Ignition issues
Old Oct 23, 2010 | 08:25 AM
  #26
alopez84's Avatar
Default Re: Ignition issues
Originally Posted by tony1
Yeah, with the S300 your best bet is the Pro 10 kit. A good quality CDI box and it allows you to bypass the igniter completely.
Yeah i've had great luck with my M&W Pro 10! I used to change the plugs almost every time i went to the track, now with this Kit I forget when i changed the plugs last... lol
Old Oct 23, 2010 | 10:12 AM
  #27
2k.civic.si's Avatar
Originally Posted by DRAGLS
Bosch makes a ignitor we honda guys can use. Just mount it with the ecu.
Nology sells it. $86
http://www.nology.com/module.html
Ouch...the one I am having designed will be sold for $25-$30 out the door.
Old Oct 23, 2010 | 11:32 AM
  #28
92redhatch's Avatar
Nice^
Old Oct 23, 2010 | 12:09 PM
  #29
Garage 808 Hatch's Avatar
Even with the digital 6 setup in my car, i've changed the plugs 2 times this year. after the dyno, and at the BOTI event when it started overheating the ignitor just incase the plugs were bad, but they were fine
Old Oct 23, 2010 | 02:59 PM
  #30
DRAGLS's Avatar
Beats buying a oem one.
Old Oct 23, 2010 | 04:43 PM
  #31
a1320honda's Avatar
Would this help with goin through coils? Ive tried a brand new Blaster SS coil with an oem honda cap and had ignition issues. Never had to change the ignitor but i go through 2-3 coils a year. Just started picking up a slight miss, gets worse until i change the coil and all is well again.
Old Oct 24, 2010 | 09:41 AM
  #32
ralph11sec's Avatar
used s300 + t1 kit combo (pro 10 and crane coil). barely 900whp with no ign issues using ngk copper tip .0016" on gasoline.
Old Oct 24, 2010 | 06:31 PM
  #33
that is an expensive way to fix a cheap problem. most people on here are not going to spend that kind of money...especially when for about $30 bucks i can give them something bullet proof that will fix the ignitor issue permanetly.
Old Oct 24, 2010 | 06:32 PM
  #34
thats the idea...i dont plan on making a bunch of money off these...this is just a hobby...i have a day job
Old Oct 24, 2010 | 06:38 PM
  #35
Its also a quality way to fix the issue. some people are also trying to enhance spark energy. Initially I made this to find a cheap fix, but realized, over the last 3 years i've wanted to try the M&W system, now I have a reason to do so.
Old Oct 24, 2010 | 06:45 PM
  #36
this isnt a cheap fix like that garbage j&s circut floating around is (that circut dumps current back into the ecu...a big no no)....i took an ecu and distributor to an electrical engineer to come up with a proper fix.
Old Oct 24, 2010 | 06:50 PM
  #37
tony1's Avatar
When you have a bulletproof $30 system on the market that's proven itself then you can talk about how much better it is than other stuff on the market. Until then...
Old Oct 24, 2010 | 06:53 PM
  #38
dont worry about that...i got just the car put it on after the replacement part has been ran on the simulator for testing....the final schematic will be in my hands tommorow
the person designing it is the head electrical engineer of fisher research labs and has been for the last 30+ years....just so happens to be my uncle
Old Oct 24, 2010 | 07:08 PM
  #39
I designed a time travel machine from poop. I know it'll work because i'm a plumber. Please quit advertising in my thread
Old Oct 24, 2010 | 08:03 PM
  #40
ralph11sec's Avatar
^ haha
just create a thread with the 30$ equipment and let everyone see your test results. its just that i'd think twice to trust a 30$ replacement for ign setup to handle a $20t motor
garage, how much power ru putting on?
Old Oct 24, 2010 | 08:06 PM
  #41
a1320honda's Avatar
LOL
Old Oct 24, 2010 | 08:10 PM
  #42
grow up poop boy =P lol
Old Oct 24, 2010 | 08:16 PM
  #43
^ haha
Currently I'm only at 850 limited by my fuel pump.
Old Oct 24, 2010 | 10:52 PM
  #44
ralph11sec's Avatar
we probably have the same issue as i had before. approaching mid 800s, s372, 30-33psi, random misfires, changed plugs, etc, changed distributors all the time, but nothing seemed to work permanently.
got the t1 kit. just splice 1 wire in the harness, and all are bolt on. redynoed, made high 800s with no misfires on about 20 passes on the dyno.
our fuel setup was dual walbro, id2000s, aeromotive reg, base pres = 80psi.
Old Oct 25, 2010 | 07:39 AM
  #45
twkdCD595's Avatar
This is making me drool over the thought of a Pro10 and coil from T1. I better put that on the list for winter plans and start saving quarters, not effin with plugs all the time or having misfires after getting some run time on them would be nice.
Old Oct 25, 2010 | 09:24 AM
  #46
Funny thing is I never noticed it on the dyno feel wise, but the graph was a bit choppy up top. At the track, it was very bad. Anyways, just ordered my pro10 kit from Tony and my Weldon 2035. Next season's gonna be fun
Old Oct 25, 2010 | 10:19 AM
  #47
xenocron's Avatar
I currently have an electrical engineer designing a replacement for the oem icm which will be bullet proof and stable past 12k rpm(not that its needed but we designed it around the idea of needing to be able to turn on and off over 800 times a second). The mosfets being used are able to withstand 5 times the amount of current that the icm can before heating up(the parts are also able to withstand a lot higher temperature). Once the design is done and tested this will be a much cheaper alternative then spending big $ on other setups just to get around the ignitor issues.
Will yours output a tacho signal to the factory tach without the use of an extra ignition box?
This is the ONLY reason I havent massed produced one either...I can see race cars using this, but not street cars...so the volume wasnt there for me to pursue it further.
Originally Posted by CMB-TUNING
I'm currently selling the ignitor bypass boxes, like the one we use in our own car. PM if you're interested. We used to have the same problems. With the bypass box no more issues.
It has been already tested and works.
P.S: It bypasses the ignitor completely so u can remove it from the distributor and throw it in the garbage...lol.
Is yours the one originally Designed on PGMFI.org? What do you do about the lack of output to drive the factory Tacho?
I made one as well, with help from Randy Schoener (RS-Tech) and Moates...I have it in a few cars with success but didnt think a majority of people out there would need something like this.
My justification was if you have none of the parts, you are going to buy an M&W PRO 10 with the Crane Coil...its just the bulletproof way to go.
If you go the way of the stock Dizzy, you need a Digital MSD Box and you still need the Coil (Crane or HVC Blue) so if you have to spend all that money, and the Ignitor relocator for $30-50 you should have just gone with the M&W from the start...
BUT if you have all of that, and you have ignitor issues already like Garage 808 here...then this ignitor box is perfect for that.
Rob Mapps has been running this for 2 years plus now...he used to blow ignitors all the time but when we switched to this last year and interesting thing happened as well, we didnt have to gap the plugs down as much as we used to need to, so somehow relocating the ICM allowed for a more powerful spark as well...which was a good thing
Old Oct 25, 2010 | 10:41 AM
  #48
em_at_kfi's Avatar
Whenever I see "2035" - I just have to be sure you're aware: those pumps are 5 min on - 30 min off. Intermittent duty only. As long as you're cool with that
Old Oct 25, 2010 | 10:52 AM
  #49
Ya, Tony made sure to tell me. Its all good, its going on a full race car.
Old Oct 25, 2010 | 12:26 PM
  #50
0554's Avatar
also be aware they are annoying lol.
