Help with launching please!
Old Oct 26, 2010 | 09:02 PM
HighBoostinTeg's Avatar
Post Help with launching please!
Hey guys, I just took my boosted 95 integra to the drags for the 1st time. I have 375whp with Work RSZ-R 16x7 rims and Falken Azenis 215-45-16 street tires. My best time was my first run on a freshly prepped track at 13.29 with a 2.3 60ft, 113mph, and shifting early in 1st and 2nd gear not to break traction. My next 3 runs had major wheel hop and was afraid i was going to break an axle (over 14sec). Tried preloading and launching at different rpms with same wheel hopping result. Would you guys recommend a traction bar and launch control? Stage 4 act clutch. I have Hondata s300 but have never used the launch control. I am saving for 15's with slicks when I up my hp to over 400. Any advice is appreciated, thanks!
Old Oct 26, 2010 | 09:07 PM
FarmYard's Avatar
Default Re: Help with launching please!
you should get some slicks now.wheel hop is no good.will break more than an axel.borrow some mabey?
Old Oct 26, 2010 | 09:15 PM
ok thanks, that was my plan. So slicks will prevent wheel hop?
Old Oct 26, 2010 | 09:24 PM
FarmYard's Avatar
yes they will.they will hook instead of bouncing all over the place.
Old Oct 26, 2010 | 09:29 PM
ok thanks for the input. Would M/T ET Street II's be ok for my current hp? Not sure if I wanna shell out for slicks and tubes quite yet.
Old Oct 26, 2010 | 10:15 PM
lunatics209's Avatar
No need for tubes. You will be better off searching the classifieds. Alot of people have complete slicks and wheel combo going for better prices than getting them separate. I would look into some MT 24.5x8-9x13.
Old Oct 26, 2010 | 10:16 PM
FarmYard's Avatar
i would get a full slick.no tubes.mabey some one else can chime in about drag radials,i dont know anything about them.
Old Oct 26, 2010 | 10:50 PM
BoostR41's Avatar
Drag radials are still going to hop. I have never broken an axle on slicks, On drag radials I have broken them like toothpicks. I have used almost every tire out there. All the times Ill post were with about 550whp
MT 235/60/15 ET street radials: Decent traction but still hops some. The best radial tire I have used. Best time: 11.9@125mph missing 3rd gear
BFG 235/60/15 Drag radials: Massive wheel hop, Traction sucked, Broke axles so bad it would twist the splines in the hub so a new axle wouldnt go in. Best time: 11.9@129mph Only got one good pass and broke 3 axles that weekend.
BFG 225/50/15: Decent tire, not as much axle breakage as the bigger BFG's but still never ran really well on them. 12.0@125mph with 400whp because I was out of gear in 4th giving it anymore power.
M&H 235/60/15 DOT: Awesome traction, bias ply so no wheel hop, on the street the tire felt less stable than radials but still not bad enough to worry me. Best time 11.7@130mph
M&H 24.5x8.5x15 slicks: 1.6 60fts consistantly no wheel hop at all even on the hardest non-preload launches.The best slicks I have ever used. Best time: 11.01@132mph
MT 24.5x8x13 slicks: good traction, no wheel hop, close to M&H but I just didnt like them as much. Consistant 1.7 60ft. Best time 11.3@132mph
That is my personal experience so you might like another tire better than I did and hate the ones I liked. It all comes down to driving style and what you are comfortable with.
Old Oct 27, 2010 | 07:32 AM
Awesome input guys, thanks! I have itr rotors so I have to go with a 15" wheel. Will the M&H 24.5x8.5x15 fit under my integra with rolled fenders with a 15x7 wheel with +37 offset? Or will I need to raise it? I have fully adjustable coilovers and its dropped about 1.5in right now, not super low.
Old Oct 27, 2010 | 07:36 AM
Ls_dx's Avatar
Yeah you might have to raise her up a bit.
Old Oct 27, 2010 | 11:43 AM
BoostR41's Avatar
The wheel is good for the slicks but you will need to be about stock ride height. Also make sure you pound in the pinchweld in the fender or it could cut the slicks. Just remember slicks grow more than a radial and depending on how soft the suspension is your front end will drop when you hit the brakes.
Old Oct 27, 2010 | 02:13 PM
Good call, I'll remember to do that. Would 23" slicks be ok? On my current tires I am still in fourth gear through the finish and if possible, I don't want to be adjusting the suspension everytime I switch wheels. Also, is an alignment needed everytime I raise or lower the car?
Old Oct 27, 2010 | 02:28 PM
RedDC2GSR's Avatar
There is a prety cool gear ratio calculator that I found on functiontheory.com the direct link is
http://www.fatboyraceworks.com/gears...Graph&Compare=
if you haven't changed the gears at all you can just use one of the pre loaded transmissions from the drop down box, otherwise you'll have to input your gear ratios. then you can select different tire sizes to get the 1/4 mile mph you are looking for. it's a good tool.
Old Oct 27, 2010 | 02:35 PM
RedDC2GSR's Avatar
also if you don't want to invest in pair of slicks or drag radials right now you might have some luck by trying different tire pressures on your current tires. I run my toyo T1R's at 35lbs for daily driving and when I went to the track the first time I was pulling 2.4 - 2.5 60's with a bit of hop. Then I brought them down to 20lbs and was pulling 2.3 60's with no hop. This is with a stock gsr with over 230,000 miles though. Buy yourself a decent tire pressre guage and try a few different pressures.
Old Oct 27, 2010 | 02:37 PM
ok so 127mph with 23" slicks vs 136mph for 24.5" slicks
-GSR tranny and 8500 redline
Any suggestions? Probably just looking for low 11's or high 10's eventually when I put my old tune back on with 500whp
Old Oct 27, 2010 | 09:37 PM
BoostR41's Avatar
You wont go 10's on a 23x7.5x15. You will need 24.5's. Just raise it to clear and leave it up. My car is WAY higher than stock and I think it looks mean
Old Oct 27, 2010 | 09:47 PM
BoostR41's Avatar
There is a pic of my integra on the 235/60/15 BFG's from years ago. Those are 26.1" tall.
That is a pic of my hatch on 235/60/15 M&H. They are 25.4" tall
Both cars had 195/55/15's in the back
Old Oct 28, 2010 | 04:54 PM
blackeg's Avatar
ive made over 100 passes on bfg radials and had wheelhop about 4 times. if it happened i just got out of it before it broke something.
never really made awesome passes on them though, best was a 12.1 at 125 with a 1.9 60ft. 400ish hp.
they are definately my limiting factor, so i bought some slicks 24.5x8.5x15 on some slips. havent run them yet, season is pretty much ending up here in ny.
if you can, get the 24.5's, look around you can find them used already on wheels in good condition for around the price of 2 new tires not even mounted
Old Oct 28, 2010 | 05:56 PM
gofastcrx's Avatar
i got a nice set of 24.5x8x13 on gold lenso wheels? 450 plus shipping
Old Oct 29, 2010 | 09:03 AM
BoostR41's Avatar
He has ITR rotors and can't use 13's not to mention that is too much.
Find a set of 15x7 rota's and get 24.5x8.5x15 slicks and you will see huge drop in times. Also if you run on slicks set the launch control on the hondata. I will help
Old Oct 29, 2010 | 02:54 PM
Ya that's what I was planning on doing. I have a set of 15x7 bbs rs (15lbs) that I was planning on using for drag wheels, will they be ok to mount slicks on? Or are rota's lighter?
What RPM should I launch at?
Old Oct 29, 2010 | 03:09 PM
FarmYard's Avatar
rotas are garbage, i wouldnt trust my life with them. here is a pic from my buddies car.
I'd use the bbs.
Old Oct 29, 2010 | 08:57 PM
BoostR41's Avatar
Those BBS's should work great and just mess with launching. It is all about how you drive. I started off at 6000rpm this year and slowly went up. I had it starting to get dialed in at my local track then went to a different track and that track wouldn't hold the power on those 6800rpm launches at all. What Im saying is it is a lot of trial and error
Old Oct 29, 2010 | 09:35 PM
Adi Radoncic's Avatar
On Fire!
What was your best 60' with these?
Old Nov 2, 2010 | 01:38 PM
sonicivic's Avatar
my car in sig, but i use 23 m&h slicks and they do great, my car has mild suspension and traction bars though
