ITR drivers...
Old Jun 26, 2003 | 11:13 AM
JiggyKooAndy's Avatar
Default ITR drivers...
what do u launch at, and are u just dropping the clutch? Please give a little advice to me, considering i went to the track last night and the best 60 ft time i could pull was 2.38.
Old Jun 26, 2003 | 11:42 AM
36Chambers's Avatar
Default Re: ITR drivers... (JiggyKooAndy)
I launch about 5500 to 6000 with sliping it out.. it got me constant 2.0'. dropping it real hard just seems to cause major whell spin for me.
try to let it out easily
Old Jun 26, 2003 | 10:43 PM
SoCal ITR's Avatar
Default Re: ITR drivers... (TypeR690)
I launch between 7k and 7500, and slip the clutch.
I can get 2.1's no problem, probably better if I practiced more.
Old Jun 27, 2003 | 01:41 AM
Default Re: ITR drivers... (SoCal ITR)
when u say slip, you mean letting it out in one smooth motion right?
Old Jun 29, 2003 | 08:24 PM
Lost Type R's Avatar
i use to launch at around 5500-7000 rpms when I was NA. Slide the clutch a lil and drop. Dont jus drop it or youll spin like crazy. What I mean by just slide is slowly disengage until your car starts moving then drop.
Old Jun 29, 2003 | 11:33 PM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JiggyKooAndy &raquo;</TD></TR><TR><TD CLASS="quote">when u say slip, you mean letting it out in one smooth motion right?</TD></TR></TABLE>
Yes, but slowly..... and ride it a little bit so you don't bog down and out of the power band.
Old Jun 30, 2003 | 10:54 AM
before you actually start slipping the clutch...do u hold the rpms at 7k, or do u let them go up and start slipping as they get closer to 7k?
Old Jun 30, 2003 | 10:20 PM
SoCal ITR's Avatar
I hold it at 7, then when the last yellow light show's up, I start to slip the clutch hard and floor it.
It's like starting up a hill, but letting all hell loose.
Old Jul 1, 2003 | 06:27 AM
how much wheel spin do u get? any wheel hop??
Old Jul 1, 2003 | 08:44 AM
SoCal ITR's Avatar
I spin until it grips at 6-7000 rpm. Very little wheelhop because I drop the pressure in the front tires to around 17 psi.
Old Jul 1, 2003 | 09:03 AM
sounds good, thanks
Yosshaa
Honda S2000
Sep 18, 2006 05:22 AM
Mr.Motion
Honda S2000
Apr 2, 2006 10:16 PM
gbinteg
Dec 28, 2004 08:07 PM
G2ILS
Sep 26, 2004 01:52 PM
bOOsTiNSoHcVtEc
Jun 19, 2003 10:25 PM
