I need Lunching tips!! please!!
Old Nov 30, 2008 | 08:07 PM
bsampson's Avatar
Default I need Lunching tips!! please!!
Hey guys i want to drag race in the near future with my integra. Keep in mind that it is pretty stock except for a few bolt ons. Stock tires. Stock suspension and i basically need a tutorial of how to launch a street legal car. What rpm's..to launch at and what to do with the clutch. How to shift and everything. Keep in mind i dont want to completly tear up the car (I know launching does hurt the car a bit) But i want to try to keep everything as good as shape as possible.
THanks!!! any help is appreciated!!!
Old Nov 30, 2008 | 08:24 PM
streetracer6rpt's Avatar
bring a pizza and a 6pack.
Old Nov 30, 2008 | 08:37 PM
njn63's Avatar
I came in here to do that.
As far as launching, drop your tire pressure some and preload the car (have the clutch partially released while holding the car in place with the e-brake). RPM's vary by car and setup, just try different things and watch your 60' times to see if the change made it better or worse.
Old Nov 30, 2008 | 08:44 PM
SOHCinWA's Avatar
Mac Donalds..
Old Nov 30, 2008 | 09:03 PM
Garage 808 Hatch's Avatar
i dont remember seeing much to lunch on in Coquille. kinda small town
Old Nov 30, 2008 | 10:02 PM
bsampson's Avatar
cmon guys i really do need some help...not this random stuff...and hey i HATE the cresswell bulldogs lol im playin i palyed ball against them a few times in high school....kinda weird finding someone so close on here
Old Dec 1, 2008 | 08:36 AM
here... type lauching under drag racing
https://honda-tech.com/search.php?do=process
Old Dec 1, 2008 | 11:06 PM
bsampson's Avatar
i did..and theres like to tuorials
Old Dec 2, 2008 | 02:57 PM
Silva Bullit DC4's Avatar
No tutorial is gonna help you more than experience. Go to the track, talk to a couple of gurus there, and practice, practice, practice.
Old Dec 2, 2008 | 04:42 PM
InDub's Avatar
Do it like these guys, "launch the car, launch the car" lol
http://www.youtube.com/watch?v=FMSH_ng9BZ4
Old Dec 2, 2008 | 04:54 PM
miller's Avatar
^ i can never get tired of that video
Old Dec 2, 2008 | 05:32 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
depending on tires.... I would start your tire pressures around 22psi, and try anything as low as 18psi. I did really well in that range, if you can log all the info about the weather, and temps and tire pressures and log your 60fts, it will take the guess work out of setting the car up. I never preloaded the clutch with the ebrake like mentioned, I always held the revs to about 4500 or as high as 5500 and slipped the clutch out... sometimes it spun to much and sometimes it hooked and took off. I used to get 2.1 60s on stock suspension and stock tires.... so just keep trying different things.... just log your passes.... write down all your shift points and everything. If you haven't cammed your GSR I can tell you that taking your car all the way to redline probably will hurt your times.... GSR cams sign off up top, you might end up shifting earlier than the 8K redline. once again these are all things you are gonna have to try and learn.... there is definitely a learning curve drag racing.... you will find out you get better and better each time you get out there.
Old Dec 2, 2008 | 06:06 PM
boostedcivicsir's Avatar
Mr. Badwrench
good gawd.
i am guessing you have a stock or organic clutch so preloading is out of the question.
rev between 3 and 6k and slip the clutch out.
or search preloading. and see what you come up with.
Old Dec 2, 2008 | 07:48 PM
bsampson's Avatar
c
thanks for your info man...but this is where i run into question...when you see green do you floor it hard WHILE slipping the clutch? do you floor it after you release the clutch? or do you eas the gas? thats where my problem is. how long do you have the clutch in at the line like while hammering the gas? im confused about that process
Old Dec 2, 2008 | 09:56 PM
If your in competition, your gonna wanna leave on the third yellow light, because by the time your eyes translate that third yellow beam to your body to tell it to launch the car and your car acting upon your inputs... it will already be green and you will cut good lights. I hold the gas down till I get to the rpm I wanna launch from and I begin to ease the clutch so I can just feel it grab but not move me... then when the beams drop I let the clutch out and as it begins to move I punch the throttle and let the clutch completely out.... there is some wheelspin but not much.
Old Dec 2, 2008 | 10:24 PM
IT'S ME DAVID's Avatar
NooB
launch at 3500-4k rpm lower pressure to 25 psi wont make a difference and wait for ur 16s time slip
Old Dec 2, 2008 | 10:29 PM
91whiteZCrex's Avatar
haha, Yeah he said that the car was almost stock... so it should be pretty easy to launch it... definatly dont preload your stock clutch
Old Dec 3, 2008 | 10:29 AM
bsampson's Avatar
what do you mean by preloading?
Old Dec 3, 2008 | 11:37 AM
Honda Bull's Avatar
VVV This was the 2nd reply, please read what people take the time to write for you.
But you won't have to preload your car much at all. Just let the clutch out (do not read: dump the clutch) from like 5000 rpm +/- 1000 rpm.
slickshifter
Aug 20, 2005 03:59 PM
95accordh22a
Jun 24, 2005 10:15 AM
strict 9 ef
Feb 19, 2004 04:36 PM
el arbi
Apr 4, 2003 12:48 PM
