How Much Boost???
Old Dec 1, 2010 | 07:39 AM
Turbo Ric's Avatar
Icon6 How Much Boost???
I know there isnt a big secret in the fact that it take lots of boost to get there and that the days of low boost being 20 psi is dead and gone. But the big Question on my mind and I am sure others, is.
How much Boost are you guys actually running to make it into your 8 second Personal best, and on what turbo? Just those 2 questions please....
Old Dec 1, 2010 | 08:50 AM
92redhatch's Avatar
Default Re: How Much Boost???
The 8 sec guys are on gt4272r's and 50psi from what I've read. For the most part or close to it.
Old Dec 1, 2010 | 09:13 AM
Garage 808 Hatch's Avatar
I know a few guys running 50+ psi on 72mm billet turbos. hotrod guys are in the high 8's on under 40psi because of weight
Old Dec 1, 2010 | 09:40 AM
hello1320's Avatar
I've heard of guys making 900 HP range under 40 psi. That should get you very close to an 8sec pass.
Old Dec 1, 2010 | 09:51 AM
miller's Avatar
Mid 50's...My best runs have been with 53/54lbs at most while crossing the traps at right around 50.
To answer your question after rereading your initial post. I was able to go 8.9 on 36 lbs. I am pretty sure the way the car is dialed in now I can go a little quicker with that boost level. So it doesnt take all the much boost to go 8's per say but to get deeper in the 8's I have had to turn it up a considerable amount obviously.
Old Dec 1, 2010 | 10:36 AM
tony1's Avatar
Pretty much sums it up. Once the car is dialed in, you can go 8's without a ton of boost. I think you can go high 8's with around 900whp, which should be mid to high 30's in boost on a setup like this.
Old Dec 1, 2010 | 12:04 PM
h22 civic's Avatar
what type of compression?
Old Dec 1, 2010 | 01:27 PM
96 GSR-T's Avatar
Assuming you mean how much compression? lol
My guess.... high to very high
Old Dec 1, 2010 | 01:38 PM
h22 civic's Avatar
yea you aint kidding 52-54 psi of boost and 12.1 is crazzzzzy
Old Dec 1, 2010 | 04:00 PM
Turbo Ric's Avatar
Are you guys using ARP head studs or that L19 for that boost level or something else? Thank you for your replies so far.
Old Dec 1, 2010 | 04:12 PM
jdm kidd's Avatar
DO IT RIC GET INTO THE 8'S
Old Dec 1, 2010 | 04:24 PM
miller's Avatar
I run a head stud kit we had made that works great. $750. No need for the 1/2" stud and all that goes along with it. I have retourqed em probably 15 tomes already and they are still in great shape.
Old Dec 1, 2010 | 04:36 PM
mx621's Avatar
for miller/tony what fuel you guys running? Q16, vp import, or methenol? silly question but i have no clue, lol.. how many passes at that power level (50 lbs boost) are you guys getting on the motors? its just insane what you guys are going! phil
Old Dec 1, 2010 | 04:45 PM
hello1320's Avatar
[QUOTE=h22 civic;44131425]yea you aint kidding 52-54 psi of boost and 12.1
Come on man......really?
Old Dec 1, 2010 | 04:57 PM
miller's Avatar
The engine I ran for the most part of the season I had just shy of 40 passes on before I tore it down and freshened it up. The engine I ran at the end of last season leading onto this season had just over 40 hits on it before the to let go.
The engine I had in the car for outlaw was junk, a bunch of thrown together laying around junk that just happened to stay together somehow.
The engine I ran at world cup was brand new and is destroyed. When the o-ring blew out and fuel pressure dropped it lifted the head so hard on that first pass it pulled the block into 2 pieces. We changed the gasket and made it so it could limp through the rounds at world cup. After further inspection we found the factory girdle to be cracked and 2 of the main caps to have split just outside of the bore for the stud/bolt. It seems as though the crank is tryin to push out the bottom of the engine. The last few engines I have had in my car when taken apart the main bolt threads aren't in the beat shape. It is something that I am addressing with our new engine program that I will run in 2011.
Old Dec 1, 2010 | 05:04 PM
TDautowerkes's Avatar
weve been 8's @ 38 psi
whenwe went 8.7@175 we hit 50-51 and it fell to 44 at the top of 4th
Golden Eagle headtsuds $100 or so
Old Dec 1, 2010 | 05:13 PM
ashtons300zx's Avatar
Miller, its pics like that that we would love to see. haha. I love carnage pics. Ive got some pretty narly carnage pics.
Here is a pic of one of my old sr20 motors with CP pistons on stock rods. Dropped a valve, shattered the piston and the rod and wrist pin punched through the cylinder wall also cracking the block. Rod miraculously stayed in once piece on the crank. haha
Post some carnage pics man. Offseason is the perfect time for that sort of stuff. Maybe i should start a thread with carnage pics.
Old Dec 1, 2010 | 05:15 PM
Thats why i chose the Golden Eagle studs for my SR20 motor. B16a studs to be exact. The bottoms are exactly the same as a proper stud that bottoms out in the block only difference is the top is about 1/4" taller. No biggie. Ran 30+psi on the motor with zero issues. Stud nuts were still on tight as hell when i took the head off to freshen up the motor.
Old Dec 1, 2010 | 05:30 PM
miller's Avatar
I ran the ge stuff for a while also but found them stretching a little once I got in the area of where I am now.
Old Dec 1, 2010 | 05:32 PM
edsperformance's Avatar
which type of spark plugs are you guys running on those
kind of horse power and which gap using on them to
prevent turn off the spark,i use ngk r5671-8 and i have some issues
with them,any help.
Old Dec 1, 2010 | 06:17 PM
Im not anywhere near the range your at but i plan to go to 700whp on the same motor i used for a year. Just made a cam change, springs and retainers, and so on. Now going with a 67mm turbo and should be able to hit that goal on about 35-38psi. I think the studs will be fine to that.
Now post some carnage pics. haha
I was running ngk 7 heat range with a .024 gap. Im gonna run 8 heat range on the new setup.
Old Dec 1, 2010 | 07:57 PM
3minburnout's Avatar
2009
I have yet to have main bearing issues or break a crankshaft from spinning it to high or making to much power. I guess it could still happen eventually but I just dont see it happening right now. Maybe once I get some better air up here in the north east and I can make big boost we might run into something but I just dont see it.
2010
I guess you finally made big boost.
Old Dec 1, 2010 | 08:43 PM
GodFather of Boost's Avatar
50 dropping to 45 psi
9to1
off the shelf GE headstuds
R5671-11 plug
Old Dec 1, 2010 | 09:18 PM
So what's in store miller if you don't mind the question, billet main caps?I believe thats what the supra guys run to fortify there engines at high hp levels
Old Dec 1, 2010 | 10:25 PM
Also T1 Tony have you run in to similar issues as Miller? I ask since mph wise you guys seem to be makin the most power.
