how to raise voltage
Old Jan 13, 2011 | 08:03 PM
slowboy90's Avatar
Default how to raise voltage
i am looking into the new dw300 fuel pump and ive read that it flows significantly more at higher voltage. What are some ways to raise the voltage to say 16 volts at the pump?
Old Jan 13, 2011 | 09:15 PM
JustOneOrTwoPosts's Avatar
Default Re: how to raise voltage
Isn't 16v a bit high? Are you boosting? I've only upgraded the fuel pump wiring so my pump runs around 14.4v. Never needed/tried anything higher. I know MSD makes a fuel pump voltage booster if that applies to you.
Old Jan 13, 2011 | 11:39 PM
locash's Avatar
Kenne Bell boost a pump, or run a 16v battery, your call.
Old Jan 14, 2011 | 11:04 AM
boosted hybrid's Avatar
Kenne bell boost a pump works great. I have used them on many different cars/pumps and its OEM reliable. I have a 20 volt dual competition one for sale that is basically brand new. PM me if you are interested.
Old Jan 18, 2011 | 02:18 PM
slowboy90's Avatar
when changing the wiring where to do start at?
Old Jan 18, 2011 | 04:05 PM
xenocron's Avatar
Start with thicker gauge wiring and a quality relay, we offer a kit to help simplify the process.
http://www.xenocron.com/fuel-pump-relay-kit-p-497.html
But like the others said, the boost-a-pump is the way to go as it allows you actually provide more voltage to the pump.
http://www.xenocron.com/kenne-bell-b...ump-p-568.html
Old Jan 18, 2011 | 09:21 PM
Garage 808 Hatch's Avatar
A flux capacitor will yield you 1.21 jiggawatts.
boost fed ls
Jan 10, 2009 11:33 AM
littlecrxVTEC
Dec 26, 2007 02:54 PM
Reelizmpro
Jul 10, 2005 06:33 AM
1genmud
11
Mar 28, 2003 03:23 AM
Mikex25
Oct 13, 2001 10:30 PM
