Help:trans won't go into gear at high rpm's
#26
Re: Help:trans won't go into gear at high rpm's
You know you have to use comps flywheel with their clutchs. If you don't, high rpm shifts are "sticky" and near impossible. Its a great clutch, but you shouldn't use a oem offset flywheel.
#27
#28
#30
#32
Id be interested to compare the two throwout bearings becuase ive had my CC twin in for quite a while now with the stock TOB and never had a problem at all. I did notice that when i blew my trans and was swapping to another that the redish plastic part in the TOB was shredded looking but still like i said, no problems no lift shiftin it
#36
#37
i had this problem with my comp stage 5.. Didnt know till I went to the track.. It was fine on the street because I never needed to shift that high
#38
At a standstill, put the car in gear, depress the clutch, and rev to about 6000 rpms. If the car tries to move, the clutch is not disengaging all the way. I had this issue with my CC stage 5. Never got it corrected. Tried to adjust the clutch pedal and the problem did not go away.
#39
#40
#42
I think your problems are caused from havin no clutch stop so you were pushin it in way too far. Before I jumped the clutch switch in my car, I would have to push the pedal down so far it would put so much pressure on the crank that the car wouldn't want to start and bog down
#43
well it was a combination of both, now I still dont have the pedal stop and havent had any issues again, I've got like 30 hits since I changed the bearing and nothing so far...The comment was an inside joke with my buddy cause he told me a million times to take the trans down, and use the right one and i didnt until the crank started to move causing the rpm to go down...bad washers and new crank etc.
#45
also having the clutch switch hooked up is bad.....
57mm ebay turbo and chrome 2300lbs 9 sec blast
DoWork17
08-22-2009 09:08 PM
92BlackSi
10-26-2004 03:51 PM
ls95hatch
05-24-2003 09:34 PM
