Help!!!
Old Jun 3, 2012 | 06:10 PM
sanman000719's Avatar
Default Help!!!
so about a month ago i spun a rod bearing on the street, and the only reason i could figure out why was my pistons were lightly tapping the head. so i went with a cometic head gasket this time .050, and it shows no visible wear anymore. went with king bearings .030"
so i did some test, and tune this friday night and i finally have a great 60' time with a 1.63 best and first 1.60 60' in 3 years. well on my 3rd and final pass it spun a bearing again. same rod bearing as before.
anyone have any kind of idea as to why this might be happening.
i was thinking of rebuilding this again, but might just buy a differant short block
any help would be awsome
Old Jun 3, 2012 | 06:14 PM
94turbosi's Avatar
Default Re: Help!!!
Did u get the rods and crank inspected , checked clearances ect. Or did u just throw a new set of bearings ?
Old Jun 3, 2012 | 06:15 PM
Default Re: Help!!!
sure did replace 2 end caps
Old Jun 3, 2012 | 06:16 PM
Default Re: Help!!!
cransk/rods/psitons were all inspected
Old Jun 3, 2012 | 06:18 PM
94turbosi's Avatar
Default Re: Help!!!
Well since u have checked all of your machine work. And it damaged the same cylinder I would check your inj , ecu , wiring.
Default Re: Help!!!
car had 10 runs on the dyno and 2 passes at the track and ran for a week on the street to see if it would have issue before traveling to tulsa.
was tuned to 34psi@737, and the passes at the track were at 20psi
Old Jun 3, 2012 | 06:25 PM
Garage 808 Hatch's Avatar
Default Re: Help!!!
Clearances? That cylinder have any oil in? Anything look different in that combustion chamber than the others?
utahturbosohc's Avatar
Default Re: Help!!!
What do you have for crank case ventilation? A lot of guys are having trouble with all of the oil getting trapped in the head, due to it not being able to return back to the block from the head.
Old Jun 3, 2012 | 06:26 PM
Default Re: Help!!!
http://www.facebook.com/#!/photo.php...type=1&theater
SPOOLINmatt's Avatar
Default Re: Help!!!
i bet $1000 its a bad crank now. probably out of round. been in your shoes years ago...ive never spun a bearing since i solved that problem.
Old Jun 3, 2012 | 06:29 PM
Default Re: Help!!!
vent is -12 in 2 -10's drain back
Matt has the crank polished after the first time
Default Re: Help!!!
my bearings looked fine even the one that was mangled it just seems like it was pushed over and mushroomed
Old Jun 3, 2012 | 06:32 PM
Default Re: Help!!!
polishing will not solve it man.
Old Jun 3, 2012 | 06:33 PM
Default Re: Help!!!
yah my feeling is dumping this be16 and going back to a gsr
Old Jun 3, 2012 | 06:49 PM
Default Re: Help!!!
Old Jun 3, 2012 | 07:13 PM
90sedan's Avatar
Default Re: Help!!!
I've spun a rod bearing before as well. Replaced the crank and rod and rechecked all the clearances and never had another issue. I'd bet that the crank and rod are way out round and will continue to spin bearings until replaced.
Just replace the crank and rod and bearings and be done with it, no sense in getting another short block unless you really want a gsr.
Old Jun 3, 2012 | 09:23 PM
hello1320's Avatar
Default Re: Help!!!
This is a very basic problem.....message me please
Old Jun 4, 2012 | 04:06 PM
Default Re: Help!!!
i spun bearings like 3 times on the same rod before i figured out to not do it 3 times in a row ever again lol
Old Jun 4, 2012 | 04:07 PM
Default Re: Help!!!
new crank will be dropped in man, and a new set of rods as well probly just do the tt's while im at it
dieselwilly
Honda Civic (2001 - 2005)
Nov 23, 2014 03:20 PM
90ZCREX
Sep 3, 2011 11:47 PM
USDM-EK4*
16
Jul 11, 2009 06:05 PM
JDMJONES
Nov 29, 2004 10:10 PM
tek_civic
Jul 11, 2003 10:41 PM
