FMIC Build Help
Old Jan 14, 2011 | 10:06 PM
dragallmotor24's Avatar
Default FMIC Build Help
I need a FMIC either built from scratch or something available off the counter which I prefer. Width space is about 24in and Height is 12in and Thickness should clear a 4in. FMIC. (24in. would be one end tank to another end tank)
Any recommendations where I can buy IC that handles about 800hp ? 3in inlet (v-band) and 3in outlet would be great. I found a 25X12X3 FMIC but rated for only 400hp, would this matter if Im strictly driving quarter mile only? The core is 18X12X3, any info is greatly appreciated.
Old Jan 14, 2011 | 10:07 PM
JDM97R's Avatar
Default Re: FMIC Build Help
T1 Race or Full race
Old Jan 14, 2011 | 10:11 PM
Ill try calling T1 2morrow. Thanks!
Old Jan 14, 2011 | 10:14 PM
rota92
Guest
Posts: n/a
Tony will get ya hooked up, do you have room for a 4" core or bigger? Thickness wise?
Old Jan 14, 2011 | 10:18 PM
I should clear a 4in core, just have to move the FMIC a little forward. Does it matter if it sits to close to the exhaust manifold? BTW, Im very new to turbo setups so I apologize for any retard questions. I was always a NA guy.
Old Jan 14, 2011 | 10:31 PM
cibao2ner's Avatar
if your track only you might want to consider a water to air....precision make one rated at 1000hp...it adds more stuff...like the reservoir and a water pump but its way more efficient and will keep your iat cooler on hot summer days...
Old Jan 14, 2011 | 10:34 PM
Do you have a website or part number for the water to air kit? Thanks
Old Jan 14, 2011 | 10:57 PM
cibao2ner's Avatar
http://www.frozenboost.com/product_i...da1eff242f6024
http://www.t1racedevelopment.com/ind...tercooler.html
http://cgi.ebay.com/ebaymotors/Preci...2#ht_554wt_939
those are 3....do some research and you will probably like the idea better...air to air is more simple...but if u trailer your car to the track and dont mind adding a couple extra stuff go water to air...
Old Jan 15, 2011 | 10:13 AM
turboek1's Avatar
I run a Garrett core, 12x18x4.5 w/ custom endtanks. setup has made 800+...
Old Jan 15, 2011 | 10:35 AM
rota92
Guest
Posts: n/a
Yea if you aren't married to an Air-Air for any reason an air to water would work great in your situation.
I also have a meziere pump to help circulate the water if you need one
Old Jan 15, 2011 | 11:24 AM
Thats exactly what Im looking for but the only problem for me is that the outlet endtank would block the hitch/latch for my one piece front end. Who made your IC?
Old Jan 15, 2011 | 11:26 AM
Im not 100% on air to air but I dont know how to plumb the water lines. Im trying to find threads and pictures of how to do a install water to air.
Old Jan 15, 2011 | 12:33 PM
hybrdthry911's Avatar
you should really be looking for a local company or a company you can ship the car to that can fabricate the setup specific to your car. there is no off the shelf intercooler thats going to just drop in. even with an a2w setup you might want to consider the same but it would be easier.
Old Jan 16, 2011 | 01:27 PM
Im searching for a Precision water to air complete kit but cant seem to locate it. T1 has bad *** system but $1125 is a bit steep for my garage assembled HR car and my pockets. Any one know of a site? Thanks
Old Jan 16, 2011 | 01:59 PM
tony1's Avatar
We have the Precision one as well, I think it's about $700.
Old Jan 16, 2011 | 02:12 PM
Can you PM me additional info. as far as size, hp rating, and what all included. Thanks Tony1
Old Jan 17, 2011 | 11:13 AM
DaveF's Avatar
run it on alcohol !
Old Jan 17, 2011 | 11:52 AM
Ls_dx's Avatar
F yeah dave SICK setup man
Old Jan 17, 2011 | 08:20 PM
Originally Posted by DaveF
run it on alcohol !
Alcohol doesnt require a cooling system right? Would I just plug up the radiator necks?
Old Jan 17, 2011 | 08:37 PM
tony1's Avatar
Sorry, my PMs are disabled. Shoot me an email at T1race@gmail.com if you're interested and we can go over the details.
Old Jan 17, 2011 | 09:55 PM
emailed
Old Jan 18, 2011 | 06:06 AM
DaveF's Avatar
you can run the engine "dry" (no water) but we havent tried it out yet. we still circulate water through the engine.
Charlie Moua
Nov 12, 2012 02:14 AM
JDM EJ1 95
Jan 30, 2008 01:53 PM
Boilermaker1
Welding / Fabrication
Apr 17, 2006 08:35 PM
HiAssHell
Nov 17, 2005 10:24 AM
cock head
Sep 23, 2005 09:51 AM
