how to remove the meter in a vtec?
Old Apr 18, 2004 | 04:47 AM
jfk
Guest
Posts: n/a
Default how to remove the meter in a vtec?
is possible?
Modified by jfk at 6:17 AM 4/18/2004
Old Apr 18, 2004 | 07:05 AM
GSRswapandslow.
Guest
Posts: n/a
huh?
Old Apr 18, 2004 | 07:21 AM
jfk
Guest
Posts: n/a
Default Re: (Ej6andslow)
change or delete the original meter for a autometer
ORIGINAL
AUTOMETER,but have a problem for vtec signal on original meter
Old Apr 18, 2004 | 07:45 AM
GSRswapandslow.
Guest
Posts: n/a
v-tech doesn't really affect the gauges in anyway, so I don't see a problem in you running all autometers
you will need to wire up some lights, signals, a CEL, and figure out a way to get the fuel level gauge to work with the OE honda sender...or figure a way to replace the OE sender with one that puts out the correct ohms
Old Apr 18, 2004 | 12:53 PM
Trooper's Avatar
You will need to get a RPM activated switch from auto meter, and have that activate V-TEC. The stock computer needs to know the car is above 14 mph i belive to turn on V-TEC.
Old Apr 20, 2004 | 12:03 AM
jfk
Guest
Posts: n/a
Default Re: (Trooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trooper &raquo;</TD></TR><TR><TD CLASS="quote">You will need to get a RPM activated switch from auto meter, and have that activate V-TEC. The stock computer needs to know the car is above 14 mph i belive to turn on V-TEC. </TD></TR></TABLE>
a ok thanks,you have the pics or the links of this auto meter
thanks
john
Old Apr 20, 2004 | 05:26 AM
91civicDXdude's Avatar
you could always read the resistance or voltage of the VSS when it is reading 14+mph and then create a circuit which simulates this, so the ECU thinks its always 16mph and will still activate VTEC
Old Apr 20, 2004 | 08:54 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6andslow &raquo;</TD></TR><TR><TD CLASS="quote">v-tech</TD></TR></TABLE>
wow!
Old Apr 21, 2004 | 02:07 AM
jfk
Guest
Posts: n/a
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">you could always read the resistance or voltage of the VSS when it is reading 14+mph and then create a circuit which simulates this, so the ECU thinks its always 16mph and will still activate VTEC</TD></TR></TABLE>
ok thanks,i'm look
Old Apr 21, 2004 | 04:14 AM
EE_Chris's Avatar
The VSS is a pulsed input....simply applying a voltage of some sort won't cut it.
Old Apr 21, 2004 | 04:41 AM
so..... make a pulsing circuit..
Old Apr 21, 2004 | 08:52 AM
B18C4-T's Avatar
You can also talk to Michael Ecker at Ecker Honda in Kaiserslautern GE. He changed out everything also and got it all to work, we even had a fuel guage. He speaks and reads english if you don't speak German. IM me if you need contact info. Larry
jasrams
Honda Civic (2001 - 2005)
Mar 10, 2011 04:18 PM
breanna*
12
Aug 2, 2006 09:29 AM
DsBananas94LS
Dec 5, 2004 07:51 PM
veilsides2000
Oct 18, 2004 07:38 AM
E-lude78
26
Jan 20, 2004 06:52 AM
