how much boost?
Old Feb 20, 2006 | 04:28 PM
deadon's Avatar
Default how much boost?
I was wondering how much boost I can push in a USDM Type r motor. Has anybody went 10-12 psi on this setup before. My hondata is tuned for 5 psi, but want to boost more without killin the motor. It has a straight T3 turbo with RC's 370's and a stock 93 DX fuel pump. The USDM type r motor has a 10.6 compression compared to JDM 11.4. Just curious folks. want to go faster down the 1320
Old Feb 20, 2006 | 05:46 PM
hondaguyef's Avatar
Default Re: how much boost? (deadon)
The motor can handle plenty more power than you are putting down now. It is power that you should base what a motor can handle on not "XX psi". Just make sure that if you're upping the boost that you retune/get a retune for the new boost/power level. An injector and fuel pump upgrade should be put on your agenda as well. There is a bright red icon in the upper right hand corner that says " <FONT COLOR="red"> SEARCH </FONT> ". Any further questions you may have can be answered there. Good luck.
Phil
IntegraType-R
Oct 6, 2006 04:57 PM
evilk
May 25, 2005 06:39 PM
L8NightDrifter
Nov 18, 2004 11:57 AM
RoachForLife
Nov 3, 2003 07:19 PM
ezark
Jan 11, 2002 09:55 AM
