how much ignition for methanol?
Old Mar 30, 2007 | 11:15 PM
ivt-t's Avatar
Default how much ignition for methanol?
just want to know how much more ignition can a give for my setup when is use methanol injection?
b16 stock bore and stroke precison turbo,25psi boost
Old Mar 31, 2007 | 01:59 AM
SlowReaction's Avatar
Default Re: how much ignition for methanol? (ivt-t)
Take it to your tuner? Are you planning to just install the kit and adjusting your timing based on what someone on this forum tells you to set it at?
Old Apr 1, 2007 | 04:58 AM
ivt-t's Avatar
Default Re: how much ignition for methanol? (SlowReaction)
i tune myself my car.
just was a question how much ignition can take methanol...
Old Apr 1, 2007 | 06:23 AM
JDogg's Avatar
usually ign timing dont have to change alot depending on which type of gas you were using, the biggest difference is in the ammount of fuel
Old Apr 2, 2007 | 07:22 AM
ralph11sec's Avatar
Default Re: how much ignition for methanol? (JDogg)
whats your compression ratio.
just the same with that of a race gas. afr goes as rich as 9s or 10s
Old Apr 3, 2007 | 05:03 PM
cartunescivic's Avatar
Default Re: how much ignition for methanol? (ralph12sec)
are you using meth as the primary fuel? or added in the intake tract, like a Snow Performance kit, for intake charge cooling? this is what i am doing:
snow stage 1 kit with aquamist HSV, controlled off of the haltech SEM output for V-tec. the nozzle is right after the FMIC, 50/50 water and methanol injected for cooler/denser intake charge. will enable me to run more timing with less detonation, thereby equaling higher output with a cooler charge. more boost, so i could run a race gas map on pump gas essentially. previously 302whp on pump gas @ 18psi..... not dyno'ed yet for the meth changes....
good luck
Old Apr 4, 2007 | 06:04 AM
JDogg's Avatar
Default Re: how much ignition for methanol? (cartunescivic)
i didnt read carefully.. you said methanol injection..
that **** sucks, just put race gas in it... one more thing to go wrong and kill your motor
Old Apr 4, 2007 | 06:17 AM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">i didnt read carefully.. you said methanol injection..
that **** sucks, just put race gas in it... one more thing to go wrong and kill your motor</TD></TR></TABLE>
I agree completely!
Old Apr 4, 2007 | 06:35 AM
4piston's Avatar
Default Re: how much ignition for methanol? (tony1)
I have the same opinion on that stuff. A lot of guys are running meth inj around here with a lot of success, but I always question it...why not just run race gas?
Old Apr 4, 2007 | 06:39 AM
tony1's Avatar
Default Re: how much ignition for methanol? (4piston)
I guess i don't have much faith in the systems. If anything in the meth injection system fails, the motor is toast if it's tuned for meth injection. Not worth the risk in my opinion. Setup the motor properly for pump gas and run it at that. If you want more, put race gas in it.
Old Apr 4, 2007 | 06:46 AM
4piston's Avatar
What octane level do you achieve running pump and then injecting say...25% meth?
One of the RX7 guys here has a real nice setup he made at home that only sees high boost if it sees meth. I have been with him when his meth quits working or runs out, and it will not go over his pump boost level.
Old Apr 5, 2007 | 05:06 AM
they make such things to safeguard against that situation, running out of meth/water mixture..... i am running the snow performance safeinjection with mine as well. if the SI reads a blockage, be it no more fluid, clogged nozzle, anything, it will dump boost via solenoid. you can have it totally safe for whatever purpose you need.
good luck.
94ta_lt1
Dec 25, 2004 03:45 PM
Importracer_001
Dec 12, 2004 08:36 PM
Chiovnidca
Mar 16, 2003 04:16 AM
spookhatch24
Jan 1, 2003 08:41 AM
ProjectSol
Sep 9, 2002 04:46 PM
