gsr 83mm ring gap???
Old Mar 14, 2011 | 04:29 PM
thebrowneg's Avatar
Default gsr 83mm ring gap???
i want know what i need to file my rings to 83mm gsr block for turbo goal 30psi 700whp????????
Old Mar 14, 2011 | 04:34 PM
22_42r_eg's Avatar
Default Re: gsr 83mm ring gap???
Multiply bore x .055" for a booster street and strip application. Or bore x .060 for a race application
Old Mar 14, 2011 | 04:45 PM
Enzo-Racing's Avatar
you left out an important 0 there.
Old Mar 14, 2011 | 05:18 PM
thebrowneg's Avatar
street/track am at 83mm now i need top ring gap and sec ring gap please thanks.
Old Mar 14, 2011 | 07:47 PM
thebrowneg's Avatar
spec please bump???????
Old Mar 14, 2011 | 07:55 PM
Garage 808 Hatch's Avatar
.028,.026
Old Mar 14, 2011 | 08:01 PM
thebrowneg's Avatar
Originally Posted by Garage 808 Hatch
.028,.026
is specs for a street car/track???
Old Mar 14, 2011 | 08:43 PM
Its what I had my 800whp 83mm gsr at. great comp and 1% leakdown
Old Mar 14, 2011 | 10:20 PM
CO_RaceFab's Avatar
Maybe im an idiot (doubtfull) but i do alot of engines and they like it tighter than that... im normally around 22 and 20 or even 20 and 18 on some of my own engines and they love it
Old Mar 14, 2011 | 10:35 PM
lsvtechatch92's Avatar
You will get a million different answers on this topic... some say bottom should be wider some say top should be wider! I personally go with smaller gap on top and then bigger gap on bottom. somewhere along the lines of .022 top and .025 bottom should be fine for a street car making around 600whp if you wanna make more power then open them up a little bit. maybe around .024 and .027
Old Mar 14, 2011 | 10:46 PM
CO_RaceFab's Avatar
I dont get why u would want more blow by... i guess this is why everyone has these elaborate catch cans for cars making 750hp and less
Old Mar 15, 2011 | 12:34 AM
wolve's Avatar
depends on fuel used also....
not only whp but also torque and afr plays a factor....
it's all about heat
i'd rather run it slightly loose then finding out it was too little gap tough
heavy duty
Mar 2, 2011 10:11 AM
jusholeum
May 12, 2009 06:30 PM
civtegra_hybrid
Sep 25, 2004 11:17 PM
vtec94civic
Nov 20, 2003 07:20 PM
GSRacer
Nov 8, 2001 01:20 PM
