fuel filter q:
Old Jan 9, 2007 | 10:44 AM
I B BANGGIN's Avatar
Default fuel filter q:
this is my set up so far, but be for i tighten everything and cut any more steel braided line i was wondering what you guys think.
heres my question: will i run into any problems with having a fuel filter directly on my fuel rail?
ruturn line goes under the fpr, not over...
one fuel filter inside fuel cell....
Old Jan 9, 2007 | 10:52 AM
MrParks's Avatar
Default Re: fuel filter q: (I B BANGGIN)
i think that you will eventually have a problem with the rail leaking after awhile, there is quite a bit of stuff hanging off that one fitting
Old Jan 9, 2007 | 11:02 AM
jjspec's Avatar
Default Re: fuel filter q: (MrParks)
What kind of in-cell filter is that? How many microns?
Old Jan 9, 2007 | 11:09 AM
Default Re: fuel filter q: (jjspec)
i really dont know.. i got it from a friend that was using this fuel cell in his k20 race car..it worked fine for him so i just left it (fuel filter) in there..i had the other aeromotive fuel fitler so i wanted to use it..
Old Jan 9, 2007 | 11:15 AM
jjspec's Avatar
Thanks, if you find out more info, post please
Old Jan 9, 2007 | 11:19 AM
IHaveTurbos's Avatar
Here is a link for the In tank Filter: http://www.petersonfluidsys.com/filter_fuel.html
In-Tank Fuel Filter
Peterson's new in-tank fuel filter uses a stainless pleated filter for superior filtration. Attachment is made by slipping a pick up hose over the 3/4" neck and securing with a clamp. It is available in straight or 90 degree styles. This filter has been proven in competition by World of Outlaws stars Sammy Swindell and Randy Hannigan.
09-1460 Straight 60 Micron
09-1461 90 Degree 60 Micron
09-1480 Straight 45 Micron
09-1481 90 Degree 45 Micron
Old Jan 9, 2007 | 11:20 AM
DaveF's Avatar
that **** is going to get in your way when it comes time to take the trans out...
Old Jan 9, 2007 | 11:23 AM
jjspec's Avatar
Default Re: fuel filter q: (dturbocivic)
Thanks turboelements.com
Modified by jjspec at 12:37 PM 1/9/2007
Old Jan 9, 2007 | 11:42 AM
i can get to all the tranny bolts fairly easy so thats not to much of a problem..getting to the starter is a little difficult but i can manage..
ill try and find out more on which filter im using inside the cell and post..
Old Jan 9, 2007 | 11:46 AM
scmil95eg's Avatar
We typically do not recommend doing that unless you support the filter somehow.
I'm not saying you'll snap the fitting for sure, but we have seen it happen. Numerous times.
3" to 4" of line between the filter & rail is all it takes to dampen engine vibration.
Old Jan 9, 2007 | 12:13 PM
Default Re: fuel filter q: (gdmfsob069)
so best bet is to make some brace for it or just add some braided line between the two...
thanks for the info guys!
Old Jan 9, 2007 | 02:28 PM
Project-D's Avatar
Use a steel fitting between the rail and filter. I've seen aluminum ones snap, but not seen a steel one snap...
Not saying it is a perfect fix, but should be better.
Old Jan 9, 2007 | 05:26 PM
buck02's Avatar
Default Re: (Project-D)
i use my filter connected to my rail and in 3 yrs never had a problem.
Old Jan 10, 2007 | 03:43 AM
R@mon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">that **** is going to get in your way when it comes time to take the trans out... </TD></TR></TABLE>
why would you need to take the tranny out of a turbo honda?
looks good btw
Old Jan 10, 2007 | 08:34 AM
ninesecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project-D &raquo;</TD></TR><TR><TD CLASS="quote">Use a steel fitting between the rail and filter. I've seen aluminum ones snap, but not seen a steel one snap...
Not saying it is a perfect fix, but should be better.</TD></TR></TABLE>
I would do this as well, it is cheap insurance. You may not have an issue, but steel would be a better way to support the weight.
Old Jan 10, 2007 | 11:02 AM
ExospeedAMcrx's Avatar
Default Re: (ninesecrx)
small fuel filters on the rail maybe fine.. but that ones a HUGE Bitch! I'd redo that one like everyone says.
Old Jan 10, 2007 | 08:36 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (exospeedAMcrx)
I'd probably run that filter before the pump, since you dont have one before the pump. Then I'd run a smaller one on the rail.
Old Jan 10, 2007 | 11:03 PM
ninesecrx's Avatar
Default Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I'd probably run that filter before the pump, since you dont have one before the pump. Then I'd run a smaller one on the rail. </TD></TR></TABLE>
He does have a filter before the pump...check it out, it is inside his fuel cell. The other issue is you have heavy braided line that adds weight especially with it bobbing around loosely.
Old Jan 12, 2007 | 12:35 PM
94draglude's Avatar
I got denied inspection at an nhra event for lines going over my tranny like that. They said it was a rule now that you cannot have your fuel lines go over the transmission because of flywheel debri.. But Ive seen people get away with it though.
Old Jan 14, 2007 | 09:08 AM
espinalmotorsport's Avatar
just mount the filter in the pump ihave my for years whit that sen setup never have a problem
Old Jan 14, 2007 | 04:57 PM
h22 civic's Avatar
Default Re: fuel filter q: (espinalmotorsport)
i have seen the filter break the aluminum fitttings i would re think it and re mount with a line in between
Old Jan 14, 2007 | 05:32 PM
swoyEKr.'s Avatar
I wouldnt have mounted that there either, but I dont think that you would break it. But i'm sure it's possible, and the face that you can have large amounts of fuel spilling everywhere is just looking for trouble. Everything looks pretty good though.
Old Jan 14, 2007 | 06:57 PM
Default Re: (swoyEKr.)
thanks for the info guys....and just to let you guys know, now there was some line added between the rail and the filter, due to the way my piping was made i had to move it and my fuel pump!
eg:R
Mar 31, 2010 05:37 PM
Ej8_KiD
Oct 27, 2009 07:15 PM
LS-VTEC-TURBO-EF9
Jun 19, 2009 06:26 AM
CPR
Sep 27, 2004 07:10 AM
joeymachado
Nov 13, 2003 08:11 PM
