold with 70mm BDL throttle body, omni tps, and BDL fuel rail price is $400.00 + shipping or I will part the throttel body from the manifold if I can get both to sell individually
Old Jan 5, 2011 | 05:58 AM
  #54
Big Teggie's Avatar
Contact Info
E-Mail – BigTeggie@gmail.com
PayPal - BigTeggie@gmail.com ADD 3% FEE to listed price if you choose PayPal
Please Email as my PM’s fill up quickly
Please click on the thumbnails for larger images
RLZ All Motor K24 Short Block
- Assembled by Howard at RLZ
- K24A4 Block and Crank
- AEBS Sleeves
- IPS K24 Cunningham Rods
- RLZ Spec Wiseco Pistons (14.5:1 c/r & 89.5mm bore)
- ACL Race Bearings
- No accessories included
- All parts are brand new, zero miles (the block came out of a wrecked accord with less than 10k)
- I will not part out or disassemble, sorry
- Block at RLZ shop in NC. You can pickup in NC, get it shipped, or pickup in NJ
$3500 + Shipping
2003 K20A2 Shortblock
- Decent condition, I used this block with a K20A3 head to move the car around.
- Has some damage to one of the trans mounting holes, however everything still bolts up good.
- Good for a quick stock rebuild (Hone and Re-Ring)
- I will not part out or disassemble, sorry.
$450 + Shipping
Pictures to Follow
K-Series Quaife ATB
-Brand new, Installed into a transmission, however NO MILES
-Includes BRAND NEW OEM bearings and speedo gear
$800 Shipped
K20A Transmission Outer Cases
-Great Condition, One is from K20A2 and the other is a K20A3, both the same thing
$150 Shipped Each (1 Still Left)
Painless Master Disconnect
-Great Condition, like new
-Includes NHRA Approved shut off switch, and power wiring from the battery (located in front fender) to fuse box in stock location.
-Removes the need to run heavy gauge wiring from the front to back of car
-Everything is labeled and wiring has high quality crimp connections
$150 Shipped
Old Jan 5, 2011 | 06:06 AM
  #55
TDautowerkes's Avatar
New Kpro with ECU installed $1200 obo
New K20 sidewinder for EG EK Integra $850
K24 K1 Rods freshly reconditioned $250
K24 Manley rods reconditioned by Manley $550
Freshly rebuilt CC twindisc for K series $900.00 obo
Exospeed 13x8 wheels 4x100 polished $650 shipped
K20 log manifold not the prettiest but works well $150.00
Ported k20a2 head with supertech valvetrain and fresh valve job. ready to install $1000
M&W indivicdual coils and M&W harness for pro 14/prodrag 4 $500
USED CC twin disc $850
NEW AEM thermocoupler amplifier for individual EGT's $220.00
pics are available to interested buyers.
786-293-8876
Damian
willing to trade for: Racepak IQ3 dash/Wilwood drag brake kit for hondas.
Old Jan 5, 2011 | 08:33 AM
  #56
f@sth@tch89's Avatar
1) YS1 cable tranny w/ new throw out bearing ($250 OBO)
2) 88-95 Blox Drag Suspension, installed on a car that never moved($700 OBO)-bought 2 months ago...still have reciept.
3) FULL RACE TRACTION BAR 88-91 CRX/Civic(NEW STILL IN BOX)-I will sell for the cost including shipping. You benefit with no tax and a few dollars off.
4) SKUNK2 Tuner GSR manifold ($200)
5) PR3 ECU(Reprogrammed by Erick's Racing)-$100
6) B16 Axles($75.00)
7) Autometer Volt Guage($45)
8) Autometer Oil Pressure($25)
9) Autometer Fuel Pressure($25)
Please text/call 424.230.6503 or email @ jdm894g@aol.com
Old Jan 5, 2011 | 09:09 AM
  #57
vtec_killer_'s Avatar
Afi turbo manifold B-series 550 shipped
Old Jan 5, 2011 | 03:00 PM
  #58
redboost10's Avatar
s372 with race cover, 1.25 exhaust housing, has about 20 passes and 8 dyno pulls on it, also has vband on compressor and is tapped for vacuum source. bought from t1.
make offer
Old Jan 5, 2011 | 03:33 PM
  #59
GRTTURBO's Avatar
SK2..TUNER 2..400
Old Jan 5, 2011 | 03:39 PM
  #60
h22 civic's Avatar
aem twin fire $190
aem long coils $200
silver pro comp 2.1/16 water temp gauge 100-250 temp=30 bux
silver pro comp 2 1/16 0-100 oil psi gauge 40 bux
aem wide band gauge with new sensor 175 bux
silver sport comp monster tach 10,000 with adjustable rpm setting and external shift light=175 bux
phantom 2 1/16 0-100 psi mechanical fuel gauge 30 bux
phantom 2 1/16 30psi boost gauge 40 bux
96-00 civic 2 gauge cluster bezel 30 bux
autometer low oil psi pencil warning light with 15 psi sensor=40 bux
2 gauge pillar mount for 2 1/16 gauges fits 96- civic/integra =25 bux
00 civic si cluster 175 bux
aem twin fire and aem pencil coils make offer
aem 30-1020 ems for obd2 already setup for coil on plug with a few h22 turbo programs in it $600
ferrea roller rocker setup for h22 with h22 all motor roller cams mint like new $1500 or just sell cams seperate( pm for cam card)
2-24.5x8.5x15 m&h slicks lots of meat left work good 200 bux
2- 15"x7" rota sub zeros flat black look new 5x114.3 very light weels 200bux
2- 205 50 15 mickey thompson et drag radials basically brand new used for 1 day of photo shooting (not 1 burn out on them) sold
5x114.3 bogarts slicks and skinnys plenty meat left sell all for $1000
full msd setup will sell cheap blaster2 coil 6al msd wires etc
fullrace_t3 t67ho turbo 82 back/70 front housing p trim wheel no probs at all make offer___
zex dry nitrous kit mint 250 bux
misc stock h22 stuff pm with needs_________
__________________
__________________
__________________
Old Jan 5, 2011 | 06:46 PM
  #61
SwappedTURBOegg's Avatar
i have a set of modded high independence bosch fuel injectors 600cc's flowed at kinsler fuel injection.
120 shipped
AEM 1010box hall effect modded 99-2000 civic box
470 shipped
***** cheap cause im desperate for some cash send me a pm
Old Jan 5, 2011 | 10:31 PM
  #62
ahobbs's Avatar
HELLO,GOOD MORNIN'
Selling a few things just because Im doing some changes in 2011 season
GE GSR manifold Fuel Rail and Manifold 450.00 New
shift-i ecliptech progressive shift light-150.00 shipped
T1 cam trigger bracket/ with sensor 165.00
plug for CBR coils on plug with a deutsch plug-50.00
precision 750hp IC. with reg endtanks 400.00 easily mounts to the stock radiator core support. In great condition
pm me if interested
Old Jan 6, 2011 | 09:49 AM
  #63
Spoolin18's Avatar
Just as the title states, I have quite a few parts for sale. The M&W Pro 10 kit is practically BRAND NEW, with 5 dyno pulls and 20 minutes of use. All of the prices include shipping, the only reason they are for sale is due to a new setup on it's way for the 2011 season.
**Everything will be shipped via UPS with a tracking number**
1) T1 M&W Pro 10 kit - $800.00 shipped
Includes - M&W Pro 10, T1 custom harness, and Crane PS92 coil.
*Everything has been used for only 5 dyno pulls, and 20 minutes of use*
2) Hondata S300 in a P28 w/ PWM Boost by Gear - $525.00 shipped
Used for a total of 6 months, in great condition. The P28 ECU cover is powder coated Silver vein! Looks sick!!
3) MSD Digital 6 Plus - $135.00 shipped
In great condition!
4) MSD Blaster SS coil - $25.00 shipped
Please feel free to either PM me or email me at DubbinD@homail.com for any questions and/or concerns. Everything is ready to ship.
Old Jan 6, 2011 | 02:59 PM
  #64
Civic89stdB16's Avatar
FS:
Set of 4 used for 500 miles ford racing (Bosch) 1600cc injectors- best offer
Pair of 13x7 american racing wheels with m/t 22x8x13 slicks with 7 passes on them-400 obo
Used EF civic Hasport billet mounts with black bushings for cable b-series in a EF-200 obo
BNIB Hasport EF Shift Linkage-100 Firm
Used B16 Eagle Rods-210 obo
BNIB PCT 82mm Pistons with rings and pins-140 obo
Set of B series arp small rod bolts- best offer
Schwitzer s200g turbo almost new t3 flanged-(bought it but never used it)400 obo
D16 cast t3 turbo manifold-65 obo
Pm or text me at 302-250-5532. thanks
Old Jan 6, 2011 | 03:31 PM
  #65
TopEndUSA's Avatar
SOLD
Old Jan 6, 2011 | 06:52 PM
  #66
90blackcrx's Avatar
FS: Innovative billet h22 mounts for an eg chassis, great condtion, will trade for b series solid mounts.
Old Jan 7, 2011 | 04:25 PM
  #67
turbociv910's Avatar
fic 2200 blue top injectors(no driver)-300 FIC sent me these to test for them, serial number 1-4.
low miles, ran e100 variant, to big for my setup, switched to 1600s
msd dis2- 250
bosch 2 channel ignitor- 50(m4 compatable running wasted spark)
bosch 4 channel ignitor-100(m4,6,800 compatable running sequential)
everythings used but in working condition
Old Jan 7, 2011 | 11:44 PM
  #68
chrisdiz's Avatar
going bigger so its for sale. purchased new @ campout 04-05 interstate 20'x8.5' racecar trailer. diamond plate ALL around, polished front post, polished wheels, flat-top no ugly rounded style.. $4900 obo call or text 702-266-5679
Old Jan 7, 2011 | 11:50 PM
  #69
damndan23's Avatar
Default FS/FT )))WELD MAGNUM((( RS*R EXHAUST . OBX DIFF . PISTON & ROD COMBO trades welcome
WELD MAGNUM IMPORT RACING WHEELS freshly polished 13X8/4X100 with M&H 24.5" slicks mounted and screwed with tubes. $700+ Shipping & PP...
Broken OBX lsd for GSR/Bseries. center splined gear is seized inside diff.all other gears come out. i can supply pix if interested. OR... if any of you have a similar diff that is broken lmk if you wanna let it go so i can fix this one..i bought and installed this diff to have it fail in less than 1000miles along with a broken case $100.00 shipped?? looks new comes complete
FULL RS*R X-mag GT2 2.5" Catback exhaust for EG straight back up and out, like drift style exhaust. has hollowed high flo race cat on it. It will probably fit any other honda/Acura with little to no effort. $200.00 picked up/or contact me for shipping arrangements
MSD master boost/timing box with remote mount controller $80.00
P72 piston and rod combo. Standard bore/stroke pulled from a 38K motor
standard size CP wristpins. from 9.1 Bseries pistons $35.00 OBO
Welded gsr open diff/spool. $50.00 OBO
I will consider trades for the following items..
12-15FT of -8 Black braided fuel line
5FT of -10 black braided hose
Black -10 straight fittings for VC to catchcan
24X12X3 FMIC core
dual backdoor FMIC
X2 38mm wastegates
X2 44mm wastegates
BW S361/S362/S366...T67..PT62-62. im leaving my options open to whatever you may have..has to be T4 twinscroll W/Vband
ITR DIFF..
3PC FRONT for EG
im open to many different options so show me what you have.
For more pictures or information contact me, Dan@(570)490-8908 .... E-mail is Deiselnutz22@hotmail.com
Old Jan 8, 2011 | 05:15 AM
  #70
k24coupe's Avatar
GARRY ENG....YOU BEEN PM'ED
Old Jan 8, 2011 | 07:38 AM
  #71
90blackcrx's Avatar
FS: h22 drive shaft shop axles for eg chassis, stage 0. Used but in great condtion
Old Jan 8, 2011 | 04:37 PM
  #72
nickyturbo's Avatar
Peakboost HVS topmount Downpipe 3"v-band flanged
$300 shipped via paypal
email nicky.turbo@hotmail.com for pics or questions
Old Jan 8, 2011 | 05:44 PM
  #73
Mugencrxsir1's Avatar
2 - B series oil pans. From b18a... $15 each
Crx Energy Suspension kit left overs - Transmission mounts, Lower control arm shock mounts, and Rear Control Arm Pivot Bushings = $40
12" SPAL Radiator Fan - $50 (Retails for $197)
88-91 Civic/CRX Spoon Sports Lower Brace. BNIB (Missing Brackets) $70 ($220 new)
OEM Map Sensor = $25
STR cam cap (Red) B16 = $10 obo
OEM B16 Valve Springs = $60 ($120 new)
Golden Eagle Dowl Pins B16 w/ tapping tool = $5
62mm integra throttle body (b18a,b) = $15
Turbonetics Racegate Wastegate Springs/Flange (3-5lbs, 5-7lbs, 7-9lbs) $5
Summit Racing Black Face Digital Oil Pressure Gauge w/ Sending unit BNIB = $30 ($50 Retail total)
b16 Thermostat housing and thermostat = $15
Synapse BOV Stainless Steel Flange = $5
Jeg's T-Bolt's 2-2.5" and 1- 1.75" = $3 each
88-89 Crx Gauge Cluster, missing fuel needle. Works Perfectly w/ Auto Glo Face installed = $15
88-91 Crx rear storage corner boxes = $15 each
If you have any more questions or need pics please email me...
Old Jan 8, 2011 | 07:59 PM
  #74
SPOOLINmatt's Avatar
Vibrant 3" VanJen Connection System
Brand new, bought the wrong size.
$70 + Shipping
ARP Head Studs
GSR B18C1....Also works with LS VTEC setups
Torqued a few times, just upgraded to stronger studs for the hell of it...these still hold just fine.
65$ shipped.
GReddy Oil Sandwich Adapter
USED, Comes with orings, -6 fitting, Honda oil filter center fitting. Great for an LSVTEC or TURBO setup for feed line or Both.
$40 Shipped
Old Jan 8, 2011 | 10:08 PM
  #75
jdmintegraxsi's Avatar
AEM EMS 30-1070U
Designed for K-swapped cars. This unit was plugged in for start up but was never ran in the car. Wideband was never used. Everything is still in the box ready to be shipped out.
$1000 Shipped
Next is almost everything to put together an all motor B-series shortblock. I will sell it all for $2200
Golden Eagle Sleeved B18a1 Block. Bored and honed to 86.5mm $1000
Brand New Custom CP 86.5mm 12.5:1 B series pistons. They have been prepped so all the sharp edges are removed $650
Crower Maxi-lite rods, LS rod length. Used but less than 100 miles on them $500
B-Series ATI damper. SOLD
LS Crank. $100
Moroso Steel B-Series Oil Pan 5.5qt. It is tapped and plugged for turbo drain line and oil temp sensors. $300
