Launching and shift points
Old Aug 20, 2005 | 10:31 AM
slickshifter's Avatar
Default Launching and shift points
I've got a 98' civic EX 5 speed. It's stock besides a Skunk2 cat-back exhaust. I haven't taken it to the track yet but I was wondering at what rpm to launch it and if I should slip the clutch, I dont really want to dump it. Also should I shift at redline. thanks guys, this is my first car so don't burn me too hard.
Old Aug 20, 2005 | 11:04 AM
tommy1's Avatar
Default Re: Launching and shift points (slickshifter)
When I had my GSR turbocharged @ 9psi, I would just dump the clutch. Now I have it tuned to 17psi and a Clutchmasters stage 4 clutch so I have to slip the clutch so I don't break my stock axles. Launching in your car would have to be where you feel the tires spin enough. When I started out I launched it at 5K and actually had to go higher cause my drag radials would grip too much. With my car now I launch it at around 6000 or so and slip the clutch and I usually can get pretty close to a 1.9 60 foot which is what I'm aiming for. As a suggestion, I would launch your car at 4500 and go up from there as needed and just dump the clutch since you have all stock components.
Old Aug 20, 2005 | 12:09 PM
Default Re: Launching and shift points (tommy1)
Thanks for the suggestions. However, you dont think dumping the clutch will damage my transmission?
Old Aug 20, 2005 | 12:38 PM
LDS's Avatar
LDS
I ran my stock 02 civic ex 5 spd and laun ched a 6500 slipped the hell out of the clutch and and shifted as close to revlimiter as possible and ran 16.1 @ 85
Old Aug 20, 2005 | 03:59 PM
Default Re: (LDS)
I bet your clutch wasn't smellin to good. Thanks for the post. I probably won't do that because I can't afford to fix stuff, but thanks again for your suggestions.
xlur8ed
May 24, 2006 05:42 PM
13DevilsCamry
Apr 8, 2005 07:53 AM
civboy115
17
Mar 12, 2004 09:26 PM
CheeseKT
Jan 12, 2004 01:38 PM
1hotintegra
Aug 6, 2002 08:51 AM
