Harmonic Dampner
Old Oct 11, 2010 | 09:00 PM
2k.civic.si's Avatar
Default Harmonic Dampner
Anyone use one of these yet?
http://performanceparts.com/part.php?partID=269007
http://www.jcwhitney.com/powerforce+...49&TID=SP00001
I can get them for less then $170 shipped instead of spending $300 plus on an ATI and its SFI approved.
Old Oct 11, 2010 | 09:09 PM
Divers's Avatar
Default Re: Harmonic Dampner
A balanced OEM one seems to work just fine.
Old Oct 11, 2010 | 09:17 PM
That's all fine and dandy but I have a reason for needing an aftermarket single belt pulley and I have this urge to replace the n1 pulley Ive been running.
Old Oct 11, 2010 | 09:22 PM
reaction360's Avatar
They do work fine. but technically if you're running too quick and too fast, by nhra rules(11.49 I believe) you're supposed to have one on the motor.
Old Oct 11, 2010 | 09:31 PM
KStuned's Avatar
The dampener police are here
Old Oct 11, 2010 | 09:45 PM
I just don't see the point in running something that costs $300+ when i can get an SFI approved one for $170 on a motor that constantly gets serviced. Unless someone here has ran these professional products harmonic dampeners and had one explode at 9,500+ rpm? at the end of run i pull the motor out to just past 10k in 4th to finish and the last thing i want is a crank pulley coming at me or someone else.
Old Oct 11, 2010 | 09:51 PM
Divers's Avatar
Excuse me sir, but you're 2.5 seconds too fast for your alternator pulley. My bad.
Old Oct 11, 2010 | 09:55 PM
lol...i wouldn't even run an alternator if i didn't drive it on the street.
Old Oct 11, 2010 | 10:00 PM
Redline130's Avatar
Spend the money on an ATI or Fluidampr. The Professional Products "dampner" doesn't even have timing marks on them.
I used on a LS/VTEC which threw a rod through the front of the block due to bearing failure. Both the rod and main/thrust bearings on the motor were toast. A friend of mine also used a Professional Products dampner and lost his motor as well, same way. Not saying that it was the dampner, but it was a common part on our motors. My motor was turbocharged, he was on the bottle. I've been using an OEM one for the past 1.5 years with no issues, but I'm only making around 600whp.
Old Oct 11, 2010 | 10:03 PM
good to know...im just a short geared n/a guy....nowhere near 600whp.
guess i will just watch more $$$ fly out of the wallet and just get it done with ati
Old Oct 11, 2010 | 10:04 PM
1320fuel.com's Avatar
ati artie!
Old Oct 12, 2010 | 03:09 AM
lsef's Avatar
Im useing the PP damper with good results ls/v 438hp 311tq reving to 9200 rpms and has not destroyed my oil pump like the n1 pulley did.
Old Oct 12, 2010 | 04:12 AM
turbotypeR@SPEC's Avatar
25 Year Member
http://www.atiracing.com/products/dampers/index.htm
Old Oct 12, 2010 | 05:58 PM
Old Oct 12, 2010 | 06:16 PM
BRMS's Avatar
I've used PP dampers in past and have seen the allen screws back out, strip, and become a hassle, the multi belt damper, Ive seen it separate. Poor construction. I've ran Fluidampr for several years now and have never looked back. Yes there around 350ish, but well worth it, considering most of our engines are expensive.
4drctr420
Mar 14, 2017 05:41 PM
lude98SH
40
Nov 22, 2016 11:00 PM
Brown Rock
Dec 30, 2011 11:02 PM
1xfastxhatch
10
Apr 25, 2008 09:03 AM
Louis_tien
Nov 23, 2003 09:43 PM
