b16 arp head bolts seeping oil between head and block
Old 08-02-2018, 02:18 PM
Default b16 arp head bolts seeping oil between head and block
i have a freshly rebuilt engine 0 miles not even been started , block was decked head was decked. i have a je pro seal headgasket, and arp head studs but i kept finding conflicting information on thje torque specso i did them in two steps 35-65, under the driver side under the cam gears i can watch it seep along the side. i have a blox oil press gauge that dosent read any pressure at all and im not sure if thats normal or it needs to be running.
1320vickers is offline
Old 08-02-2018, 05:36 PM
Default Re: b16 arp head bolts seeping oil between head and block
May of found the problem for one I didnít use dowels and Iím seeing 80 ft lbs for the studs. Itís leaking from the front corner bad but also more on the side as well
Old 08-03-2018, 06:34 AM
you need to use dowel, if you decked head and block a lot, you may need to machine down the dowel.
As for the leak, it can also occur if you dont do this:
Cupajoe is offline
Old 08-03-2018, 11:46 AM
It wasnít much 0.006 on the block and the head was less. I ordered dowels should I put gasket maker around the holes were oil and water pass thru I used copper spray the first time
Old 08-03-2018, 12:30 PM
I suggest no copper spray. I would not re-use the head gasket, get a new one and oem is possible. Not sure about JE proseal reviews.
I only put the hondabond stuff (I actually used toyota black fipg) on the bottom left in the pic outside dowel on mine where mine would puddle oil, I skipped the other and well the bottom right near the title belt leaks a little ha ha. I should have done them all next time I will.
If you just want to smear some gasket maker on the outside where head meets the block where the leak is after cleaning it, that has done the trick for me as well. The engine needs to be turning to have oil pressure. 80-85ft/lbs is what I do, I actually go to 85 and make sure you torque in proper sequence.
Anyway good luck!
Cupajoe is offline
1320london
09-29-2015 07:09 AM
PhunekyPhish
18
05-13-2014 02:47 AM
Mfoehrkolb
11-26-2007 09:10 PM
93sivtec
10-07-2007 04:24 AM
danxdan
11
08-22-2005 03:48 PM
Quick Reply: b16 arp head bolts seeping oil between head and block
  • Ask a Question
Question Title:
Description:
