Higher FD + Launch techniques/clutch slipping
Old Jun 21, 2002 | 09:25 AM
sackdz's Avatar
Default Higher FD + Launch techniques/clutch slipping
Going to the strip tonight for the first time in awhile.
JDM FD owns my launch. Makes things a lot more tricky. I found with a gtech that a 4k-4.5k dump with clutch slip after the revs start to build was most effective, 14.1 on street tires w/ passenger.
I don't know how many runs I'll get so I'd like some launch ideas to try before I go.
Runs will be on very worn Hoosier R3S03 race tires that are too worn to see a REAL TRACK again .
Reccomended psi?
My main question...
What is the best technique for clutch slipping? Should I try to maintain an even rpm at first tehn let it come up slowly? Anyone use the speedometer as a guide? I realize it all happens very quickly in that ever important 1st gear.
How should I approach the situation?
Old Jun 21, 2002 | 09:39 AM
Willard's Avatar
Default Re: Higher FD + Launch techniques/clutch slipping (sackdz)
use street tires instead of the Hoosiers...
Old Jun 21, 2002 | 09:59 AM
sackdz's Avatar
Default Re: Higher FD + Launch techniques/clutch slipping (Willard)
what psi on the hoosiers peeps?
willard ill burn u
[Modified by sackdz, 1:59 PM 6/21/2002]
Old Jun 21, 2002 | 10:38 AM
sgT's Avatar
sgT
you want the tire with the softest sidewall possible
also you will find that what works well for you on the street will be WAY off
at the track. be prepare for lots and lots of wheelspin.
my suggestion is to find the tracks of rubber left by the race cars and try to
put your tires in those.
tuan...
Oct 30, 2005 01:02 AM
PePpeRedDc5
Apr 20, 2005 06:36 AM
.M.
Mar 28, 2004 03:07 AM
CarbonfiberR
Aug 15, 2002 11:17 AM
MyWhiteCivic
Jul 13, 2002 01:53 AM
